Author Topic: Teds new project a CB500 K1 mostly version 0.5 circa 1972.  (Read 307807 times)
Re: My new project a CB500 K1 circa 1972.
« Reply #30 on: September 12, 2022, 05:00:37 PM »
I've had the back wheel out and sorted out the hub binding  - a very small dent in the hub flange edge  area was the culprit. Cut most of the alloy out with a Stanley Knife then a bit of polishing with a cutting wheel - cleaned brake shoe contact area plus roughed up the shoes a tad.
Next sort out the stiff throttle - just drained the tank prior to removal to get at the open & closing cables - seat removed to make it easier to access all areas.
Definitely need to look inside the engine for peace of mind.
« Last Edit: September 12, 2022, 05:58:28 PM by McCabe-Thiele (Ted) »
Re: My new project a CB500 K1 circa 1972 has arrived.
« Reply #31 on: September 12, 2022, 05:14:07 PM »
Sounds like you have found yourself a good project Ted.
Offline flatfour
« Reply #32 on: September 12, 2022, 05:44:58 PM »
On the subject of brake lever travel, I (and a good few other riders that I know from our evening bike meets) have found that replacing the original Honda master cylinder (smooth reservoir) with a pattern type (fluted reservoir) reduces lever travel immediately, for reasons that I am unsure of, but assume that perhaps the piston sizes differ slightly?
« Reply #33 on: September 12, 2022, 06:01:20 PM »
I have a DS replica on my 400 - there is virtually zero movement.
I'll try a spare original lever see how that is if it fits.
« Reply #34 on: September 12, 2022, 06:05:35 PM »
My dirty engrained fingerprints will confirm that - I have plan A to complete - then ride it ASAP before winter sets in - see how the gearbox feels then I can see it being a pile of parts before Christmas!
« Reply #35 on: September 12, 2022, 09:25:01 PM »
Horay, balance will be returned to the Ted household ;) :D
« Reply #36 on: September 13, 2022, 08:31:16 AM »
Except my phone does not recognise my  finger print.😁
« Reply #37 on: September 13, 2022, 10:02:39 AM »
« Reply #38 on: September 13, 2022, 10:40:12 AM »
Fingerprint? How can you have those if youve been working on bikes for years
« Reply #39 on: September 13, 2022, 11:31:53 AM »
I did once try to fingerprint a glass cutter - hardly a single loop or whirl was printed on the form.
My submitted prints were rejected twice before anyone read the note I submitted on the form.
The glass dust wears them away - still now there is the DNA option.
« Last Edit: September 13, 2022, 06:32:13 PM by McCabe-Thiele (Ted) »
« Reply #40 on: September 13, 2022, 09:00:08 PM »
Most of the heavy throttle action was down to cable routing so that's one less item for now - needs a new throttle tube and grip for the rebuild but works well enough for now.
Nice chrome stopper in the handlebar end. - not sure if that's original.
Started first clean of the spare crank cases that Bryan has provided / lent me - boy was there some oil crud on the case halves. As I'm giving it some stiff brushing with petrol in a plastic box that the cases arrived in I realise petrol is leaking every where - the box has a split in the base!
« Reply #41 on: September 13, 2022, 11:42:56 PM »
Knew i should have got better cables when i built it!
« Reply #42 on: September 14, 2022, 06:17:24 AM »
Ted, I may just have a spare throttle tube kicking about. Don’t buy before checking with me.
« Reply #43 on: September 14, 2022, 08:05:47 AM »
Thanks Philip,
I've not bought a replacement yet - can't believe the cost of the grips mine are not in great condition & will not come off the tube in one piece. Cheers Ted
« Reply #44 on: September 14, 2022, 08:10:16 AM »
Beware of non oem grips. Check the length before buying.
