Author Topic: Teds new project a CB500 K1 mostly version 0.5 circa 1972.  (Read 307565 times)
Re: Teds new project a CB500 K1 circa 1972.
« Reply #150 on: October 02, 2022, 10:28:51 AM »
What or who is BiL
Sorry Brother-in-Law (BiL)
Offline mickwinf
« Reply #151 on: October 02, 2022, 11:16:57 AM »
I had real trouble on my 550 removing the taper roller bearings as there is no space to get a long drift to knock them out, the bearing is the same diameter as the housing. In the end i had a mate put a bead of weld around it and it just fell out. Same problem now with Lazarus.
« Reply #152 on: October 02, 2022, 12:33:57 PM »
The manual states there are 6 bolts on the top half of the casing I have 6 holes but only 5 bolts so either one is missing or there its a dowel in its place - position is circled in blue?
What is the big bolt head with a built in tab please?
.Top casing bolts by Macabe Thiele, on Flickr
« Reply #153 on: October 02, 2022, 01:17:52 PM »
Big bolt is the gearchange selector drum retaining bolt. It was used on early models to aid positive neutral selection.
The one circled is one of the 6 bolt holes and uses a 6 x 100mm flanged bolt.
« Reply #154 on: October 02, 2022, 02:32:56 PM »
Thanks Ken - a missing bolt then - no problem. Next I need to dismantle the primary gear drive as it's nothing like the 400.
Time for me to read the manual again in detail - so far I've just removed two circlips & the gearshift levers - that's it for today - need to keep the right side of Wendy on her only day off in the last 6 days.
« Reply #155 on: October 02, 2022, 06:37:23 PM »
And the casing has been separated a tad ahead of schedule.
A bit of a wrangle getting the primary shaft out of the casing but managed in the end with minimum violence.
.2nd October 2022 by Macabe Thiele, on Flickr
« Last Edit: October 02, 2022, 06:42:23 PM by McCabe-Thiele (Ted) »
« Reply #156 on: October 02, 2022, 06:42:41 PM »
People seem to think that to replace the primary drive rubbers you need to remove the 3 large countersunk JIS screws but in actual fact you don't. As soon as you remove the circlip it will come apart.
« Reply #157 on: October 02, 2022, 06:45:51 PM »
Noted Ken along with your other words of wisdom.
« Reply #158 on: October 02, 2022, 08:59:12 PM »
Sharp rap on a piece of softwood will separate the primary drive to access the rubbers. This is where it gets interesting as many report the rubbers as being as hard as marble, but my 1977 17k miles example was as soft as originally installed, which is by the way not ‘soft’, just ‘compliant’. I replaced mine anyway as a matter of course. They ain’t cheap. That primary drive looks past its best by the way…..
« Reply #159 on: October 02, 2022, 09:41:02 PM »
Less than £50 for the Kawasaki one its change it anyway
« Reply #160 on: October 02, 2022, 09:56:06 PM »
Although it's clearly not the original there was a fair bit of play in the primary chain - I'll defo replace it.
« Last Edit: October 02, 2022, 10:02:41 PM by McCabe-Thiele (Ted) »
« Reply #161 on: October 02, 2022, 10:12:03 PM »
Anyone got the Kwaka part number handy please?
« Reply #162 on: October 02, 2022, 11:04:17 PM »
92057-1011
« Reply #163 on: October 03, 2022, 07:30:57 AM »
I’d replace it Ted, but before you do try to evaluate the actual wear. This photo provides a simple visual check. The one in the background is a new Kawasaki item, the one in the foreground is 17k miles.
If you do replace the chain it would be useful for you to post a similar comparison just out of interest.
« Reply #164 on: October 03, 2022, 08:03:29 AM »
