Author Topic: Honda Grease Nipples  (Read 5014 times)
Offline Phil Ward (RIP)
« on: September 12, 2023, 05:41:53 PM »
I'm going to replace all the grease nipples on my bikes as I'm not confident they accept grease properly.
Are they just a friction fit? Do you just wangle them out and knock them in with a tube on the flanged part of the nipple?
They are the ones on the swing arm (350/500/750) and clutch (350/500)
Thanks in advance
Re: Honda Grease Nipples
« Reply #1 on: September 12, 2023, 05:59:31 PM »
I know for sure the 750 swing arm grease nipple is threaded Phil as I stock them. That's the only one I can remember though, Trig will know what fit the other are I'm sure.
Edit..... The threaded ones are for later 750's than yours Phil 😱😱😱
« Last Edit: September 12, 2023, 06:03:13 PM by Nurse Julie »
« Reply #2 on: September 12, 2023, 06:00:24 PM »
They just push in Phil on the flange. Were original some sort of brass which are hard to get hold of theses days.
To get out without damage with a small blade under the flange and as you say wiggle  ;)
« Reply #3 on: September 12, 2023, 06:30:06 PM »
Thanks Julie/Graham - I'll have go
Online deltarider
« Reply #4 on: September 12, 2023, 08:11:25 PM »
Realise that for greasing not just any grease gun will do. Can be frustrating. I maybe have succeeded about three or four times, in over a ton, that I have managed to get it in there. Have a look at these different nipples. The grease pump shown in the pic will require quite some muscle to push it in there.
« Reply #5 on: September 12, 2023, 08:26:45 PM »
A "Wanner" Swiss made grease gun will get the job done every time. Excellent quality and action, look for one on the bay as don't know if made now.
They sell for about 20 quid, and one of the best value for money you can buy. They'll get grease into old solidified propshaft joints that many won't even touch  ;D
Highly recommended.
« Reply #6 on: September 12, 2023, 09:25:39 PM »
Just changed the nozzle on my grease gun and managed to get grease in ALL the nipples on all my bikes! So I think I'll take Nigel's recommendation and spend the 'nipple' money on a 'Wanner'!
« Reply #7 on: September 12, 2023, 09:28:58 PM »
« Reply #8 on: September 12, 2023, 09:35:30 PM »
 ;D ;D ;D
Yes, you do have to be careful how you type that one don't you  ;D
Offline Anderzander
« Reply #9 on: November 15, 2026, 10:25:45 PM »
Can I ask - which kind of nozzle you used please ?
CB750 K3
« Reply #10 on: November 16, 2026, 07:46:39 AM »
Grease guns, I've always wasted more grease when filling them than I ever use.
I bought a mini cartridge type during Covid, still ended up covered in grease. I wish I had fitted the later threaded nipples as the brass type needs a lot of effort to get grease in.
I've been spoilt in the past by using garage air driven grease guns at work.
« Reply #11 on: November 16, 2026, 08:00:10 AM »
Highly recommended.
Online deltarider
« Reply #12 on: November 16, 2026, 08:28:22 AM »
I follow this thread with interest. For greasing the only central nipple underneath my swingarm not just any grease gun will do. Frustrating. I maybe have succeeded about three times, in over a ton, that I have managed to get some grease in there. In spite of that, the swingarm on my CB500K2-ED has not developped an issue so far. I could be wrong, but maybe with the modification - that include going from one on each side to a central nipple underneath - Honda had chosen for the 'greased for life' approach that was not uncommon in the automobile industry at that time. If not, I find it hard to understand that my swingarm has developped no play whatsoever so far (knock wood).
Just over a month ago someone lended me his grease gun assuring me his nozzle would fit. Not so, so again no grease went in and plenty around the nipple.
Here's my question: what nipple should I choose for replacement that will fit the commonly used grease gun? In other words: who of you, that has a model with that central nipple, has succesfully replaced it?
« Last Edit: November 16, 2026, 11:34:46 AM by deltarider »
« Reply #13 on: November 16, 2026, 10:49:18 AM »
Maybe less hassle to knock the swing arm pin out clean and re pack. Just a thought! I have had limited success with nipples.😜
Online Oddjob
« Reply #14 on: November 16, 2026, 02:16:17 PM »
The 500 swinging arm with the grease nipples on each end is a very poor design and it's no wonder they fail all the time. In essence you fill up the spindle, to a depth of around 1 inch, the spindle is drilled there to let the grease out, the only problem is it lets the grease out inside the internal collar that Honda fitted, that's drilled and grooved to allow the grease to lubricate the steel bushes fitted. However to get to that point the entire internal area of the collar needs to be full or there's little pressure to force the grease out of the collar and into the holes drilled in it. You do a couple of pumps of the grease gun and think that's enough but it could just be filling the void inside the collar, the other problem is the holes in the collar which allows the grease through to lubricate the bushes get clogged with hard grease. You get a pressure backup because of that and grease starts to escape from around the grease nipple, you think that means it's full of grease, well lubricated etc only to find in a year or 2 that both bushes have worn to the point they need replacing. Along with the collar I may add, the collar wears faster than the bushes, you can see the wear marks on it when you remove it. It's also getting almost impossible to replace these days.
The central grease nipple fitted to the 550F and the 550K amongst others is a much better solution. That fills the void between the collar and the swinging arm, it's a much bigger void so takes more grease but once it's full you can see it pouring out of the swinging arm caps between the swinging arm and the frame. Once the void is full it squeezes between the bush and the collar and then out of the swinging arm, hence why Honda went to fibre bushes instead of metal ones on the 550. Much better greasing system fitted. The nipple fitted is also one of those that grips the grease guns nozzle, the back pressure seals it onto the nozzle, meaning grease gets pushed out of the nipple rather than from around the nozzle. Almost any modern grease nipple has this feature and all modern grease guns have the spring fitted inside the nozzle that causes the seal.
Best solution if you own a 500, replace the swinging arm with one off a 550K, that has the quick release blocks at the rear but also has the central grease nipple. Failing that, drill a 5mm hole centrally underneath the swinging arm, tap it to 6mm and using a copper washer fit an angled grease nipple in there. Done that years ago, never had a worn bush again. Now I've fitted the 550K arm instead because it looks a neater job and has the more modern collar (no holes). I also fitted a roller bearing conversion by Tourax, you can only do that with the central nipple system, it will not work with the nipples on the end of the spindle due to it replacing the collar and that having no escape holes.
