Author Topic: Aligning the rear wheel on frame  (Read 14061 times)
Offline alexdecker
« on: April 07, 2024, 03:42:17 PM »
Hey all
What is the best method to align the rear wheel on the frame, if you don't have any special tools available? Obviously I can use the marks on the frame, but is there a way to dial it all the way in? I feel a little jitter in the pedal of my rear brake, and I think it might be because of poor alignment.
I aligned the rear wheel according to the marks on the frame. Then I finger tightened the nuts. I then activated the rear brake and while holding down the brake, I tightened the nuts down.
What do you guys do?
Re: Aligning the rear wheel on frame
« Reply #1 on: April 07, 2024, 03:46:26 PM »
Align the rear wheel with string and the front wheel
That's the best way
« Reply #2 on: April 07, 2024, 04:38:38 PM »
That's the best way
Presumably it must be special string that does not stretch?
Would a decent metal tape ruler work?
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #3 on: April 07, 2024, 04:58:29 PM »
You can do what the MOT man does - a long piece of straight, wide timber with a cut out for the stand, not forgetting the front wheel is narrower than the rear.  You can add a strip to the edge which contacts the front wheel - half the difference between the front and rear tyre widths.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #4 on: April 07, 2024, 05:01:27 PM »
Not really,
2 6ft straight edges would
The idea is you put it around the front wheel,,about 8in from the ground, then pull equally both sides to the rear wheel,
As the rear tyre is wider, the string should just touch the leading edge of the tyre,
Next you check the gap at the front tyre,
It's fairly easy to see if both sides are equal.
If not, adjust the rear wheel as necessary
« Reply #5 on: April 07, 2024, 05:57:31 PM »
The "jitter" is nothing to do with alignment but either oval or corroded drum, you dont say what bike it is, very frustrating and i dont care if its in the header, shouldnt need to read that!
Offline alexdecker
« Reply #6 on: April 07, 2024, 06:16:13 PM »
Sorry, it’s a CB550F2 from 1977!
« Reply #7 on: April 07, 2024, 06:34:12 PM »
Offline Seabeowner
« Reply #8 on: April 07, 2024, 06:49:11 PM »
Not really,
+1 to that.
That's the way I've always done it.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #9 on: April 07, 2024, 07:04:26 PM »
If they are new brake shoes they might just need some bedding in or is it worse than that?
« Reply #10 on: April 07, 2024, 07:10:24 PM »
The 500 has a reputation for cracking drum liners and it is very possible the 550 is following suit, take it apart and check the cast drum part for cracks and rust lifting, if so its either a different wheel or find somebody who can machine out the liner and shrink in a new one.
I know you dont have to mot it but it would be a fail if you did
Offline alexdecker
« Reply #11 on: April 07, 2024, 07:41:46 PM »
The inside doesn’t look cracked at all though. I have this picture.
« Reply #12 on: April 07, 2024, 08:04:09 PM »
That wheel has been relined alread mate and may not have been turned perfectly true or possibly pulled fractionally out of true when rim laced, it may bed in or may need a very light skim by somebody with a big enough lathe to get the complete wheel in
Online Laverda Dave
« Reply #13 on: April 07, 2024, 09:32:26 PM »
Try Terry at Stotfold Engineering, he's near Biggleswade.
I took my Triton front wheel to him because it was grabbing. Turned out the drum was slightly oval due to being pulled out of shape by the fitting of stainless spokes.
He has a lathe big enough to get a whole wheel in complete with tire. He also machined the brake shoes to match the drum.
http://www.stotfoldengineers.co.uk/motorcycle-restoration/
« Reply #14 on: April 07, 2024, 09:39:32 PM »
Alex, were are you based?
