Author Topic: CB360 Seat Pin / Bar Seat Hinge 77103-369-000  (Read 2780 times)
Offline Craizeehair
« on: June 03, 2024, 04:35:10 PM »
I’ve had this bike down to a bare frame and bagged and tagged everything meticulously but for the life of me, I can’t find this. Everything else is present and accounted for and I’ve seen it several times, I know it was here but it has disappeared, I’ve spent days going through EVERYTHING but it’s vanished!
If anyone has one they could sell or any suggestions where I might find one it would be hugely appreciated.
Greg
Offline Skoti
Re: CB360 Seat Pin / Bar Seat Hinge 77103-369-000
« Reply #1 on: June 03, 2024, 05:21:28 PM »
Looks like you could make one from a bit of steel rod or bolt sourced from your local engineering shop.
Was it 5 or maybe 6mm diameter?
Skoti
1976 Honda CB750F1
Offline Deano400
« Reply #2 on: June 03, 2024, 05:25:14 PM »
Offline Craizeehair
« Reply #3 on: June 03, 2024, 06:03:27 PM »
Not sure on the size, I keep holding off cos I’m convincing myself it will turn up but it’s a goner for sure.
Offline Craizeehair
« Reply #4 on: June 03, 2024, 06:06:03 PM »
Used but available at the moment.
https://honda4parts.nl/product_info.php?products_id=3139
Thanks for that, I did look but was drawing a blank. I’ll get it ordered.
Offline Craizeehair
« Reply #5 on: June 03, 2024, 06:09:38 PM »
Need to spend £135 minimum order :(
« Reply #6 on: June 03, 2024, 06:16:40 PM »
I am not familar with your model - does it have one long pin that fits through  both hinges?
Can you not fit two shorter ones?
Offline Craizeehair
« Reply #7 on: June 03, 2024, 06:27:21 PM »
Looks like it had to be one long pin Ted
« Reply #8 on: June 03, 2024, 06:33:08 PM »
This long screw type  is very strong they come  with a Hex head or a Cross head - they are used to fit double glazed doors etc.
Might be okay if you can match the diameter then shorten & thread, they are a hammer fix so the shaft is quite strong.
I bought this  one about 10 years ago from somewhere like B&Q - it came with a very deep plastic rawplug fitted.
They come in different lengths & screw diameters - might be good enough for a temporary fix?
Is this long enough?
Do you need the diameter of it?
PXL_20240603_173237946 by Macabe Thiele, on Flickr
« Last Edit: June 03, 2024, 06:43:14 PM by McCabe-Thiele (Ted) »
Offline Skoti
« Reply #9 on: June 03, 2024, 06:44:23 PM »
They're not going to do much business with £135 minimum order policy.
Does it say so on their web site, or do you have to put the item in the basket and go through all the address stuff and payments details first?
Skoti
1976 Honda CB750F1
Offline Craizeehair
« Reply #10 on: June 03, 2024, 06:48:04 PM »
I might have missed it on the website and not noticed it but it came up after I had it in the basket, opened an account etc, that’s when I found out that I needed to spend my extra £120+
Offline Craizeehair
« Reply #11 on: June 03, 2024, 06:49:44 PM »
That’s a decent idea Ted, I do have a few bits and pieces on the van that I might be able to utilise if all else fails.
« Reply #12 on: June 03, 2024, 06:52:43 PM »
The one in the photo is 4.99 mm diameter on my calipers.
Offline Skoti
« Reply #13 on: June 03, 2024, 06:58:43 PM »
Thanks for pointing this out.
Skoti
1976 Honda CB750F1
Offline Craizeehair
« Reply #14 on: June 03, 2024, 07:00:27 PM »
Thanks Ted, I’ll check next time I’m back on it.
