Author Topic: CB550 refurb  (Read 153969 times)
Re: CB550 refurb
« Reply #150 on: November 21, 2024, 10:34:33 PM »
Yes like the fish tank gravel idea. Plenty shell sand around the local shores here.
Re: CB550 refurb
« Reply #151 on: November 21, 2024, 10:48:10 PM »
I'd be thinking about plastic beads or similar.
Re: CB550 refurb
« Reply #152 on: December 05, 2024, 10:55:32 AM »
Feel as if I need my white gloves to handle these somehow! Great job once again Peter!
Offline Orcade-Ian
    • Older Vehicle Web
Re: CB550 refurb
« Reply #153 on: December 05, 2024, 03:03:05 PM »
Er, was this the bike you were just going to tidy up a bit??
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: CB550 refurb
« Reply #154 on: December 05, 2024, 05:29:04 PM »
Ian
😳😳🤭 yes Ian! The clocks just needed a bit of tidying.😂
Re: CB550 refurb
« Reply #155 on: December 05, 2024, 05:33:58 PM »
Lovely! 😁
Re: CB550 refurb
« Reply #156 on: December 16, 2024, 12:16:32 PM »
Less than impressed so far with this parts cleaner/polisher. Tried so far three different types of media and three hours of rumbling.
Re: CB550 refurb
« Reply #157 on: December 16, 2024, 03:37:37 PM »
Cement mixer with loads of hot soapy water with added degreaser for cleaning, add pea beach gravel for very, very stubborn shite.
Never tried the cement mixer for polishing, Graham always does the polishing on the polishing machine. He also uses the wheel with a wire disc thing for cleaning all the threads out of bolts and cleaning nooks and crannies out of parts and awkward corners prior to sending for BZP. Usually about 20kg at a time that are barrelled BZP'd.
Online Laverda Dave
Re: CB550 refurb
« Reply #158 on: December 16, 2024, 03:55:51 PM »
Just catching up on some posts that have slipped past me. Those clocks are fantastic, another great job from Peter.
Offline Moorey
Re: CB550 refurb
« Reply #159 on: December 16, 2024, 04:35:28 PM »
More likely 3days rather than 3hrs needed for those types of polishers.
Re: CB550 refurb
« Reply #160 on: December 16, 2024, 06:25:15 PM »
Maybe indeed Moorey! There’s lots of different types of media yet to try before I declare it not suitable for the type of work I had in mind for it. I’m prepared to persevere a bit.
Offline Moorey
Re: CB550 refurb
« Reply #161 on: December 16, 2024, 11:24:35 PM »
 They are commonly used in the restoration of Pinball machine metal parts as well and parts are usually in them for 3 or 4 days.
Offline AndyD
Re: CB550 refurb
« Reply #162 on: December 17, 2024, 11:52:04 AM »
I've had the larger version of the tumbler for a few years and it's certainly not a perfect answer but I have found it very good at cleaning up brackets and fixings if given enough time.
Also found that adding the tumbler liquid seems to help the process.
Seems to work brilliantly on flatter surfaces - brackets, large bolts, washers etc., less so on intricate smaller parts but that mat be down to the media type / size.
I've left them in for a good 6 or 8 hours and quite happy with the results - always dubious about leaving something running overnight but may give it a go one day when feeling brave.
Size of the media makes a big difference - I found that recessed bolt heads etc. weren't good but then got some much smaller cones and results were then much better - downside being they easily get stuck in any nuts or recesses etc.
Haven't tried many other types of media yet but I have got a bag of walnut shell for polishing and some fine glass blasting stuff which may be good for more aggressive work (but not great for the tumbler itself!).
Cheers,
Andy
Re: CB550 refurb
« Reply #163 on: December 18, 2024, 11:09:37 AM »
Good to know Andy! I am still experimenting with different media and times will post on here either way good or bad. I have been just following guidelines too from manufacturer. There are many different uses for these types of machines but they are probably not the number one choice for cleaning small parts. I thought I could be doing something else instead of dodging missiles from the old wire wheel! 🤣🤭
Re: CB550 refurb
« Reply #164 on: January 07, 2025, 10:24:30 AM »
Had a very short spell in the garage yesterday due to other commitments but managed to reunite engine and frame.
