Author Topic: Using the original Honda style 500 grease nipples?  (Read 6315 times)
« on: August 29, 2024, 01:50:02 PM »
I need to squeeze some grease into my swing arm shaft using the original style nipples.
Yes, had I thought it through I would have tapped out a thread and fitted the modern type.
Is there a specific end I can fit to my Sealy Grease gun that will work on this old presumably Japanese design or is it a case of holding the gun against the nipple and keep on pumping until I see grease appear somewhere?
« Last Edit: August 29, 2024, 02:05:11 PM by McCabe-Thiele (Ted) »
Offline Mike_Berkshire
Re: Using the original Honda style 500 grease nipples?
« Reply #1 on: August 29, 2024, 02:37:11 PM »
I don’t know of this helps Ted but I bought anew grease nipple for my 550 K2 from Julie, screwed it into the swinging arm using the original thread and used my new bought from Halfords grease gun. All seemed to fit and work ok
« Reply #2 on: August 29, 2024, 04:59:21 PM »
These are the nipples at the ends of the  swing arm shaft - there are no threads they are the original press fit type so they do not lock onto my grease gun.
« Reply #3 on: August 29, 2024, 05:04:28 PM »
Ted, if you push the gun tight into the nipple whilst pumping it you should eventualy see grease appear from the ends of the swingarm mate
« Reply #4 on: August 29, 2024, 05:33:13 PM »
I hope it will i'll persevere - so far grease has only escaped round the external edges instead - tbh it's not an expensive grease gun just a small Sealy one that uses a cartidge system so not a great volume but good pressure.
If I can't get it to work it might be a case of tapping out the right thread and fitting the screw type.
Bryan, do you happen to know what size Tap I need to fit the modern type screw in nipple?
« Last Edit: August 29, 2024, 05:40:47 PM by McCabe-Thiele (Ted) »
Offline SteveW
« Reply #5 on: August 29, 2024, 06:16:24 PM »
I bought M6 threaded nipples, so drilled and tapped to M6.
Worked perfectly.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #6 on: August 29, 2024, 06:19:25 PM »
I just buy M6 grease nipples then drill and tap M6x1 mate. Which is the most common M6.
« Reply #7 on: August 29, 2024, 06:26:46 PM »
Pretty sure I have an M6 tap so need what diameter drill bit will I need?
« Reply #8 on: August 29, 2024, 06:42:44 PM »
5mm or 13/64 Ted
« Reply #9 on: August 29, 2024, 06:50:00 PM »
Thanks Bryan that will be plan B.
« Reply #10 on: August 29, 2024, 08:49:11 PM »
If you remember the old oil pump guns where the tube went inside the body, thats what we had in the 70,s in one dealers
Offline Murf
« Reply #11 on: September 02, 2024, 11:51:17 PM »
Interesting thread (pun intended), as this is a job I will have to do soon, handy to know the original nipples are just a push fit.
« Reply #12 on: September 03, 2024, 12:12:04 AM »
Yes BUT  do not hit them on the end to fit, only hit on the shoulder with a correct sized tube. NOTE an 8mm deep socket WILL damage the end, tee shirt and video for that one
Offline Murf
« Reply #13 on: September 03, 2024, 09:38:08 PM »
Thanks, but what I mean was that I am going to take out the original nipples and replace with normal ones so I can just use a standard grease gun.
