Author Topic: Idiot Bulbs and Holders  (Read 15712 times)
Offline Mike_Berkshire
Re: Idiot Bulbs and Holders
« Reply #15 on: December 22, 2024, 12:45:01 PM »
« Reply #16 on: December 22, 2024, 02:34:36 PM »
One thing to add which i think has been mentioned is the bulbs, the common one has a torpedo shaped glass, is too long and will damage the jewel plastic or clock face.
The correct round bulb is available from Lucas and is a jag mk2 dash bulb, i have the number somewhere and will post it later
« Reply #17 on: December 22, 2024, 03:32:15 PM »
« Reply #18 on: December 22, 2024, 03:52:32 PM »
I used the Classic Led's for mine some  are only 0.5 W with good lumens, colours also available to cut down glare. I went for Green Instrument lights.
It's horses for courses, some of these little soldering irons are quite good, they take a while to fully heat up, as long as there is enough heat capacity to get the solder to flow properly between the wire and the fitting they work fine.
My Weller is an eary 100 W version,  you are not supposed to keep the trigger on full power for more than 5-10 seconds at a time. I tend to ignore this tbh. I don't do enough soldering to justify the later version that looks pretty handy if you can justify the cost.
My first ever soldering iron was the size of a coal fire poker, it took about 20 minutes to warm up, I think it was branded as Rawplug. It packed up after 25 years. https://www.ebay.co.uk/itm/235874490230
« Last Edit: December 22, 2024, 04:05:23 PM by McCabe-Thiele (Ted) »
« Reply #19 on: December 22, 2024, 04:24:59 PM »
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #20 on: December 22, 2024, 05:04:47 PM »
 I think Weller soldering irons are the best choice...picked up a PU-1D from eBay a number of years ago...excellent iron.
PS. Lead solder (60/40) with rosin flux core every time...the alloy solder is not very good.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #21 on: December 22, 2024, 05:19:07 PM »
Thanks Alan - Ill have a look out for one of those - where do you get the decent solder? I think that is my main issue TBH.
« Reply #22 on: December 22, 2024, 06:32:42 PM »
I buy mine from CPC Farnell but you need an account, if you want some i will happily buy and post on but thats double postage
« Reply #23 on: December 22, 2024, 07:44:10 PM »
As Brian says, you can buy the correct solder from Farnell online (no a/c required, check out as guest)
Current bikes:-
« Reply #24 on: December 22, 2024, 11:17:29 PM »
You can but if you have an account and want other stuff the shipping is cheaper, 1st leg that is!
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #25 on: December 24, 2024, 04:45:12 PM »
I bought the whole set with wires and bulbs for my 500/4 some years ago and worked well. Can’t remember where from but could have been the USA. If no luck a USA forum may well have a source.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline JezzaPeach
Offline Skoti
« Reply #27 on: January 05, 2025, 12:03:36 PM »
Here’s some mentioned earlier
https://www.vintagebike.fr/faisceau-de-tableau-de-bord-cb-500-750-four37581-323-000p-t
https://www.ebay.co.uk/itm/334039996105?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=VGLMpv-UTVy&sssrc=4429486&ssuid=hkXEB8tRRti&var=&widget_ver=artemis&media=COPY
The first link from vintagebike has the correct genuine Honda 3.4w bulbs fitted (as listed on his website).
The second link has standard off the shelf 4w bulbs fitted and will risk melting your console.
Skoti
1976 Honda CB750F1
« Reply #28 on: January 05, 2025, 12:52:59 PM »
Valid point concerning the second listing...the eBay listed item has been supplied with the low profile lamps for a number of years now..as attached picture.
The 4watt standard lamps (longer profile) have been fitted in my CB750 K4 console for 15+ years...no signs of heating.
Current bikes:-
