Author Topic: A missing part discovered again  (Read 3814 times)
Offline Athame57
    • SeaWitch Artist
« on: August 06, 2025, 08:19:05 PM »
Thanks to a post on CB400F Facebook group I've discovered another missing part on my bike.  :o  a spring at the pedal end of the rear brake rig, see pic. It is part number 46514377000
I've not noticed this in the seven years I've had the bike, nor have the numerous mechanics who have worked on her either. It begs the question, do I really need it? Your thoughts?
I brake for animals!
1978 CB400F2 named Elen.
Re: A missing part discovered again
« Reply #1 on: August 06, 2025, 08:26:57 PM »
Its fine without until the brake operating cam or the pedal shaft starts to get gummed up in their holes then the brake will drag
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: August 06, 2025, 08:43:28 PM »
Naff....  >:( I'd better get one then, DSS has them. I don't have a workshop so will fitting it myself be one of those jobs that's as bit a pain as a DIY tooth exraction?
« Reply #3 on: August 06, 2025, 09:32:56 PM »
Yes because you have to remove the pedal pivot shaft and that goes inwards and usually the swing arm is in the way.
First bit to fit on a rebuild is the rear brake pedal shaft with spring!
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: August 06, 2025, 10:06:45 PM »
Looks like a mechanics job again. If the swing arm is to come out I think I'll have the bushes changed at the same time, pre-emptive to them failing.
