Author Topic: brake bleed screw size?  (Read 8112 times)
Offline neat street
« on: September 27, 2025, 02:54:54 PM »
Hi all, I have just got a new bleed screw for my 500 front caliper and it is 7mm? it seems that this is `standard`? mine takes a 6mm. did honda make two different sizes of bleed screws?
thank you for your input.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Re: brake bleed screw size?
« Reply #1 on: September 27, 2025, 03:12:43 PM »
7mm is the standard size on 500/4. That's the only size I know of as standard, the 750/4's use 10mm.
Offline neat street
« Reply #2 on: September 27, 2025, 03:54:05 PM »
Thanks Nurse Julie :-) dont understand why mine is 6mm? thread pitch is the same
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
« Reply #3 on: September 27, 2025, 04:04:04 PM »
I've known owners to helicoil a knackered thread and fit an insert down to 6mm as that was the size bleed nipple they had laying about at the time🙄🙄🙄.
The 350/400/500/550 all use the 7mm.
« Last Edit: September 27, 2025, 04:05:48 PM by Nurse Julie »
« Reply #4 on: September 28, 2025, 12:02:28 AM »
Is it a pattern caliper with a different bleed screw to a standard one?
Offline neat street
« Reply #5 on: September 29, 2025, 08:10:49 AM »
From what I can see, its standard??? thank you for your replies, guess someone has messed around with it at some time in its life  :)
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Offline florence
« Reply #6 on: September 29, 2025, 10:19:00 AM »
the best option for repair I have seen is a stainless steel banjo bolt with bleed nipple in the top.  (You leave the old broken nipple in place) I have this arrangement on mine and it seems to make bleeding easier.  It's been there for 30 years through rain, shine and salt and still works perfectly.
Offline neat street
« Reply #7 on: September 29, 2025, 01:36:19 PM »
problem kinda solved... Filed the top of the bleed screw hole and yes, someone had put in a helicoil and also damaged the hole for the bleed nipple to work, solution throw it away and buy a replacement... thank you all for your help
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
« Reply #8 on: September 29, 2025, 02:37:12 PM »
Look at mmatti on amazon, you get complete thing with pads and mounting bracket for what i think is a reasonable price
Offline neat street
« Reply #9 on: September 29, 2025, 04:17:05 PM »
Thanks Brian, yes thats a bargain :-)
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
