Paint code
Topic: Paint code (Read 4274 times)
Outrunner
Newbie
Paint code
November 05, 2025, 08:22:10 PM »
Does anyone know a match for the black on the outer bezel/top case of the speedo/rev counter please?
McCabe-Thiele (Ted)
Re: Paint code
November 05, 2025, 09:01:57 PM »
My understanding is back then they did not have Paint Codes or RAL numbers.
Someone here will know the closest you can get, I used Peter Horton (kent400) who restored my clocks
Link to my full restoration
Gromitdog
SOHC Member
Re: Paint code
November 06, 2025, 10:12:08 AM »
Peter Horton is the guy you need he did my clocks and made a lovely job well worth the money if you message me I pass on his address
Best Regards
Nigel
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Murf
SOHC Expert
Re: Paint code
November 11, 2025, 11:27:40 PM »
Hi
Well I can’t give you a paint code, but can tell you that it is a satin black and post a photo of a genuine NOS tacho 37240-323-774 I have which may help. It’s a ND one and has been in a box all its life so is not faded.
Oddjob
Re: Paint code
November 12, 2025, 09:49:33 AM »
Just some advice.
Rattle can spray paint gives a good result BUT it’s easily scratched and marked.
Powder coating can seem like a good idea but with the coat being thicker it can make assembling the clock afterwards nigh on impossible.
Ceramic coating gives a thin coating that is thin enough not to cause problems with assembly but it’s also extremely durable and quite hard to mark. It’s also fairly resistant to solvents like petrol and brake fluid.
Paint code
