Author Topic: Front Brake Disc - Torque Settings for Bolts  (Read 20989 times)
Offline element137
« on: April 21, 2026, 07:29:53 AM »
Hi everyone , I have had a look at the Haynes manual, but cant see the torque values for the four bolts/nuts that pass through the  front wheel hub and front brake discs, also assume these are thread locked  - as standard , there is no retaining tab washers ? ( as per the rear sprocket nuts )
Re: Front Brake Disc - Torque Settings for Bolts
« Reply #1 on: April 21, 2026, 08:46:39 AM »
Might be worth checking the downloadable Honda workshop manual on this site.
My 400 has lock washers, a paired arrangement iirc.
« Last Edit: April 21, 2026, 08:57:52 AM by McCabe-Thiele (Ted) »
Offline exvalvesetdabbler
« Reply #2 on: April 21, 2026, 09:40:48 AM »
Try this,
Regards
Dave
Offline element137
« Reply #3 on: April 21, 2026, 11:53:52 AM »
Thanks - I could not find it in the workshop manual - and I have seen conflicted images reference the lock tab washers - some with - some without ?- not sure if it changed on model years ?
Offline element137
« Reply #4 on: April 21, 2026, 11:54:24 AM »
Offline element137
« Reply #5 on: April 21, 2026, 11:56:36 AM »
Actually looking at that service bulletin, it looks like CB350 had the lock tabs - 400 not fitted ?
« Reply #6 on: April 21, 2026, 01:10:55 PM »
Might be worth checking the 400 parts book.🤔
Online taysidedragon
« Reply #7 on: April 21, 2026, 02:43:02 PM »
Correct, 400f uses flanged locknuts instead.
« Reply #8 on: April 21, 2026, 06:04:01 PM »
Considering the damage a bolt would do I’d be inclined to fit the tab washers myself or failing that some nyloc nuts
« Reply #9 on: April 21, 2026, 06:51:11 PM »
You would need a longer bolt for extra tab washers or for a nyloc to have something to grip
Dave
« Reply #10 on: April 21, 2026, 07:06:45 PM »
Without the washer or flange in this case the existing bolt should be ok.
Offline TrickyMicky
« Reply #11 on: April 21, 2026, 11:09:54 PM »
Whilst I agree that they are not cheap, for such a safety critical part, the genuine flange nuts are available.
« Reply #12 on: April 21, 2026, 11:22:36 PM »
Have they got the serrated flange Mick? If so loads available in stainless steel
Offline Skoti
« Reply #13 on: April 22, 2026, 07:06:05 AM »
Nyloc nuts not really suitable for high temp use such as brake discs, metal lock nuts are more appropriate.
Better safe than sorry.
Skoti
1976 Honda CB750F1
Offline TrickyMicky
« Reply #14 on: April 22, 2026, 08:10:43 AM »
I'm only going by the pics on the DSS site, which shows them as being smooth, but, listed as genuine parts.
