Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
If you're fitting the OEM ones like I stock, they should be pretty easy to fit on George.
I used Wendy's Hair spray to make sure they stay in place, particularly for the throttle side.I used Meths to clean the bars / throttle tube.
Gel hand sanitizer works for me (from our much loved COVID days)Wipe it on the bar or inside the grip, they slide on easy then as the alcohol evaporates, the residual tack will keep the grips firmly in place.
https://youtube.com/shorts/uvCpcT4z8Tk?is=85Fn2Pv6-pYZMLXUThis is the tie wrap method I used and thought it was very straight forward.
Unless the video is Ai faked.
