Author Topic: CB500K four 1975 request for photo of alternator wiring and starter cable route  (Read 346 times)
Offline martin_uk
I bought this bike as a project disassembled. ::)
Had a bit of a break, but getting back to it.
Finishing reassembling the engine and have looked at images in manual but not completely covered.
I have worked out the fitment of starter cable into the holder/grommet that sits in casing recess.
Images show the starter cable above the alternator wires on the clip that forms part of neutral switch holder.
Images also show alternator, oil pressure switch and neutral wiring feeding through recess in upper crank case and starter cable running under the top rear engine mount.
I cant see if the alternator wires have a clip to secure to engine close to exit from alternator cover ?
I also cant fully see how the starter cable runs and is supported, where it separates from running along side the alternator loom ?
If anyone has a photo covering this, much appreciated. :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline LeCromb
Hi Martin,
Not sure if these pictures will help, but I am just looking at exactly the same area on my UK '76 CB550F - I don't know if the wires are the same as your model, but guess they might be - if not, I'm sure others here will advise.  No sign of any clip/support for the alternator wires as they leave the cover.
Then they go into a small shaped rubber grommet thing moulded around the wires to hold them at the front of the chain cover casing, which I think you know, and starter cable is above this.  Starter cable also above alternator wires under metal clip.  Once out the top rear of the chain cover casing area, (I have starter cable over the alternator wires here, and I don't know if this is correct either), starter cable just loops up behind the frame to the starter solenoid.
(Note that the green/white alternator wires are not connected in the photos, due to testing for no 12v at the white wire, but that's another story....)
Good luck!
1976 Honda CB550F
1990 Kawasaki GPZ900R
1956 Ariel VH500
Offline mickwinf
the starter cable should go under the engine mount bolt according to the manual. also i think that it should go behind the electrics plate to solenoid.
Offline mickwinf
looking at my own picture i notice the starter cable should run over the clip at neutral switch, also my bike had some extra wire connectors at that point, since rewired.
Offline LeCromb
Hi mickwinf, that does make a certain amount of sense, about the cable going behind the electrics plate, (looks a bit odd in front), but I think I just put it back as it was, and over the years perhaps these things get moved/changed...  if the starter cable is meant to go under the engine bolt it might explain why the two are a bit tight in that gap!
1976 Honda CB550F
1956 Ariel VH500
Offline martin_uk
Thanks guys.
Appreciate you showing these.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
