Author Topic: front mudguard line up problem  (Read 4966 times)
Online neat street
« on: March 08, 2014, 11:58:52 AM »
Hi All
The whole bike is now together, but have a problem with the bracket from the mudguard rubbing on the nearside part of the tyre, can anyone give any clues as to whats wrong please,
Many thanks
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline LesterPiglet
  • 1977 CB550F2
Re: front mudguard line up problem
« Reply #1 on: March 08, 2014, 01:10:23 PM »
Guard on backwards? Give us a wider picture.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
« Reply #2 on: March 08, 2014, 01:25:07 PM »
... and show us the mounting to the caliper bracket...
Online neat street
« Reply #3 on: March 08, 2014, 01:48:32 PM »
Thanks for your replies, more pics below, from both sides
Many thanks
John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Offline MarkCR750
« Reply #4 on: March 08, 2014, 02:58:23 PM »
It' a bit hard to tell from the photo's but can the brackets be bent so that the mudguard sits closer to the tyre, the bend would then give greater clearance between the bracket and the tyre, at present the bracket looks like A, can you joggle it to look like B ?. (apologies photo is upside down)
« Last Edit: March 08, 2014, 03:01:06 PM by MarkCR750 »
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
  • 1977 CB550F2
« Reply #5 on: March 08, 2014, 03:02:15 PM »
What size tyre? Is it actually rubbing? If it doesn't rub don't worry about it as the tyre will only grow in height, not width when its rotating.
Is your brake line pushing against the bracket?
And give us a straight on shot of the wheel/guard.
« Reply #6 on: March 08, 2014, 07:02:05 PM »
Hi,
Just checked mine on the brake side you should be able to get your little FINGER down between the guard and the tyre.If you cant you either have a warped guard or your tyre is too dare I say in this day too fat.
Bitsa
« Last Edit: March 09, 2014, 09:30:50 AM by Bitsa »
  • 1977 CB550F2
« Reply #7 on: March 08, 2014, 07:36:08 PM »
Your little what? There's no way mine is fitting in there.   ;D
Online neat street
« Reply #8 on: March 09, 2014, 02:18:17 PM »
Thanks for all your help, the tyre size is 100/90/19, so this should not be a problem? my only thought is that when the mudguard went to  chrome (in three bits, top bracket, bottom stay, and mudguard), they bent it somehow?
Any other ideas would be appreciated. many thanks again
John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
  • 1977 CB550F2
« Reply #9 on: March 09, 2014, 03:20:27 PM »
100/90x19 is the same as mine so there shouldn't be a problem.
Offline neilb
  • marine engineer
« Reply #10 on: March 09, 2014, 05:17:04 PM »
bend it back
Laverda Mirage
Suzuki 1200 Bandit
Ducati 848
