Author Topic: Starting the engine  (Read 56233 times)
Re: Starting the engine
« Reply #135 on: February 01, 2015, 08:30:23 PM »
Mick
Yeah got one of those but got pissed off with keep looking down at it.Its ok here to a degree but in the UK dare you look away from the traffic? :o
Ralph
Offline Green1
« Reply #136 on: February 01, 2015, 08:46:04 PM »
You don't have to look at it all the time the same goes for your speedo and rev counter. ;)
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #137 on: February 02, 2015, 09:47:28 AM »
Mick point taken but I love gadets never look at Revcounter only the speedo and thats when I see coppers or radars.
Adored the Humber cars dashboard all those years ago loads of dials ;)
Ralph
Offline El__burro
« Reply #138 on: February 04, 2015, 01:36:17 PM »
Back to work. I am trying to make the oil pressure switch come light go off. I have added 3 litres of brand new oil and as johnWebley suggest I am kicking the pedal until the light goes off. How long will it take in normal circumstances. Bear in mind that I drained the old oil already.
El__Burro
Offline LesterPiglet
  • 1977 CB550F2
« Reply #139 on: February 04, 2015, 01:54:14 PM »
Fire some oil under the tappet covers before you turn it over.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline tom400f
« Reply #140 on: February 04, 2015, 01:58:10 PM »
Last time I did mine I was changing the filter as well and I pumped out as much old oil as possible (via the oil ways in the filter housing face) by kicking it over. Under those circumstances it took the proverbial "ages" to build oil pressure on the starter/kick start.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #141 on: February 04, 2015, 03:32:56 PM »
El__Burro
 you are doing great,I suggest you remove the plugs,and as you can kick it over,it seems ok,so now use the starter,
 just spin it for about 5 seconds at a time,so the starter doesn't over heat,
good luck !!!
« Reply #142 on: February 04, 2015, 03:34:14 PM »
Yup I go with that
Bitsa
Offline El__burro
« Reply #143 on: February 04, 2015, 08:02:32 PM »
« Reply #144 on: February 04, 2015, 08:05:48 PM »
Excellant but was that white or blue smoke?Make sure you watch the oil level
Bitsa
Offline El__burro
« Reply #145 on: February 04, 2015, 08:06:29 PM »
Ooooooh yeah!   ;D
After many kicks the oil pressure light went off.
Then the magic happened.
Just wanted to share with you the first time it roared and what a ROAR.
For sure it needs some adjustments to be fully satisfied but my ambition was to start the engine and hear its roar.
Mission accomplished.
Thank you
el__burro
;D
Offline El__burro
« Reply #146 on: February 04, 2015, 08:08:06 PM »
The smoke was white,  i have to say that the carbs are not fitted properly.
« Reply #147 on: February 04, 2015, 08:41:19 PM »
don't worry to much about the smoke,it will be burning spare oil from the re-assembly,and this time of year there will be
lots of condensation /steam as the exhaust cools in the pipes
« Reply #148 on: February 06, 2015, 07:19:44 PM »
Agreed white better than BLUE
Bitsa
