Author Topic: Rear axle setup help  (Read 13098 times)
Offline JustcallmeMrT
« on: June 07, 2015, 07:20:44 PM »
Hi all,
I'm trying to fit the rear wheel as per the diagrams on cmsnl, it looks like I'm missing some spacers or something.  I've already added a spacer on the left, and two on the right just to give me enough thread on the axle bolt to tighten things down, and there's still space in each chain adjuster.  This can't be right - where have I screwed this up?
Re: Rear axle setup help
« Reply #1 on: June 07, 2015, 07:37:21 PM »
Can't understand why so many washers on the spindle ? Can not see from the picture but are they the right adjusters ?
« Reply #2 on: June 07, 2015, 08:12:23 PM »
I put the washers on so that I wouldn't run out of thread on the axle, seems like it's too long?
« Reply #3 on: June 07, 2015, 08:33:00 PM »
Was this wheel fitted to the bike when you got it, or was it loose in a box of bits? Somethimg looks amiss on the sprocket side of the wheel. Did you replace the wheel bearings? if so, are you sure you put the spacer between the bearings back? (saw that on my CB175 when I bought it years ago)
Offline corromant
« Reply #4 on: June 07, 2015, 08:45:24 PM »
Bit new at this, is this on a 500? If so the swinging arm looks wrong from the exploded diagrams that I have.
Probably talking coblers.
Born again SOHC owner
« Reply #5 on: June 07, 2015, 08:51:43 PM »
 looking at the picks,all the spacers seem in place,the only difference to mine,is the nut is on the drive side,
may be the swing arm is wrong,how does the chain line up?when the sprocket is close to the l/h side,is the chain aligned??
Offline corromant
« Reply #6 on: June 07, 2015, 09:04:16 PM »
Don't know how to post a picture, but that definitely looks like the wrong swinging arm. The slots for the axle should have an open end with a retaining block bolted in to close the slot, it should also be thicker which would explain the gaps that you have.
« Last Edit: June 07, 2015, 09:08:24 PM by corromant »
« Reply #7 on: June 07, 2015, 09:29:20 PM »
I cant remember if yours is a 500 or 550 Mr T. I have just looked at the swing arm on my 550 K3 and the slots for the spindle are closed in on mine.
« Reply #8 on: June 07, 2015, 09:47:21 PM »
The swing arm is 550F1 or F2  ;)
Offline corromant
« Reply #9 on: June 07, 2015, 09:53:48 PM »
Perhaps a jumble of 500/550 bits?
« Reply #10 on: June 07, 2015, 09:57:38 PM »
And your 400 had a wobbly rear end  ;D ;D ;D
« Reply #11 on: June 07, 2015, 10:17:12 PM »
[/quote
Just concentrate on Mr T's back end thank you Trigger 😃😃😃😃😃😃😃
Offline Norniron
« Reply #12 on: June 07, 2015, 10:26:23 PM »
My F2 rear
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #13 on: June 07, 2015, 11:48:24 PM »
My F2 rear
That top pick of the drive side on your bike seems to show a spacer I don't have.
« Reply #14 on: June 08, 2015, 09:52:29 AM »
The brake plate, spacers and collars are different on a 500 with removable ends in the swing arm to a 550 with the closed end swing arm. Can't remember exactly what and where but what you need to do is get the wheels in line the add or make spacers to fit the gaps, may even need a 550 spindle
If you have the time check which part numbers are different 500 to 550F on the diagram and that will tell you which bits are different
