Author Topic: Fork advice please  (Read 11002 times)
Offline Mike on a bike
Fork advice please
« on: June 28, 2015, 08:21:49 PM »
I need a lower fork leg and found this on the bay of theives.
It has an obvious crack at the top of the leg, so how important would this be as to the actual function of the forks/bearings etc. I can get it welded but would seek your advice first as I know sweet FA about these things.
http://www.ebay.co.uk/itm/331544353868?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'm not a complete idiot.....some parts are still missing.
Offline haynes66
Re: Fork advice please
« Reply #1 on: June 28, 2015, 08:30:40 PM »
never, ever use anything that has been damaged on a critical item, which the fork is. there may well be other fractures not visible which could prove fatal. keep searching!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline martin_uk
« Reply #2 on: June 29, 2015, 10:33:25 AM »
+1, you have to ask yourself, why did it crack? Would you want to risk?  It may be bent as well.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #3 on: June 29, 2015, 07:50:58 PM »
Thanks guys, you have just confirmed what I was thinking. Maybe I was getting a bit desperate!  :-[
Offline ginger_jim
  • Anyone for a Guinness?
« Reply #4 on: July 01, 2015, 11:40:32 AM »
I have some fork legs you can have cheap - they have new seals in them too  ;D
Offline ginger_jim
« Reply #5 on: July 01, 2015, 03:48:24 PM »
Think they might be later than the ones youre after looking at the ebay page.
« Reply #6 on: July 02, 2015, 10:47:59 PM »
Thanks for that GJ, do you know if they would be compatible with my earlier forks?
« Reply #7 on: July 03, 2015, 08:26:15 AM »
Will probably fit and seal OK but the brake caliper brakets and calipers are different
« Reply #8 on: July 03, 2015, 10:27:46 PM »
GJ, just out of curiosity what are you looking for in the gold coin department? The brakes are not a problem as some dickwad has bastardised mine hence the search for a new lower.
Offline ginger_jim
« Reply #9 on: July 06, 2015, 10:36:59 AM »
Hi Mike...£20 posted?  Basically just trying to recoup what I paid for them.
Offline Phil Ward (RIP)
« Reply #10 on: July 06, 2015, 08:25:02 PM »
I would check on CSML for compatability of the internals (using their schematic diagrams) because from memory (when I was sourcing bits for my original basket case), the lower internals are different so if you're using internals from the earlier (upto early k2) they may not fit - worth a check
« Reply #11 on: July 07, 2015, 08:18:31 PM »
GJ, I might take you up on that. Do you know what year they are? I shall do some homework on that.
Phil, pardon my ignorance but what/who is CSML?
« Reply #12 on: July 07, 2015, 09:39:33 PM »
Mike
Its a Dutch 'Dave Silver' but it has all the parts schematics - Here's the link - http://www.cmsnl.com/honda-cb750k2-four-european-direct-sales_model14369/partslist/
Offline ginger_jim
« Reply #13 on: July 09, 2015, 08:06:19 AM »
Hi Mike, TBH I don't know  :D
I bought them from Bitsa on the off-chance that I could use the fork tubes which luckily I was able to use with the standard bottoms.  Only difference is that the tubes were about 7mm shorter than standard so the old girl should steer a bit quicker, not that ive noticed any difference.
Let me know if you need any more photos.
« Reply #14 on: July 09, 2015, 08:59:31 AM »
I think that even if the internals vary the bottom allen screw that holds it together is the same so they should fit, you need to use the internals that go with the steel tubes to get the lengths correct
