CB750
Cylinder head
Topic: Cylinder head (Read 10412 times)
Coppertop1234
SOHC Expert
As long as the wife is happy
Cylinder head
August 31, 2015, 09:53:53 AM »
Project 2 (1978 F1) has issues with the head so we are looking for a replacement top end.
I have seen an F2 head on eBay in UK and think it would be a straight exchange?
Any advice please
Keith Snr
Last Edit: August 31, 2015, 10:13:21 AM by Coppertop1234
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650 Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1 Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream Restoration
1977 CB400/4 - The last one - Restoration
hairygit
Re: Cylinder head
August 31, 2015, 10:06:04 AM »
Project 2 is an F1? An F2 head can be made to fit, but it's a lot of hassle to keep it oiltight due to mods to the lubrication and oilways/return passages in the head, and are notorious for rapid valve/guide failiure, and very expensive to source replacement. Far better to look for the correct head, also shared with the 750K7. I understand that earlier K heads will also fit, but you'll need to get advice from Bryan or Trigger as to what's involved
Spitfire
Re: Cylinder head
August 31, 2015, 02:02:56 PM »
I may be wrong but if I remember correctly the F2 has domed pistons and larger volume hemispheres in the cylinder head so you will be lowering the compression, here's some info from the US site,
http://forums.sohc4.net/index.php/topic,99165.msg1105940.html
There is probably more information over there.
royhall
Keep biking I'm not quite bankrupt yet
Re: Cylinder head
August 31, 2015, 07:15:34 PM »
Most definitely not the same. The F2 head is unique to the F2, bigger valves being the biggest difference. Don't think it would fit either, dowels are possibly different.
Last Edit: August 31, 2015, 07:23:52 PM by royhall
Trigger
Engines built on reputation, not advertising.
Re: Cylinder head
September 01, 2015, 08:44:03 AM »
+1 with Roy on the F2 head, will be a nightmare to get it right. Some of the F1's had domed pistons, but even that head is not a straight swap.
Coppertop1234
SOHC Expert
Re: Cylinder head
September 01, 2015, 11:44:38 AM »
So the F2 head is out of the running - Thanks for info
Will the K6/7 series be a possible replacement.
Seen some in USA, but expensive when postage and customs have had there bite of the cherry
I am struggling to find a 1976 F1 in decent condition, has anyone got one they would wish to part with?
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Re: Cylinder head
September 01, 2015, 12:12:50 PM »
Not sure K7 is different. I had one but I gave it way yonks ago to someone on here.
Think the K6 would be OK though
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
hairygit
Re: Cylinder head
September 01, 2015, 01:41:55 PM »
K7 will fit, the K7 used the F1 engine, but fitted with those awful carbs similar to the F2
captaink
Old racers never die. ' they just go faster '
SOHC Expert
Re: Cylinder head
September 01, 2015, 04:47:47 PM »
Reference the comment valve guide failure on f2s. As a point of interest, I have just ordered new cast iron APE f2 valve guides in the UK for under £70 the set. In stock.
Found a supplier...Suzuki performance spares. They have a website and are Honda also.
Last Edit: September 01, 2015, 04:51:02 PM by captaink
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International 1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
bytio
SOHC Associate
Re: Cylinder head
September 01, 2015, 05:40:50 PM »
I can see the bronze guides there, but not the cast iron ones, do you have a link?
captaink
SOHC Expert
Re: Cylinder head
Reply #10 on:
September 01, 2015, 06:12:08 PM »
i think the guys name is Nick. They may not be listed but he has them,
I confirmed there f2, he seems quite knowledgable .
The bigger f2 valves I have ordered from him are coming from the USA and are kibblewhite and will be about 2-3 weeks although double the cost of other valves.
Springs are also in stock.
I will most likely order the big bore kit from him at £ 495 as it's also in stock
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
royhall
Re: Cylinder head
Reply #11 on:
September 01, 2015, 06:18:50 PM »
Got my F2 Kibblewhite valves from CycleX in the States. Good price and fast delivery. I'm told the original guides are a good replacement as they were changed later on for harder items that wear less. As they kept the same part number, I believe it's called a delta change part?
Sent from my GT-I9305 using Tapatalk
Coppertop1234
SOHC Expert
Re: Cylinder head
Reply #12 on:
September 02, 2015, 03:36:55 PM »
Found this one in USA seems to be correct 1 for a 1977 CB750 F1 ?
http://www.ebay.co.uk/itm/77-HONDA-CB750-SOHC-CB-750-K-HM272B-ENGINE-CYLINDER-HEAD-/231635611814?hash=item35ee8ef0a6
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
hairygit
Re: Cylinder head
Reply #13 on:
September 02, 2015, 04:11:54 PM »
Ouch on the postage,vand don't forget george osborne will want his cut (whatever import duty it attracts, plus 20% v.a.t. on the purchase price, postage and import duty!) plus royal snail adding at least £12.00 for acting as tax collectors!
Coppertop1234
SOHC Expert
Re: Cylinder head
Reply #14 on:
September 03, 2015, 06:58:13 AM »
Found 1 in Uk but its from a 73 so early K series unsure if it would be compatible or
http://www.ebay.co.uk/itm/321466019903?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Better price but will it fit a 77 F1?
Last Edit: September 03, 2015, 08:09:41 AM by Coppertop1234
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
CB750
Cylinder head
