SOHC.co.uk Forums => Project Board => Topic started by: DomP on August 10, 2023, 08:55:03 PM
Title: Doms CB550F1 project
Post by: DomP on August 10, 2023, 08:55:03 PM
I decided I needed a CB550 in my like after completing (nearly) my XS650B restoration.  I found a UK 1976 cb550f1 on 32k and in relatively good condition with very little apparent rust or corrosion, it was last started in 2017 but still turns over so fingers crossed a service and strip and clean of the carbs, new plugs will get it running.  I've bought a compression tester so I can find out what kind of health the engine is in and will stick my inspection camera down the plug holes to see what it all looks like in there.
So far I have discover a few good and few not so good things.
Good-
The frame must have been painted or powder coated at one point as its far too clean bar a few knocks.  A previous owner has gone over it replacing all engine cover fastenings with stainless cap heads.
Not so good-
The gear lever looks to be from another bike, it's been over clamped in an attempt to gain a grip on the shifter splines which are a little bit chewed up.  All float bowl screws are chewed up and are a mix of length and head type, possibly the worst thing I've encountered so far is the rear wheel.  I'd noticed it was very hard to push around so stripped the rear wheel out, the hub has been dinked on the edges by a hammer or something so it was catching on the drum plate.  When I removed the plate from the hub I found very uneven wear on the shoes and lining which has also cracked in several places, new hub or a replacement lining needed.
Title: Re: Doms CB550F1 project
Post by: Oddjob on August 10, 2023, 11:57:42 PM
Good luck finding a new hub or a second hand hub that isn't cracked. However you can get the hub relined with the brake liner out of a Morris Minor I believe. Search the forum for links to who does that type of work, one in lower Wales IIRC.
Sounds like your going to need a new gear selector shaft, I have a couple spare if you do. Also had a gear lever but I've sold it recently. You can find them second hand but the chromes usually crap.
I also have 3 spare carbs off the 550, 069a carbs are standard on that model. I have 2, 3 and 4 cylinders. Not particularly for sale unless you're really desperate, you can heli-coil those threads but it's a tricky job..
Post by: Trigger on August 11, 2023, 08:56:16 AM
Good-
Not so good-
All sounds normal to me for a 45+ year old bike that has had a previous owners tinkering    ;)
Post by: DomP on August 11, 2023, 01:37:51 PM
Thanks Oddjob, I've had a look and got a few leads to chase up regarding the brake lining, I think the carbs are very much salvageable with an m4? Helicoil.
Yes I think so too Trigger, nothing insurmountable...so far!  Is it you that is able to re-line hub brake linings?
Post by: Oddjob on August 11, 2023, 01:51:56 PM
Yeah M4 helicoil, you'll find the insert is about 2 threads too long, maybe fit one and see and then trim the others before fitting based on what you find when you test fit the first one.
Ignore the screw sizes listed by Honda for the bowls and the tops, the float bowls are too long, the tops are too short So the top ones strip out because there are too little threads engaging and the bottom strip out because the threads come out of the other side of the casting, then they corrode and when you remove them they strip the thread out of the casting as that corrosion gets pulled through or they damage it so much it strips out when you try and refit the screw. Fit slightly longer screws in the tops and smaller ones in the float bowls or trim the existing ones.
There are stainless steel replacements readily available as are new JIS screws, they won't rust and petrol doesn't bother them. Don't fit socket bolts or allen keyed IMO, they can exert too much force and strip out threads.
Post by: Trigger on August 11, 2023, 06:43:11 PM
If you are going to buy a helicoil kit, V-coil are suitable for rolled threads  ;)
And the carbs do not have enough meat on them for a  Time insert  ::)
Post by: Trigger on August 11, 2023, 07:39:30 PM
I did hub lining but, have now sold the lathe. Near on imposable to find someone with a big enough lathe to take a full wheel so, a full strip is required.
Not a cheap job, the donor Honda brake drum have shot up in price and a lot of work involved.
Post by: Oddjob on August 11, 2023, 07:57:52 PM
I've done loads of inserts in carb bodies and none have ever failed  ;)
Post by: Trigger on August 12, 2023, 05:36:45 PM
On 69a's. It does not have enough alloy for the collar with a time insert  ;)
Post by: DomP on August 12, 2023, 09:24:00 PM
I'm going to order an m4 helicoil kit off ebay, I've used them a few times before so I'm sure it will work on the carb body.  Just to confirm, those are m4 lower bolts (×16) and m5 upper bolts (×8)
I've found a bit more bodgery today, not only have the carb bodies been rattle canned in black with the bowls off but one has been butchered and had the jet JB Welded (up- see pics) although ive managed to pick it apart and removd the mangled jet.  That same body is missing the flat spring steel jet retaining spring, are they available separately?
Post by: Bryanj on August 12, 2023, 09:35:45 PM
I have ordered some from 4 into 1 in the us but they come in sets, i saved a bit by ordering via a us mate, if you do order and need one urgently i could lend you one
Post by: DomP on August 12, 2023, 09:58:43 PM
Thanks Brian!  However I'm wondering if I need a complete new body looking at the jet seating area, what do you think?
Post by: Bryanj on August 12, 2023, 10:16:39 PM
If the O ring fits tight it will work OK, carb sets and bodies are starting to get scarcer, a complete set of 500 or 550 of a different number will be ok if rejetted but dubious about fitting one odd carb of a different number, i have a few odd bits hanging about and will look if you give me carb number but it wont be quick and cant be sure what i have
Post by: Trigger on August 12, 2023, 11:47:22 PM
looks like the Emulsion tube is all mushed up. Give the carbs a total strip and assess what you need  ;)
Post by: Trigger on August 12, 2023, 11:55:02 PM
A set is on ebay but, i would ask the seller to send pictures with the float bowls removed >>> https://www.ebay.co.uk/itm/314768758353?epid=10028018716&hash=item4949ae1651:g:71EAAOSwtHRk2AFv&amdata=enc%3AAQAIAAAA0G%2BoGv80GLmU%2BX91MyCkAlV328khKGpRY7WxBNTHfLk3aexNvW%2Bz6uUiZeSY%2FWVllZk7ndskp1ZwRg1D5gUUlRTcSFS5ZH2zLejxTY6F69%2F8scIUYaJh4TU%2FCwQ%2FKwaIHwMXMg78CBh3LRT14pDC%2F%2Bs9KH7Eni2TiVWPDXPmTAMDomwsOapFyy6DT7FzcgppxH3Ka1exZT7n5sF%2BeWZ5nYpnZq8q6pa2We7K1Wt5QVe3L%2FW02G485LX8pMWKYIIDfD1HSMALb6m8D7Ht6Ncn6go%3D%7Ctkp%3ABk9SR86r2L69Yg
Post by: DomP on August 13, 2023, 07:11:00 AM
Yes you're correct Trigger, looks like they've tried to drift the emulsion tube out...rather unsuccessfully!
It's no.4 carb I need but having all the spares might come in handy, I didn't expect this to be plain sailing, twice as many carbs as my xs😆
Post by: DomP on August 13, 2023, 07:13:23 AM
I thought the keihin 069a were a more commonly used carb? Barely any or their parts on Ebay
Post by: Trigger on August 13, 2023, 07:17:06 AM
You drift the tube out from the other end, needle side  ;) If it was plain sailing, you would be bored by now  ::) Having a spare set usually works out cheaper in the long run.
Post by: Trigger on August 13, 2023, 07:19:57 AM
The earlier carbs are more available from imported bike being broken for spares  ;)
Post by: DomP on August 13, 2023, 08:05:24 AM
True, plenty to keep my occupied this winter I think.  A full spare set in decent condition could be a godsend actually, I'll message the ebay link you sent me to check their condition under the bowls.  Thanks for your help too!
Post by: Trigger on August 13, 2023, 08:50:33 AM
I had a shed load of carb body's that i cleared out last year. Julie put them on ebay and sold all within a month.
Most owners damage (Snap off ) the float pin towers trying to get the pin out. I have always found that if, they are well stuck in. It is easier to run a thin blade down the side of the towers and cut through the brass pin. Cheaper to replace a in than a carb body  ;)
Hope you get a result .
Post by: DomP on August 13, 2023, 02:40:38 PM
Amazingly the Ebay seller of those carbs is unwilling take the bowls off to enable me to check the condition.
Post by: McCabe-Thiele (Ted) on August 13, 2023, 03:28:08 PM
That might be because he knows they are not very good inside.
Post by: Nurse Julie on August 13, 2023, 06:47:48 PM
Well, that's a poor show, they probably have no internals in them 😂😂😂
Post by: Seabeowner on August 13, 2023, 06:52:18 PM
Equally amazing they sold in a day. Did you buy them?
If they were listed as used, they must be serviceable. But just looked they are just marked pre owned, so maybe anything goes.
Post by: Trigger on August 13, 2023, 06:58:52 PM
I would of taken a chance as, not listed as spares and repair  ;)
Post by: Oddjob on August 13, 2023, 08:06:45 PM
I have a spare number 4 carb body, 069a, and most of the internals for the rest of the carb bodies, I'm just waiting for Dom to see if he needs anything else besides the carb body, an emulsion tube and the jet leaf spring. Looking at the state of his carbs it's likely that he will.
Post by: DomP on August 13, 2023, 09:00:49 PM
I wasn't prepared to take the chance given his response, removing 4 screws per bowl would take all of 5 mins.  Any way I've carefully drifted all four emulsion tubes out, no4 is damaged although the internal orifice that the needle enters is ok but really needs replacing, other than some float straightening on all other carbs they are good.
In short I think I need the body of carb no4, it's emulsion tube, main jet and the retaining spring, or just a complete no4 carb.  I've spent most of this afternoon stripping the black rattle can paint off them, carb cleaner wrinkles it up nicely.
Post by: Trigger on August 13, 2023, 11:22:18 PM
The needle enters the emulsion tube and that is its guide  ;)
Did you get all the float pins out OK ?
Post by: DomP on August 14, 2023, 08:02:37 AM
All float pins came out easily Trigger, the pin entry end of the emulsion tube is only slightly marred on the top edge but I'll replace it anyway.
Post by: DomP on August 14, 2023, 12:18:24 PM
Sent you a pm
Post by: DomP on August 18, 2023, 12:37:22 PM
I had a bit of a deeper delve into my bike yesterday, the air box has been messed with to the point I'm not sure what's missing even when looking at the Cmsnl parts list.  I'm guessing lots of the parts aren't even available any longer which leaves a bit of a dilemma.
Can anyone advise me as to why I have two cut wires in the loom that have been connected seemingly the wrong way? Hopefully I've got the carb parts here to reassemble and bench sync and fuses on their way so I might be able to test the electrics by next week...who knows I might even get it started.
Post by: Trigger on August 18, 2023, 01:25:18 PM
The wires are to the solenoid and it maybe a aftermarket unit that had the colours the other way round. The solenoid is only a switch and it may not matter which way they are fitted on some  ;)
Post by: Johnny4428 on August 18, 2023, 01:47:21 PM
Yes as Trigger says, actually the yellow/red wire from the solenoid looks as if it is connected to the yellow/red on the loom, apart from that little bit of black connection in between. That whole wiring looks as if it needs a good going through. Alarm bells would ring for me with that block and blue connectors fitted.
Post by: McCabe-Thiele (Ted) on August 18, 2023, 01:57:37 PM
Those piggy back connectors (faded blue one) are notorious for poor connections plus if wrong size wiring for connector it can almost cut the cable in half. I would be replacing that with a decent alternative.
Post by: DomP on August 18, 2023, 02:28:45 PM
Yeah I'm having alarm bells too!  I'll go through every connector and clean or recrim with jap connectors that I've got from doing my xs.  Hopefully nothing too bad with it all, the seller claimed he'd ridden it in 2017 but I have my doubts, however it did have a clean MOT in 2016 so I wonder if he'd raided it for parts as it had no fuses or spark plugs when I got it delivered.
Post by: Deano400 on August 18, 2023, 03:01:57 PM
Agree, it most probably is an after market part. The PO has put the connector in there as the after market part meant the connectors were male to male and female to female. Not the way I would have done it but was the easiest way to get round the problem.
Post by: Oddjob on August 18, 2023, 04:16:38 PM
All that wiring mess near the coils is supposed to live in a small box which mounts onto a plate bolted onto the frame, that way it keeps them reasonably dry and protected etc. Is all that missing?
The foam is missing from the metal piece removed from the bottom of the airbox, you must have it fitted or it will wreck the filter with oil mist. Is the spring missing that secures the filter?
Post by: Bryanj on August 18, 2023, 04:20:01 PM
The two wire goto the insulated activating coil in the solenoid and it really doesnt matter which way round they go.
The air filter system is missing a foam filter that you can cut out of a kitchen scouring pad.
Post by: Trigger on August 18, 2023, 05:53:00 PM
You also have this part missing from the bottom of the air box >>> https://www.sohc.co.uk/index.php/topic,29346.0.html
Post by: andy120t on August 18, 2023, 06:08:30 PM
Is any of that filter/drain stuff at the bottom necessary or can it just be removed. Isn’t it US West Coast emissions related, or something similar?
Post by: Oddjob on August 18, 2023, 06:25:23 PM
Yeah it was emission related, California related almost certainly.
You can ditch it all and just fit the 500 filter, keeps cleaner as well. Vent the pipe from the breather over to atmosphere.
Either keep the old stuff or sell it on, your choice.
Post by: Seabeowner on August 18, 2023, 07:16:08 PM
The wires to the solenoid may have been reversed as the RHS switch has been replaced at some point. The early 500s only had the yellow /red to the switch and that was then earthed through the bars. The 550Fs switches have two wires to the switch (the yellow/red and a green/red I think) that completes the circuit.
Post by: DomP on August 18, 2023, 07:23:56 PM
Using a 500 air filter sounds a far simpler option to me, and this won't affect carb jetting from standard?  I'm also missing the airbox lid😫
Post by: Oddjob on August 18, 2023, 07:28:46 PM
The snorkel fitted to the 550 can be replaced by the tool tray off the 500 as well. It was fitted to reduce induction noise mainly. Jetting will be fine.
Roo has a couple of the tool trays which are far handier than having the snorkel fitted, they ain't cheap however as they are getting ultra rare these days but you can also get a spare fuse holder in it as well, which can be very handy.
Post by: DomP on August 18, 2023, 10:14:12 PM
This is the airfilter fitted to it that's had the element cut away for some reason, is it a cb500?
Post by: Oddjob on August 18, 2023, 10:19:18 PM
No that's a 550 one, the hole in the bottom is where the pole on the piece at the bottom of the airbox sticks through, what a waste of an airfilter, might as well not be fitted. No idea what the hell that bracket is doing bolted to it, that's part of the airbox mounting brackets.
Ahh, I'm betting the spring was missing and that was fitted to space the filter out to seal it against the front. So the springs missing?
If so, this is what you need.
https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_17216323020P/
Post by: DomP on August 19, 2023, 08:20:22 AM
The spring is missing, I was going to make something up to do that job for now but I'll definitely go down the 500 filter mod as originality isn't something I'm bothered about.  I still intend light modifications and haven't ruled out doing a bit of a cafe racer.
Post by: Oddjob on August 19, 2023, 03:12:50 PM
Try this fella.
http://www.sohc.co.uk/index.php/topic,27149.msg250841.html#msg250841
Post by: DomP on August 19, 2023, 07:15:09 PM
Thanks! I'm sent him a pm so fingers crossed
Post by: Oddjob on August 19, 2023, 07:47:25 PM
You need to ring Dave Baker at the phone number given in that thread Dom. See if he's still doing them.
Post by: DomP on August 19, 2023, 10:13:20 PM
Hopefully he still does Ken, I messaged Charlie to see if he remembered what the donor hub was from because the part number no longer exists.
Post by: Oddjob on August 19, 2023, 11:43:27 PM
Appears to be a VW Mk3 Polo 1993.
Check the dimensions.
https://www.gsfcarparts.com/parts/braking/brake-drums-shoes/brake-drum
Post by: DomP on August 20, 2023, 12:10:54 AM
No matter what I do GSF comes up with nothing, those links dont even work for me for some reason.
Post by: Trigger on August 20, 2023, 12:20:40 AM
The ones i used to use where Honda Civic drums, not easy to find and not cheap. I found that aftermarket drums were a lot harder to work with and some even had old crushed ball bearings from when they recycled the steel.
Honda OEM number was 42610-SB2-010, 42610-SB2-761  ;)
Post by: Oddjob on August 24, 2023, 03:58:52 PM
How about this Dom?
https://www.ebay.co.uk/itm/333827058618?hash=item4db9a4abba:g:bEAAAOSwMGBf2jdm&amdata=enc%3AAQAIAAAAwP91%2FFBnA7SeWFp2W9T4C2jvAfTNy1o5UlSCw%2B4FCuB%2F9C7otpfOCyt6LbcBqByDWG8vsDFOs5wRrn2ve1F7oBI0L2CxzWAGCDKAl6gjAMkmW3Z4CE5d5tuHYGmcOvh7AZzoTuEaDYFhAnM3p09RhU7pNagaQLiU5Y3909rH%2FsEeK81ZDTaCnB%2FLKSZ9I3o70lMMQKqmn%2FO%2Fq9zL1gnrzkMPDDjwqDAZytav7RwN%2F3lonBs1LdEUlddf%2BIqVT2O8Xw%3D%3D%7Ctkp%3ABk9SR8aL2oDFYg
Might be worth a gamble.
Post by: Trigger on August 24, 2023, 05:26:18 PM
Too big on the inside diameter  ;)
Post by: Oddjob on August 24, 2023, 05:44:27 PM
Thought the original spec was 180mm with a max spec of 181mm, which that drum clearly shows to be the same max spec.
Plus it's supposed to be the equivalent of the 42610-SB2-010 which you listed.
Post by: DomP on August 24, 2023, 08:07:14 PM
How about this Dom?
Only just noticed this, it looks like it should work
Post by: DomP on August 24, 2023, 08:08:34 PM
Having read that 550f's take 25mm fuses I spent ages searching for some and ordering them only to find my fuse box takes 30mm
Post by: Trigger on August 25, 2023, 07:44:10 AM
As i have already stated on this thread, you have to be careful of aftermarket drums. It needs to be 180mm spot on or like the old Honda ones were 179.850mm. The AP lockheed will be a tad over 180mm.
Try a Brembo 14.5069.10  or a Bosch 0 986 477 063
These were the last one i bought for Mick's and Roo's hub >>>https://www.autodoc.co.uk/brembo/1657868
Post by: Oddjob on August 25, 2023, 01:08:07 PM
The specs listed show it as being 180mm. AP Lockheed are a decent make.
That Brembo one is mage expensive, especially when all you want is the liner.
Post by: Trigger on August 25, 2023, 04:59:32 PM
Not expensive at £60 per drum. You get what you pay for.
My mate who is a window fitter had worn out his OEM brake disc's after 75000 miles on his van and he replaced them with cheap shite from europarts. They only lasted 10000miles  ;)
Post by: DomP on August 26, 2023, 11:09:12 AM
Before I commit to getting this hub relined, what's going on here with the alignment?
Post by: Oddjob on August 26, 2023, 11:24:34 AM
Alignment Dom? Please clarify.
Correct me if I’m wrong here but weren’t AP Lockheed original equipment on some 750f models?
Post by: Trigger on August 26, 2023, 12:55:07 PM
Show me a picture of you hub because i may have one already done  ;)
Post by: DomP on August 26, 2023, 02:05:49 PM
Post by: DomP on August 26, 2023, 02:06:49 PM
Will do when I can but for some reason I can't upload photos today?!
Post by: DomP on August 26, 2023, 02:56:39 PM
When using a 500 air filter in a 550 airbox how do I prevent it dropping it the bottom?
Post by: DomP on August 26, 2023, 03:04:04 PM
Hmm, I've had to resize my photos which I've not needed to do before.  Here you go Trigger.
Post by: Trigger on August 26, 2023, 06:28:10 PM
Sorry Dom, hard to tell from those pictures. I thought you had the wheel stripped down and that is the picture i was after to ID the hub  ;)
Post by: DomP on August 26, 2023, 06:50:27 PM
I did have but put it back together so I can move it about in my cramped garage.  It's a standard 550f rear hub so I could send you photos from one on ebay?
Post by: DomP on August 26, 2023, 07:06:46 PM
I got it started today after a carb rebuild, it sounded a bit rough but I've only done the cam chain adjustment so not looked at the tappets or timing! I remembered I'd not checked the compression so did a test after it's brief time running.  The results were worryingly poor, 70,75, 80, 82ish, as its not been started since 2016/17 I'm guessing I've got either piston ring wear or very poorly adjusted tappets. Is this likely to be the case on 32k?
I have found that it's not running on points but electronic ignition (Dyna S) which was a nice surprise as its one less thing to have to mess around with.
Post by: Oddjob on August 26, 2023, 07:15:39 PM
AFAIK the filter will sit correctly. I seem to recall it's the same psychical shape and size, just with a hole in the bottom on the 550.
Post by: DomP on August 26, 2023, 07:31:32 PM
It will sit down too far meaning it doesn't line up with the airbox hole. I think the 550 filter is held up by the metal pipe and gauge screen.
Regarding the rear hub alignment I mentioned earlier, there is a photo a few posts back where the sprocket carrier isn't in alignment with the hub.
Post by: Bryanj on August 26, 2023, 07:34:51 PM
Sprocket carrier is not fitted correctly
Post by: DomP on August 26, 2023, 07:41:38 PM
Here you go Trigger, this is what the internals of mine looks like.
Post by: Trigger on August 26, 2023, 07:49:53 PM
Is that the hub from your bike ? Can not see any cracks in the liner .
Post by: Nurse Julie on August 26, 2023, 07:57:34 PM
A 500 air filter will not fit a 550 air filter box, it'll just drop to the bottom and won't line up where it needs to, I've tried it personally as I have 500 and 550.
Post by: Trigger on August 26, 2023, 07:59:30 PM
I need this angle picture to ID what sort of hub you have. Like this. I have put a picture on this forum before with the two different types of hubs but, can not find it  ;)
[attachimg=1]
Post by: DomP on August 26, 2023, 08:02:59 PM
OK, I'll go out and get a photo now.   Regarding the 500 air filter, I though of making a bracket to bolt though the lower airbox hole to prevent the filter slipping down.
Post by: Nurse Julie on August 26, 2023, 08:14:24 PM
You could just use a 550 air filter Dom. There are 2 different 550 air filter boxes, one has a rubber cushion around it the other doesn't, as well as other differences in the air filter box set up between the 2 550's.
Post by: DomP on August 26, 2023, 08:20:06 PM
You could just use a 550 air filter Dom. There are 2 different 550 air filter boxes, one has a rubber cushion around it the other doesn't, as well as other differences in the air filter box set up.
I used a 500 filter because I'm missing quite a few of the original airbox bits and Ken told me it's the easier option.  Mine is the rubber cushion type.
Post by: DomP on August 26, 2023, 08:22:58 PM
Trigger-
Post by: Nurse Julie on August 26, 2023, 08:25:37 PM
Ah yes, I remember seeing your photos now. If I remember, you had the piece with the stand on it but not the panching plate, which you can do without anyway.
Post by: Nurse Julie on August 26, 2023, 08:33:20 PM
This is what Trigger did to my bike as I also had bits missing, so all I've got is the bottom part in the air box, the same as you have, I have a 550 air filter, of which there is two types and a made up lid.
[attachimg=1].
Post by: DomP on August 26, 2023, 10:55:31 PM
Any thoughts on my low compression results folks?
Post by: McCabe-Thiele (Ted) on August 26, 2023, 11:17:05 PM
If you are concerned about the compression readings after you have checked the valve clearances it might we worth trying some oil down the bores then re-check with all the plugs out.
If its piston related they should come up massively, if little change might be the valves need re-grinding.
Post by: Trigger on August 27, 2023, 12:19:49 AM
Trigger-
Ok Dom, it is a 323 hub. I must have one in one of the store rooms. Will have a look for it and get back to you  ;)
Post by: Oddjob on August 27, 2023, 06:34:46 AM
If fitting the 500 filter is a problem in the 550 air box just replace that part with the 500 version. CMS have 3 new ones in stock for around £30 each.
It seems a little bit of overkill tbh but the 500 filter is generally easier to find and generally a lot cheaper to buy, genuine that is not aftermarket. So it will pay for itself in the end.
You could just fit the 550 filter with the bottom tubed part of the recycling system fitted as well. What you shouldn’t do is fit it without that part fitted as well, firstly because it has a small seal that seals around the hole in the bottom of the filter and secondly because without that seal unfiltered air is getting into the engine and you might as well not fit an air filter if that’s happening.
Drop a little oil down the plug holes, just a few drops, and leave it for a while. Test compression again, don’t forget, throttle wide open, kill switch to off. It could be ring wear, it could be the rings are stuck in their grooves so aren’t sealing like they should, the oil may help them become unstuck. If the readings go up significantly then that points to the rings being the problem.
I seem to recall that the 550 brake plate won’t fit in the 500 hub, it fits physically but a flange on the plate rubs on the hub. Been a while so I might be mistaken.
Post by: DomP on August 27, 2023, 07:51:02 AM
Thanks all, I'll have another look at it today, struggling to get a steady idle, carbs set to factory with genuine jets etc and bench synced and the low compression concerned me a bit.  I'll get there, might take me delving into the engine which I've never done before.  Is it that costly to do a DIY top end rebuild?
Post by: Trigger on August 27, 2023, 08:01:11 AM
A 550K0, 550K1, 550K2, 550F1 brake plate is middle number 374 and was fitted to the 323 hub  ;)
A 550F2, 550K3 brake plate is middle number 341 and was fitted to a 404 hub  ;)
Dom has a 323 hub as he has a CB550F1 UK model   ::)
It is very easy Dom. All you had to do is unplug the hose that runs from the top of the engine breather cover where it attaches to the air box at the bottom. Find a rubber ferrule that would fit over the pipe at the bottom of the air box. This would cap any oil vapour from the engine. Use a 550 air filter with what you already have and hunt for a lid for the air box.  ;)
Post by: Trigger on August 27, 2023, 08:03:49 AM
Cost is down to what you find that needs replacing  ;)
Post by: DomP on August 27, 2023, 10:40:30 AM
I've just done a compression test again after trying to get it to idle and giving up, a fair amount of smoke and smelling really rich.
New results with all plugs out, and full throttle.  I think I'd left the choke on however.
Cylinder 1 - 125psi
Cylinder 2 - 110
Cylinder 3 - 120
Cylinder 4 - 110
I've turned the mixture screw in so it's now at a full turn out. Next plan is to let it cool down and check/adjust the valve clearances.
Post by: McCabe-Thiele (Ted) on August 27, 2023, 11:45:10 AM
A lot better than they were previously @ 70,75, 80, 82 ish.
Might be worth putting a few miles on her with some upper cylinder lubricant if it's not run for a while they might improve - nothing to loose.
If it turns out to be a bore/piston wear issue you really need to split the crankcases as new pistons can put extra load on the crank so best to check the big ends & main bearings.
Bryan here does rebores for 500/550's I think as well as Trigger so might be worth a couple of PM's for prices.
Post by: DomP on August 27, 2023, 01:00:58 PM
It's not roadworthy enough yo put miles on sadly Ted, the rear hub is buggered and I can get it to idle without stalling as yet.  Just done the valve clearances and I think I should check the set up of the Dyna S ignition to be sure it's not set incorrectly.  Not sure how it's set up but I'll do a google
Post by: DomP on August 27, 2023, 05:10:36 PM
Why isn't there enough adjustment in my electronic ignition?  To set a timing light to come on t the F mark with the advance at full it won't rotate far enough.  I'm a bit stumped
Post by: McCabe-Thiele (Ted) on August 27, 2023, 05:19:25 PM
You can do the Dyna S like points statically or dynamically.
Okay without going back over your post have you cleaned the carbs & bench synched them?
Post by: Oddjob on August 27, 2023, 05:29:24 PM
Can't remember which it is now but one electronic ignition is set at full advance. So rev to 4k and set it there and see if that works better
Post by: Trigger on August 27, 2023, 06:24:50 PM
https://www.google.com/search?q=set+up+a+dyna+cb550&rlz=1C1YTUH_en-GBGB1002GB1002&oq=set+up++a+dyna+cb550&aqs=chrome..69i57j33i160l2.11336j0j7&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:7c85c45c,vid:q7oy8RSB9Vs
Post by: DomP on August 27, 2023, 06:35:46 PM
Yep carbs are refurbed and synced as close as I could get them.  I think I've been using the wrong mark🤭, it's easy to be set to the very far right mark with the advance at full where as I'd been setting it to the F.
Post by: DomP on August 27, 2023, 07:29:05 PM
All sorted, still sounds like a bag of nails though and stinking rich😬  I get the feeling it's going to,need open heart surgery.
Post by: Trigger on August 27, 2023, 07:32:21 PM
 glad you got that one sorted.
You will find you need to strip the whole engine down and be prepared for some surprises  ;)
Post by: Nurse Julie on August 27, 2023, 07:34:43 PM
Are you turning the air / fuel mix screw the right way?. Out for more air = leaner, in for more fuel = richer.
Post by: DomP on August 27, 2023, 07:54:19 PM
I've taken a video of it running, not sure it will upload on here but it doesn't sound smooth at all, my xs650 sounds smoother!  When I drop the revs to around 1100 it starts to sound a bit clanky.  I very much doubt that the previous owner had it running and went round the block like he claimed when he last used it, more like he stopped running it due to what I'm hearing.
Post by: DomP on August 27, 2023, 07:55:32 PM
My bad! Yeah I turned it in rather than out by mistake
Post by: Nurse Julie on August 27, 2023, 08:06:35 PM
Yea, that's what I guessed 😊😊😊
Post by: DomP on August 27, 2023, 09:11:50 PM
Short of biting the bullet and stripping it down are there any tests I can do to detect what sort of wear I might have?  I think I know the answer to this one!  One thought I have had, could it be a weak or intermittent spark causing the roughness and therefore the smoking/smelling rich? The HT leads are pretty rigid and the coils a bit knackered looking.
Post by: McCabe-Thiele (Ted) on August 27, 2023, 09:31:49 PM
My brief experience with coils is to look at where the HT leads just exit the coil if the outer insulation is cracked then they are probably part of the problem.
Post by: DomP on August 28, 2023, 09:00:19 AM
I'm going to order some new ht lead and caps (plugs are new non resistor type) and do the 'Ash fix' on the coils to rule that out as a possible cause.  Could the carb sync being out be enough to cause it to sound so bad?  Going to get a load of airline to perform a carb sync as well and see where that leaves me, if all this doesn't solve it it is at least nothing lost and I can move on to looking at a rebuild.
Post by: Trigger on August 28, 2023, 09:03:04 AM
If the carbs are not all balanced correctly, the engine will sound ruff  ;)
Post by: DomP on August 28, 2023, 09:05:43 AM
In my haste I've only become synced,
Post by: Trigger on August 28, 2023, 09:19:47 AM
If the clunking is that bad, you will find that the primary chain and rubbers are well past its best  ;)
Post by: DomP on August 28, 2023, 09:27:35 AM
To be honest I'm a bit excited by the idea of splitting it, I've got room on the kitchen table now the carbs are back together too 🤣
Post by: Bryanj on August 28, 2023, 11:28:14 AM
If you are going to split i suggest getting as many parts as possible first.
Gasket set
Oil seal set
Primary chain (kawasaki)
Cam chain, see oddjob
Primary damper rubbers x 8 Honda and not cheap
Possibly cam chain tension blade
Probably cam chain cushion
Maybe pistons/rebore
Bank loan
Post by: McCabe-Thiele (Ted) on August 28, 2023, 07:24:11 PM
If you split the casing you're looking at a potential budget of £1k plus a tad more if you need some gearbox bearings as well. These old bikes are like black holes with costs.
Post by: Trigger on August 28, 2023, 07:40:57 PM
Check for bent valves and cracked valve guides  ;) And they are not cheap if you can get them .
Post by: DomP on August 28, 2023, 10:53:39 PM
I'm prepared for it to be expensive, that's not really an issue as I'm in no rush and will be doing the work myself as far as I can.  Having turned the air mixture screw out to factory setting again I began syncing the carbs with some cheap ebay vac gauges and got it running a whole lot better and quieter.  Family life then intervened so I still need to finish tweaking but I think I'm getting somewhere.  Bit of a weep coming from the head gasket though!
Post by: DomP on August 31, 2023, 09:41:16 AM
I've bitten the bullet and bought a Morgan Carbtune so I'll get the carbs balanced on the weekend.  Is there a recommended setting for the throttle stops?
Post by: Oddjob on August 31, 2023, 01:20:56 PM
Depends what you mean by throttle stops
Post by: DomP on August 31, 2023, 03:51:21 PM
I've just got a Haynes manual today which says 56mm. This is what I was referring to Ken
Post by: DomP on September 02, 2023, 03:19:51 PM
I think this engines not well, far too much blue smoke and I can't get the it to idle well enough to balance the carbs even. I just can't work out what to do next.
Post by: Oddjob on September 02, 2023, 03:44:06 PM
Strip the head and barrels off.
Post by: DomP on September 02, 2023, 03:52:32 PM
Yes I think so Ken, to be honest it's got an oil lea from the head gasket that needs sorting so I'm going to be going in there at some point so might as well now.  Also a few times after turning it off the exhaust has made a king of vacuum stuck back noise, what's that?
Post by: Oddjob on September 02, 2023, 03:58:24 PM
Sounds like either a bent valve or a really bad valve seat problem, so it's pulling air down the exhaust due to the poor seal.
Don't forget to replace the valve stem seals whilst you have the head off.
I suspect you'll find rings stuck in the grooves on the piston as well
Post by: DomP on September 02, 2023, 04:29:46 PM
Ken, do you remember offering any more help I might need? 😉   I might be asking a few questions
Post by: Bryanj on September 02, 2023, 04:45:45 PM
Its either been stood too long with a valve open, or the cam cover has not been reassembled to the head carefully enough and a valve stem got bent!
Post by: DomP on September 02, 2023, 04:49:18 PM
Someone's been in there before me, theres dodgy red gasket sealant on the cases which can't be a good sign.  I've never fully stripped an engine before, now I know you are all going to say pull the whole engine and strip it fully but could I pull the head and barrels in the frame and see what I find before going any further.
Post by: Bryanj on September 02, 2023, 05:04:23 PM
Yup, its easier to do that way as it makes the lump lighter.
The full honda 500/550 manual is in either Ashs dropbox or alladins cave so download it and read, especially the bit about refitting cam cover!!!
Post by: Trigger on September 02, 2023, 05:52:43 PM
If any valves are bent Dom, get a magnify glass and check that non of the valve guides are cracked. Even a small hairline crack will open up once the engine has warmed up  ;)
Post by: DomP on September 02, 2023, 06:17:39 PM
Thanks all, I've got the rocker off following several guides, I'm labelling everything and sticking bolts through labelled card to remember their positions for reassembly.   I'll post some photos later
Post by: Trigger on September 02, 2023, 06:25:04 PM
I love pictures of the insides of engines. That is what made my job so interesting, you would never find the same problem once stripped down  ;)
Post by: DomP on September 02, 2023, 07:28:35 PM
For now in going to call it a day, the head won't come off the barrels and it's beer o'clock
Post by: McCabe-Thiele (Ted) on September 02, 2023, 07:51:36 PM
My 400 head was well stuck on Iirc I sprayed all around the edges of the head gasket with Plus Gas then used a big Rubber mallet to give it some side shock. Lastly I used a plastic double glazing wedge to persuade it to separate.
Post by: DomP on September 02, 2023, 08:03:28 PM
Here's what I've found so far...  the rockers are nice and clean but there is some scoring to the surfaces in the head and on the camshaft, some is visible but can't be felt with a nail.
Post by: Bryanj on September 02, 2023, 08:33:58 PM
Nowt wrong with that cam
Post by: DomP on September 02, 2023, 08:37:11 PM
That's a relief Bryan,  I'm  not sure if I want to find any other issues that answer my problems or whether a clean bill of health would be good.  Either way I'll be fixing a head gasket leak so it's all positive!
Post by: Oddjob on September 02, 2023, 08:46:38 PM
Has some pitting on number 3 inlet lobe, the journals are a little tramlined as well, depends a lot on how the journals are underneath on the head TBH. Post a pic of the rocker arms and the camcover as well, but before you do anything remove the tacho drive, CAREFULLY. It's breaks for fun, right where it meets the top of the camcover, a lot of the time only the bolt is holding it together. Push from underneath rather than try to lever it out. If it's intact store it carefully. They are expensive to replace and VERY easy to break if left in the cover.
The cam can be re-profiled if there is more pitting on the lobes.
The dreaded instant gasket has made an appearance, haven't seen that stuff for a long while now. Very common in the 80s.
Post by: Oddjob on September 02, 2023, 08:47:33 PM
Feel free, my favourite engine the 500/550.
Post by: Bryanj on September 02, 2023, 08:48:56 PM
Dont remember seeing where you are located apart from uk, which whilst smaller than us still covers a big area
Post by: DomP on September 02, 2023, 08:54:46 PM
Thanks Ken! I'm enjoying it at the moment. The tacho drive that screws into the rocker cover? It came out easily
Post by: DomP on September 02, 2023, 08:55:55 PM
Good old Herefordshire, right on the Welsh border just outside a town called Kington.
Post by: K2-K6 on September 02, 2023, 08:56:34 PM
What about the holes / inclusion on the lobe nearest the sprocket flange in 3rd photo  ? Looks like a good cheddar on my screen   :o
Post by: Oddjob on September 02, 2023, 09:14:23 PM
Yeah, that's what I spotted, number 3 inlet lobe. Showing some pitting, you need to check the other lobes for the same type of damage Dom. Also check the rocker that runs on that lobe for damage that pitting may have transferred to it. You should have a 550F type rocker cover, we need to check that's the case as they can be swapped and sold and fitted with a 500 cover. The 550 is the better type of over as the rocker shafts were pegged to stop them rotating and ovaling the holes out in the cover body. However the pegged shafts are prone to premature wear so maybe think about removing those as well.
Don't hammer the cylinder head fins to get it unstuck BTW or you'll break them. 2 small bolts fitted front and rear of the cam tunnel as well, make sure they are out. Use a rubber mallet or better still what is called a Compothane hammer, which is like a plastic hammer but the head is filled with lead shot so it gives a real dead blow which tends to shock stuff loose but without breaking it.
Like this.
https://www.screwfix.com/p/magnusson-dead-blow-rubber-mallet-35oz-0-99kg-/3081V?kpid=3081V&cm_mmc=Google-_-Datafeed-_-Tools?kpid=KINASEKPID&cm_mmc=Google-_-TOKEN1-_-TOKEN2&gclid=Cj0KCQjwusunBhCYARIsAFBsUP8616XTHja4_0HC5RPXdGZ7TOykNRarRGVFWQZhGP1N4kUKdpvza2kaAu5FEALw_wcB&gclsrc=aw.ds
Post by: DomP on September 02, 2023, 09:19:34 PM
I'll get some photos of the rocker lobes tomorrow but they all looked really good to me, I did notice the blemishes on the one lobe.  I really appreciate everyone's help on this, proper like minded community spirit!
Post by: Bryanj on September 02, 2023, 09:25:00 PM
Yes its pitted but seen worse, if you are going balls outfull race needs replacing, if, like most of us, it will do maybe 2,000 a year it will last forever.
The followers are hardened the lobes are not
Post by: Oddjob on September 02, 2023, 09:26:10 PM
If worse comes to worse you can always get the cam redone at Newmans. Maybe have it re-profiled to suit the engine better, a few degrees more overlap, a few degrees more duration for example really wake this engine up midrange. Cost is the same as just having it done to standard. It's about £100-120 plus VAT plus P&P.
Post by: K2-K6 on September 02, 2023, 09:59:09 PM
Interested to see what the rocker faces look like. Wear from these component will often be too small (sub 5 ~10 micron ) to be trapped by conventional oil filters, that's what makes the "tramlines" in plain bearing surfaces by getting trapped in soft part of those bearings next time round, crankshaft assembly too.
Originates in oil condition during previous running, too long interval and fuel dilution. Cam lobe and followers always show this first due to highest pressure exerted on oil film at this site location.
Post by: DomP on September 02, 2023, 10:30:17 PM
I quite like the idea of a bit of cam reprofiling, if I find everything else to be in good order I may go down that route.  In terms of top end gasket and o-ring kits, where is best to get them?
Post by: Oddjob on September 02, 2023, 11:19:27 PM
Always try and source a genuine top end gasket kit. Quality is far superior. Not exactly an abundance of them these days though.
Post by: Trigger on September 02, 2023, 11:24:36 PM
Vesrah are a top kit and you will need more than a top end set  ;)
Post by: DomP on September 03, 2023, 11:30:38 AM
I've got it stripped down and barrels off, I think at this point pictures will speak a thousand words, some good, some not so.  Here goes, I've not got a valve spring compressor so that bit will have to wait.
Post by: DomP on September 03, 2023, 11:32:24 AM
There's more
Post by: DomP on September 03, 2023, 11:35:32 AM
Apologies for the picture heavy content!
Cylinder 4, the small end bearing has some wiggle but the rest all seem fine from my very basic checks, all piston rings were free but the barrels don't look great do they?
Post by: DomP on September 03, 2023, 01:44:25 PM
Things I've noticed are the pitting on 3x tappet adjuster screws, some rough and raised edges on two of the puck recesses, pitting to the valve side of the head, the bores are a little scored and one has an inclusion or something.
Post by: Trigger on September 03, 2023, 01:57:56 PM
Looks like your in for a long winter getting that back to top condition. Tappets are cheap but, I can see where they have chipped away at the top of the valves.
Cam lobes don't look good and it will need a rebore with oversize piston kit at 0.50 or more  ;)
Cam chain guides look like any old guides and you always replace them.
Post by: DomP on September 03, 2023, 02:22:51 PM
It's just the one lobe not that that makes things better, it's all doable I presume though and there's really no rush on my part.  Would I be best asking one of you to do any machining I need doing or look for somewhere near me and I'll need to as you all for advice on what a rebore entails such as new pistons etc.   Don't get me wrong when I say this but I'm looking to make it reliable and doing what's necessary but not spending where I don't need to.
Post by: Trigger on September 03, 2023, 02:32:20 PM
Bryan J is close to you and he has a boring bar, knows the spec and knows were he can get a piston kit from  ;)
Post by: Oddjob on September 03, 2023, 02:53:23 PM
What's the barrel itself like Dom, any chipped fins etc. I'm thinking maybe replace the liners and rebore those so you can say just do an 0.25 overbore and save the rest for later, if ever.
Oversize pistons available at Cruzinimage pretty cheap and they seem ok from reports. Maybe check to see what the barrels clear up at before ordering. Either with new liners or with the old ones.
I may have some tappet adjusters. The valves with the damage may be able to be dressed up.
Got to say some of the rings look stuck in the grooves in a couple of the pics. Clearly 3 and 4 were not running well.
Head looks ok, camshaft journals not too bad. Rocker box is 550.
One thing I did notice, there appear to be springs fitted against the rocker arms, the 400 got similar but not the 550 to the best of my knowledge.
The camchain tensioner doesn't look bad, maybe check it's moves freely and replace the slipper if it does. The metal part should look straight from top to bottom, most seem to have a bend in them from bad fitting when amatuers take them apart. Check it's straight.
The camchain guide looks normal TBH, I've never replaced one of those unless it was damaged, usually bent.
With the state of the engine, clearly due to badly contaminated oil, I'm sort of dreading what the cranks shells are going to look like. Let's hope I'm wrong and they are fine.
Post by: DomP on September 03, 2023, 03:09:49 PM
Thanks Trigger, I'll send Bryan a pm.
Ken, the barrels have a couple of bits of fin damage but pretty inconspicuous and ill be painting it if all goes to plan.  Your correct there are springs on the rockers, should they not be there?  Very small marks to two valves but I've also noticed a chip on the cm chain adjuster retaining bolt hole.
No stuck ppiston rings Ken, they are all free but thats immaterial i guess what with the bore wear, tensioner looks OK for straightness too. You're all suggesting I split the cases then, I'm dreading that bit, I can't get the kickstart off the splines for a start😫
Post by: Bryanj on September 03, 2023, 03:11:03 PM
Recently i have had a lot of my old barrels not clean at 0.25 as the liners have been egg shaped, so worth checking bore before ordering pistons.
You can call me on 07795162623 Monday to Thursday inclusive after 8pm when i am at work driving
Post by: Oddjob on September 03, 2023, 03:22:50 PM
Remove the pinch bolt on the kickstarter and force a screwdriver or a chisel into the slot, that should expand the slot and allow the arm to come off.
Post by: DomP on September 03, 2023, 03:42:04 PM
I tried that Ken, I'll be a bit more gung-ho!
Post by: Trigger on September 03, 2023, 06:04:37 PM
It is one of the mistakes that a lot of owners buy pistons at .25 and only 10% ever do clean up mate.
Post by: Bryanj on September 03, 2023, 07:29:44 PM
Yup, im finding them barrell shaped, fine at top and bottom but dont touch in middle, never found a step at the top yet though
Post by: Trigger on September 03, 2023, 07:41:20 PM
It is a fine art with liners mate and can be a lot of work. Had a 750 set once that had water sitting on top of two pistons for years.
Re-bored to  0.45 and then to 0.75 and then 0.95 and you could still see the marks. Pushed the liner out and it had gone all the way through  :o Then had to go down the road of putting another liner in and skim up the barrels  ;)
Post by: DomP on September 03, 2023, 07:53:49 PM
Am I right in thinking I'm doing the right think here, I'm not chasing a lost cause?
Post by: Nurse Julie on September 03, 2023, 08:16:52 PM
You won't know until you have fully stripped the engine, measured and assessed everything, priced up all the parts needed and costed the machine work.
Post by: DomP on September 03, 2023, 09:14:01 PM
Let's remain positive folks🤣
Post by: DomP on September 04, 2023, 11:44:30 AM
This week I'm hoping to find time to split the cases, is there anything I should be aware of when I do this?  I'll be following the shop manual and some YouTube videos to guide me.
Post by: Bryanj on September 04, 2023, 12:20:22 PM
If you have the puller take the alternator rotor off the crank whilst still assembled, easier than chasing crank arround the bench.
There is one odd 10mm headed bold hidden away everybody forgets.
You dont need a puller for the primary shaft, remove the oil pump and use a SOFT drift on the end you can see in the hole AFTER removing the retainers at clutch side.
Keep all the shells exactly where they came from as there is no way of identifying size if mixed up
Post by: Oddjob on September 04, 2023, 02:36:45 PM
The primary shaft is easily removed by using the step bar bolt, the one the riders footrests thread onto.
Remove the bolt, leave a nut and washer on one end, thread on one of the footrests so the rubber end protrudes past the nut and washer. Thread the bar into the end of the primary shaft and use the footrest like a slide hammer It will pull out very easily as a rule.
Catch the spacer as it drops out from between the starter ring and the bearing.
Remove as much as you can before removing engine, points and advance unit, rotor as Bryan describes, clutch and chain sprocket, oil filter housing and oil pan and mesh filter. Get the engine as light as possible, you can get it out of the frame a lot easier that way.
Post by: DomP on September 04, 2023, 04:24:59 PM
That sounds a good plan Ken, I think this will be a steep learning curve!
I'm still not entirely sure I know in what order to remove bits yet, I think I need to watch it being done a few more times and read through the shop manual again
Post by: McCabe-Thiele (Ted) on September 04, 2023, 05:42:51 PM
You will get the hang of it Dom once you have removed pretty much everything from either side of the engine, top & bottom it gets easier. As has been said best to remove the alternator rotor then it's casing bolts in order. The primary drive shaft is easier to remove than it sounds - iirc I used some long drifts to knock the bearing out then look for the hidden bolt that stopping the cases from separating.
Post by: Oddjob on September 04, 2023, 06:03:12 PM
The hidden bolt is inside the sump IIRC.
Just take parts off and store them together, maybe take a pic of the area first so you can see what it looked like if you get lost. Take points cover off, take the bolt out of the middle of the big nut, that will allow the nut to come off, put everything inside the points cover first off, then remove the 3 screws holding the points plate on, disconnect the wiring and remove plate, then advance/retard mechanism. First job done, put everything in sealable plastic bags, maybe a label, maybe not. Keep areas  together, points in one bag, rotor in another, clutch in another etc. You'll soon get used to it.
Post by: McCabe-Thiele (Ted) on September 04, 2023, 06:59:35 PM
Ken is right about labelling and putting parts together in bags or boxes.
I use old takeaway boxes to group bolts etc together then write on the lid where they came from take plenty of pics on your phone as well it helps with assembly some months later. Even when it's obvious where something was take a photo as it might not be obvious a week or more later.
For the engine casing bolts I use a piece of cardboard labelled up then fit the bolts through the holes makes it easier for assembly, you may well have thought of this anyway so sorry if i'm being too basic. Yes I spelt dowel wrong & left the y out of empty where a bolt was missing iirc.
(https://live.staticflickr.com/65535/53164673133_67eb42a836_o.jpg) (https://flic.kr/p/2oZYR6p)PXL_20230904_175427132 (https://flic.kr/p/2oZYR6p) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: Bryanj on September 04, 2023, 09:30:17 PM
The 500/550 is the easiest of the fours to work on, only two "specials" you need
1 rotor puller and an ht bolt with correct thred will work
2 clutch nut peg spanner and you can make one from an old socket and cutting disc
Post by: DomP on September 04, 2023, 09:30:57 PM
I did exactly this on the weekend when dismantling the topend Ted, seems the best way to ensure stuff goes back where it should.  Tonight I've had time to get get the points side all out, clutch cover and cluch eventually after a bit of a battle with the kick-start, and all of the left side as far as the big bolt on the stator.  It was getting too dark by then as I've been wheeling it out of the garage and under a gazebo for natural light, without an impact gun will getting that bolt out be easy enough because I can't see how to stop the crank spinning.
Post by: DomP on September 04, 2023, 09:34:00 PM
You beat me to it Bryan, I'll try to call you this week to try and get the ball rolling.
Post by: McCabe-Thiele (Ted) on September 04, 2023, 10:05:54 PM
With the block off you can pop a Gudgeon Pin through number one Conrod then use a wooden block on either side of the pin to hold the crank in place. At least I think that's what I did to undo the alternator nut.
Post by: Oddjob on September 05, 2023, 05:29:41 AM
Eh??? The 500/550 doesn't have a clutch nut Bryan, it's a circlip. You're confusing it with the 400 I think.
Post by: DomP on September 05, 2023, 11:05:09 PM
I've had a look tonight and you're right Ken, there's a spring on the rocker shaft.  What the hell is that all about?!
Post by: Trigger on September 05, 2023, 11:28:09 PM
Should not have springs on the shafts Dom. Only fitted to the 350 and 400's. Looks like someone got confuse with the manual on the 550/400.  That is why your valve stems are chipped so much and you will have to replace any damaged valves  ;)
Post by: DomP on September 06, 2023, 07:23:10 AM
Oh crap, seems I've definitely bought a bit of a s####er, I'm a bit far in to give up now though
Post by: Trigger on September 06, 2023, 07:40:53 AM
The Haynes manual covers both the CB400 and the CB550 in the same book and it looks like the previous owner has taken the information on the CB400 rockers and applied it to a CB550 engine  :o
On a CB400, if you have the springs on the wrong side of the rockers, you get the same result on valve stem chipping after some time  ;)
Post by: Trigger on September 06, 2023, 07:45:07 AM
If you look half way down this page on Julies thread on a CB400 you will see the springs on the shafts  ;)
https://www.sohc.co.uk/index.php/topic,14049.30.html
Post by: DomP on September 06, 2023, 07:57:26 AM
I'll take them off tonight then, looking at the shop manual there's nothing in their place which makes me wonder what takes up the slack?  I've written a list of bits I think I need at this stage-
Cam chain £35, Ken
Primary chain  £48.40, Kawasaki
Primary dampers £6.41 each, DSS
Vesrah full gasket set £94.80, DSS
oil seal set £?
Piston set, Cruizinimage or DSS
Cam chain dampers £10.69, DSS
Valve stem seals £24, DSS
Hondabond £20
Any opinions or additions to on that list so far?
Post by: Trigger on September 06, 2023, 08:37:24 AM
Cam chain £35, Ken
oil seal set £?
Hondabond £20
Valve stem seals come in the gasket set Dom but, the head sealing rubbers (pucks) do not  ;)
Oil pump o'ring kit from julie.
You will not know until you fully assess what you need at the full strip stage but, any short cuts and these engines bit back  ;)
Post by: DomP on September 06, 2023, 10:21:28 AM
Should I be using plasti gauge on the conrod big ends
Post by: Trigger on September 06, 2023, 10:30:48 AM
Yes, everything needs to be plasti-gauged up to work out all the clearances.
All gear box bearings need to be checked they are running feely and are not worn. The gear change dogs are with in spec and so on  ;)
Post by: Bryanj on September 06, 2023, 12:51:01 PM
Do you mean cam chain tens blade and cushion as dampers are little things that go in ends of tensioner
Post by: DomP on September 06, 2023, 12:55:07 PM
Yeah that's what I meant Bryan, the little dampers.
Best order some plasti gauge, what colour?
Post by: Oddjob on September 06, 2023, 03:28:21 PM
Cam chain £35, Ken
oil seal set £?
Hondabond £20
Vesrah kit seems damned expensive, the OE head kit includes valve stem seals BTW and TBH a full kit isn't that attractive. There are only a few gaskets in the bottom end kit and most of the time it's cheaper to buy them separately IF you need them. Rotor one for instance isn't an oil seal gasket, just a seal to keep water etc out. If it's not broken you can reuse that. TBH I've reused lots of gaskets in the past, so long as they come off intact why not. Or buy an OE bottom kit.
I have some of the camchain tensioner damper rubbers somewhere. NOS of course. I'd advise checking the tensioner itself, does the blade compress and expand smoothly, is the release bolt ok, screwdriver slot not deformed or even broken, more than a few are. Is the bottom part straight and damage free, you'd be amazed how many have been caught by the primary chain, the damage is easy to see.
Refrain from buying plastigauge, look at the crank first, assess what needs replacing. It's likely you're going to need new shells, you can order it then if you think you need it.
It's going to get expensive, try and keep the costs down as much as possible whilst buying good parts, you get what you pay for when it comes to engine parts. Most of the roller bearings are available cheaper than OE, same make, same bearing, buy them from Hendersons for example. Same for seals, just chek the old one and you'll see the size printed on it, input that into Google and far cheaper alternatives come up.
Post by: Trigger on September 06, 2023, 05:24:30 PM
If you just buy a top end gasket set, you will be missing the starter motor cover gasket, the clutch gasket, the alternator gasket, the points cover gasket, sump gasket and all the bottom end o'rings .
If you skimp on using old gaskets, you run the risk of an oil leak  ;)
Post by: Oddjob on September 06, 2023, 07:59:41 PM
Never changed the starter motor cover gasket, never changed the points cover gasket, almost never changed the oring for the sump.
Rotor gasket isn't oil tight, just water so you can make one if it rips coming off. Only one you might need to change is the clutch cover if that rips, I tend to slide a really thin Stanley knife blade down the gap once all the screws are out, normally got half off without them breaking and you can use them again then.
Orings are dirt cheap and readily available. Same for engine seals, I have most of the orings and quite a few of the seals as I buy them in quantity.
His bill will be high enough without buying parts that aren't always needed. For a few pound more he could source a genuine top and bottom gasket kit and get the right parts, no problem with the head gasket and the orings not sealing with genuine, orings are all the exact size as well. John Oldfield has 2 bottom end kits for £34 each. It's just a matter of searching hard and you can find them at the right prices generally.
If you feel like searching Dom, the part numbers are 06110-390-020 for the topend set and 06111-390-000 for the bottom end set. Have a look around, see if you can find a bargain, they are out there, getting harder to find admitably but still available.
Post by: Trigger on September 06, 2023, 11:58:34 PM
This is the part you need for the bottom of your air box Dom >>>> https://www.ebay.co.uk/itm/355020970267?hash=item52a8e6191b:g:qzcAAOSwF8Nk-KJG&amdata=enc%3AAQAIAAAAwHvKo2rJus4LgdssI7kGjCt8xNFvDZkkQLL%2F3dC27wc96qT4KCMTLEUyfuOXsFaM9D%2B5IchmMOY2CKs0fKgdgBzl6m7YD5IdJUDvgxlrQovxO1zokbKr7zD3Ve1pXdZKgn7USjGsYDVk77mryw%2F%2BV7n%2F8N6TSOQ3K7EntaPaE1%2FufwdtEiFICxLaABemyOxC8dA7MII5NQHLckHv0%2F%2Frhb2qkUIC9w%2BboHMtGqHx2QYBbGECceSXtnBYJQPAAXbhqA%3D%3D%7Ctkp%3ABk9SR9yBoMvNYg
Post by: DomP on September 07, 2023, 07:28:25 AM
Thanks Trigger, for now I'm reserving all my funds for this damn engine.  What is the rotor thread for removal, m16 x 1.5?
Post by: Trigger on September 07, 2023, 08:01:24 AM
That size is correct. Looks for a car wheel nut at that size, thread it in by hand attach a impact gun and it is off  ;)
Post by: Oddjob on September 07, 2023, 04:31:24 PM
If you've got other Hondas or are maybe planning to buy them in the future this is the tool I use.
It's a genuine Honda tool and works really well, never failed yet. I just find the right thread, thread it into the rotor and hit one of the cross pieces with a rubber mallet. It's not as cheap as a bolt but you don't need an impact driver.
https://www.davidsilverspares.co.uk/CB500K1-FOUR-1972/part_61715
The upside of buying genuine tools is they sell really well when you no longer need them, usually for more than you've paid as they are always going up in price. Plus they tend to make working on the bike so much easier, I have hundreds of genuine tools, pity your not closer, I could pop round and let you use them. You'd be able to borrow my valve compressor as well  ::)
Post by: DomP on September 07, 2023, 05:25:04 PM
Thanks Ken, you'd be welcome as its getting on my eaves a bit.  Interestingly an M16 x 1.5mm bolt isn't the right size on this rotor the thread looks a bit smaller than 1.5mm comparing it to the bolt I've bought.  Genuine tool it might be then.
Post by: K2-K6 on September 07, 2023, 05:37:51 PM
 :o Oh no, not thread pitch again  ;D
Post by: Trigger on September 07, 2023, 05:42:03 PM
Someone must of buggered the thread Dom, you will have to use a pulley to get it off  ;)
[attachimg=1]
Post by: DomP on September 07, 2023, 05:47:01 PM
The thread looks clean as, could the bolt be 1.75mm?!
Plan B in action
Title: Re: Doms CB550F1 project
Post by: Oddjob on September 07, 2023, 05:47:50 PM
I'll check the rotors I have off at present, thread the tool into them and then check the pitch and let you know.
Post by: Trigger on September 07, 2023, 05:51:28 PM
Plan B in action
Defiantly a 1.5, just tried it on 3 different ones. Unless they have put a 400 one on  :o
Post by: Trigger on September 07, 2023, 05:55:43 PM
[/quote
 ;D ;D ;D ;D
Post by: Oddjob on September 07, 2023, 05:58:22 PM
Just checked the Honda tool and they are all 1.5 pitch, the arms are marked 16, 18, 20, 22.
Check the bolt supplied to be 100% sure that's 1.5mm and they've not sent something else by mistake.
Post by: DomP on September 07, 2023, 06:12:08 PM
I'll blame the bolt I got from my local tool hire shop, it cost me nothing as they couldn't be bothered to charge me for it.
Post by: Trigger on September 07, 2023, 06:32:23 PM
You can not any old bolt, if it snaps you will have another problem. The bolt needs to be high tensile and that is why a car wheel bolt is ideal  ;)
Post by: Seabeowner on September 07, 2023, 06:40:52 PM
I used a bolt from a Fiat van. Got the end turned down like the real tool. No impact, so tighten, hit with mallet, tighten, hit with mallet and they pop off.
Post by: DomP on September 08, 2023, 04:42:29 PM
It was high tensile
Post by: DomP on September 08, 2023, 04:46:01 PM
I've taken the rocker arms out to remove the springs that a previous owner had felt the need to fit, literally just cut up springs! Doesn't appear to be and damage caused
Post by: Trigger on September 08, 2023, 05:33:00 PM
I am always shocked on a fair few engines that i have stripped and done an assessment report. Some have been complete horrors  ;)
Post by: DomP on September 08, 2023, 06:09:20 PM
Is there meant to be a small amount of side to side play in the rocker arms then?  I assume that's what they were trying to alleviate.
Rotor off tomorrow hopefully then I'll be able to see tge extent of the wear a bit more, fingers crossed!  Is there a point at which engine wear isn't salvageable, I might as well prepare myself🤣
Post by: Bryanj on September 08, 2023, 07:29:45 PM
Yes, cranks are not regrindable and broken cases are a problem but i,m sure between forum members we can get most stuff
Post by: K2-K6 on September 08, 2023, 07:39:37 PM
Yep, hoping your crank is not like an LP record for grooves  :o as that's one of the eventuality this oil and wear situation produces.
Fingers crossed for good outcome.
Post by: DomP on September 08, 2023, 07:51:19 PM
Post by: Trigger on September 09, 2023, 01:47:03 AM
All engines are salvageable, it is just down to cost  ;)
Post by: DomP on September 09, 2023, 08:40:38 AM
Received my replacement hub from Andy yesterday, it certainly looks like the correct part and a few measurements all match up and plenty of lining left so fingers crossed that's one thing sorted.  I'll wait until I get stainless spokes before relacing it, bigger fish to fry with the engine I think but at least while it's stripped I'll have the perfect opportunity to paint the cases etc.  Simoniz engine enamel or its Diuplicolor equivalent?
Post by: DomP on September 09, 2023, 09:27:41 AM
I don't think I intend keeping the Motad exhaust and the seat (which I think isn't from an F) that came with my bike, are they worth much in fairly good condition?
Post by: Bryanj on September 09, 2023, 01:17:05 PM
Not a vast amount but always worth something to somebody, dont be caught out by shipping charges if it stays in one piece
Post by: Oddjob on September 09, 2023, 03:36:17 PM
I think the ones in the Titanic may disagree with you.  ::)
I wonder why they thought springs on the rockers a good idea? I can see them getting confused, the 400 has them, why hasn't mine, maybe I lost one? Maybe but you don't lose 8 of them so clearly they were never fitted.
Post by: Oddjob on September 09, 2023, 03:49:35 PM
Couple of alternatives for you to consider Dom.
The 550F seat is rare, really rare. Not sure why but they are and when they do come up you get offered seats which TBH should be consigned to the bin. Pans are normally rusted out etc.
The 500 seat however is still available, even copies are going about these days but you can still find NOS ones if you are willing to wait and willing to pay for them. OR, a good second hand one might pop up. Same could be said about the 550F but IF a good second hand one comes up be prepared for a bidding war as everyone and his dog will want it.
The downside to fitting the 500 seat is that it doesn't fit the 550 tank, however if you change the tank to the 500 as well they should marry up quite well. The mounting points etc are the same. 500 tanks are easier to find as well and the sale of a good 550 tank should pay for one and leave a little left over. Personally I think the shape of the 500 tank is better as well.
Now the 550F seat had it's tools stored in it, the 500 has them in a tray above the air filter. Ditch the snorkel fitted to the 550 and fit the tray off the 500. Roo has one spare if needed.
The 550F original exhaust is almost unobtainable, so your never going to get a bike that is standard unless you win the lottery, so consider going near standard but without the expense. A Delkevic exhaust is available in stainless, so no rust, looks better than the Motad as well.
Just food for thought.
Post by: DomP on September 09, 2023, 08:23:58 PM
Oh I may have not made sense before, I'm planning long term to fit one of the straight Delkevic exhausts and will make a cafe racer style seat so both parts on my bike will either be stored or sold to add to funds for this damned engine.
Post by: DomP on September 10, 2023, 12:37:29 PM
This morning I've split the cases which were again stuck together with the red stuff (forget the name), I hope I'm not being overly optimistic here but it looks far better internally than I was expecting.  No scratching on the crank which although polished feels smooth across the face with a fingernail.  Primary and Cam chains are both past their best.  What does everyone think?
Post by: Nurse Julie on September 10, 2023, 12:57:45 PM
Lots of pitting on the shells and a gouge out of the left side.
Post by: DomP on September 10, 2023, 02:17:17 PM
OK, so I need to be determining what colour shells I have fixed and replace all marked shells? The crank appears OK to me
Post by: Trigger on September 10, 2023, 02:33:16 PM
Gear box dogs look fine. I would plasti up the shells as long as you run your finger nail across the crank journals and don't feel any grooves  ;)
Post by: DomP on September 10, 2023, 03:24:29 PM
Can't feel a thing Trigger, I'm not sure what step to take next to be honest...strip it all out and clean it up and check bearings?  From what I can see the primary chain hasn't either the casing at all.
Post by: Oddjob on September 10, 2023, 03:34:06 PM
Far better than I expected Dom.
You need to rotate the gearbox and take another pic, although it looks fine in the pic posted there could be damage underneath we can't see.
Shells don't look that bad TBH, some minor pitting, most likely from contaminants in the oil sitting against the shell when it's been stood. Crank journal we can see looks ok.
Primary chain looks toast TBH, but check with the tank track test and see what it looks like then. Strip the engine completely, if nothing else it needs a really good clean.
Gear selectors look fine.
Anything sitting in the sump? little bits etc.
Looks like the dreaded red hermetite or instant gasket, really plastered it on either way.
Can you see the crank markings? the printed letters and numbers? What are the letters on the back of the lower crankcase as that will show what colours you should have fitted, well within 2 colours anyway.
Need more pics but looks good up to now.
Post by: Bryanj on September 10, 2023, 04:57:20 PM
Again looks ok apart from dreaded rtv jointing which has killed many honda engined after blocking restrictor jets.
Take everything out, remove ALL the orange krap an thourouly clean everything.
I would plastigauge the crank and check clearance.
REMEMBER to keep all shells in the place they came from
Post by: DomP on September 10, 2023, 05:46:57 PM
All conrods are marked E and 2, the lower crankcase is AABBB, all of the gears are clean when rotated, no chips or marks.  The sump had some fragments of hardened rubber that I assume must be from the camchain tensioner although there is a tiny bit missing from the nylon oil deflector (?)
While I'm in here I think for the sake of £48 I might as well do the primary chain, clocks show 32k if I trust they are original, or the engine for that matter as I've not checked.  Replace al oil seals and bearings too?
Post by: DomP on September 10, 2023, 06:50:37 PM
Yes I'm moderately pleased with what I've found, glad I cracked it on too!  Looks like I'll be needing your cylinder reboring services Bryan, would it be jumping the gun to go ahead and get it to you?  IMD or David Silvers piston kits?  Obviously I'll hold off on them until you know how much oversize you have to go.
I'm still tempted by a cam reprofiling while it's all apart if it will be a worthwhile improvement, if my pocket allows!
Post by: Bryanj on September 10, 2023, 07:12:57 PM
You can bring me or send the block, i dont do any blasting, cleaning or painting  thats down to you.
Put up a pic of the inside of the lower case and lets see how much the chain has et away, 550 usualy less than 500.
Mileage dont mean much on an old bike, it could have babied or totaly hammered, i know the primary dampers are as expensive as the chain but they will be rock hard now so need changing.
There will be markings on the crank for pin sizes but if you cant find them bring up the crank and i will mic it for you
Post by: DomP on September 10, 2023, 07:32:57 PM
Ah don't worry I'm quite happy doing the clean and paint side of things😉  I'll definitely be doing the primary dampers, I'm a bit unsure what you mean by pin numbers?
Lower case has survived quite well I think.  Maybe I'll call you this week at the times you said now that i know better the state of things.
Post by: K2-K6 on September 10, 2023, 08:00:04 PM
Agree that the bottom end assessment shows a pretty good condition overall.
Something weird about it as barrels upward are generally well worn, in big contrast to the bottom end. Looks almost like two different engines have been combined that have very different service history.
Post by: DomP on September 10, 2023, 08:20:52 PM
I suppose that's always a possibility, the barrels are quite scored and from everyone's views on here I feared I'd find a right mess.  I feel a lot more positive and about it now.
Post by: Oddjob on September 10, 2023, 08:44:52 PM
I'm not so sure Nigel, the damage to the liners could be because of water damage etc rather than wear.
You can see where the primary chain has worn partly through the main oil gallery but you can also see it's rubbed on where the camchain tensioner goes as well, which makes sense of why I'm finding so many damaged at the very bottom. It's even worn a slight groove higher up, clearly it's been lashing around.
If you look closely at the crankshaft Dom you'll find some printed numbers and letters, exactly like the ones you can see on the rods. They can be very hard to see, washing the crank in petrol can help. They are all in a line, so if you find one you should be able to see the others without turning the crank.
Yours crankcase letters are good, the A's can only be yellow or green and the B's can only be green or brown. So no blacks, which is good news.
IF you were going to replace them I'd go with 4 greens in the A journals and 6 Browns in the B journals.
You need to split the rods now and check how those shells have lasted.
Post by: DomP on September 10, 2023, 09:03:46 PM
Thanks Ken, that's good news then re the shell colours.  Are we thinking I need to plastigauge all shells on the crank and conrod then?  excuse my ignorance but what colour or range should I get?
Post by: Oddjob on September 10, 2023, 10:47:17 PM
Well I’m not thinking that. If I could see appreciable wear then maybe I’d recommend that. But I don’t see wear, some slight damage but that’s from contamination.
Now you can either reuse your existing ones or change them for new ones, that’s your choice, remember though that there are 18 shells and most are around £15-20 each, so the best part of £300-400, Then a pair of chains and damper rubbers, another £150. Then gaskets, seals, orings, roller bearings etc.
Not cheap eh
Post by: Bryanj on September 10, 2023, 10:50:01 PM
By pins i meant crank pins i.e. big end and mains, sorry i was talking machinist!
Post by: Bryanj on September 10, 2023, 11:00:20 PM
Forgot to say if you do want to reprofile the cam i have i just picked up from a member in cheltenham who is leaving for portugal and it has slight wear on one lobe so ideal to send away and keep your standard one if in good nick
Post by: Oddjob on September 10, 2023, 11:28:11 PM
I asked Newman cams if they could reprofile a rocker arm and they said yes, they hard chrome them then grind back to original shape, never knew they did that.
Post by: Trigger on September 10, 2023, 11:33:05 PM
I would strip the crank down to clean out all the traps as that sealant gets everywhere. Once all cleaned, plasti to see if any of the shells are worn. If it is to spec, you should be good to go with the crank and rods  ;)
Post by: DomP on September 10, 2023, 11:48:22 PM
I'll strip the crank tomorrow evening once I've ground a socket down to fit the conrod nuts, im concerned the small end on cyl 4 conrod might be worn, it feels looser tha the other three.
Post by: Oddjob on September 11, 2023, 01:25:39 PM
Rods were originally fitted with either green or brown shells Dom. Which is good news as those are easy to find. IF you need them of course.
IF you end up having to replace a rod you'll need to find another with the weight code E on it. Might be easy, might be hard.
Post by: DomP on September 11, 2023, 05:11:23 PM
I can't make any sense of the crank markings, would they all be same across the entire crank?  I forgot to pick up a socket to grind down today as well so I'm at a bit of a loose end tonight
Post by: Deano400 on September 11, 2023, 05:42:29 PM
Like these markings in yellow Dom. Ignore the red marks.
[attach=1]
Post by: Deano400 on September 11, 2023, 05:43:16 PM
This is a good example. More often very difficult to see.
Post by: DomP on September 11, 2023, 06:01:57 PM
Thanks matey, I can see the marks just not able to work out what they say as mine are black.  I've butchered one of my 6 sided 12mm sockets now so I've had the conrods off, all looks good on the shell faces and crank.
Post by: Oddjob on September 11, 2023, 07:36:32 PM
The 400 tended to get white marks and the 500/550 black ones. Those are really clear John. Can't mistake those.
Post by: McCabe-Thiele (Ted) on September 11, 2023, 07:42:31 PM
If 550 conrods are the same as 500  ones I have a set going spare - just postage cost if it helps.
Post by: Deano400 on September 11, 2023, 08:04:14 PM
The 400s are hard enough to see after 40 years, I guess the 500/550 must be nigh on impossible,
Post by: Nurse Julie on September 11, 2023, 08:27:43 PM
The very early 750/4 crank markings are in Japanese and you have a translation document to use 😱😱😱😱. Most of the time the Japanese markings are so feint, you can't decipher them at all.
Post by: DomP on September 11, 2023, 08:56:08 PM
Thanks Ted, that's very generous of you.  I'm still trying to work my way through it all at the moment so may take you up on the offer.
All the roller and needle bearings feel smooth, am I OK to reuse or should I be replacing them at this stage?
I need to decide on the most cost effective way of buying the gasket sets and oil seals.
Post by: Oddjob on September 11, 2023, 09:01:19 PM
Depends what marks are on them Ted, not the letter but the number. If they are all number 2 then they'll be fine and he can reuse existing shells.
Post by: Trigger on September 11, 2023, 09:13:28 PM
You can not go by crank markings as, the markings are for a new crank and not a worn one. Everything needs to be measured and matched. All con rods have a weight in grams and must match and that goes for pistons also  ;)
Post by: Oddjob on September 11, 2023, 09:15:25 PM
I disagree. So long as the crank doesn't show wear it will be fine.
Post by: Trigger on September 11, 2023, 09:25:28 PM
The eyes lie to people that don't know what to look for but, measuring up is the only way to get a accurate measurement.
I would never build a customers engine and assume that it looks OK  :o
Post by: Bryanj on September 11, 2023, 10:32:29 PM
Only problemGraham its only old sods like me and thee that can read a mic accurately, and know how to zero it!
For home mechanics plastigauge is a boon but can get expensive on shells
Post by: Trigger on September 11, 2023, 11:37:10 PM
I always wondered why i have that big tool box full of measuring equipment. Next time you do a rebore, as long as the piston fits in the hole it should be fine mate  :o :o :o
Post by: McCabe-Thiele (Ted) on September 11, 2023, 11:50:34 PM
Might be difficult to find a Conrod of the same number - could it just be a worn Gudgeon Pin causing the problem?
Post by: Bryanj on September 12, 2023, 02:16:49 AM
I can do you a set of 4 rods if you need them, would have yo check codes on them
Post by: Oddjob on September 12, 2023, 04:49:04 AM
That’s a completely condescending comment Bryan and frankly insulting to a lot of members. Using a micrometer isn’t hard and digital micrometers have a zero button these days.
I’ve build hundreds of engines and never ever used plastigauge, it’s not rocket science to spot wear. It doesn’t take years of experience to spot it either. Most members on here are more than capable of tackling these engines, it’s insulting that you seem to suggest that only you can do these simple engine rebuilds. It’s not got VTEC, it’s not a V4, it’s a extremely simple design that almost everybody can get their head around.
Post by: DomP on September 12, 2023, 08:11:28 AM
So going back to my last question-
Is it good practice to replace all needle, roller bearings in the gearbox etc or if they are smooth with no play can they be reused?
If I were to plastigauge what colour should I use, from looking I think red?
Post by: Trigger on September 12, 2023, 08:20:20 AM
They can be reused if still good and the best way to spot if they do need replacing is have a good look at were they run on the gear box shafts. They show signs on the shafts first  ;)
Post by: AshimotoK0 on September 12, 2023, 08:28:39 AM
https://www.ebay.co.uk/itm/404405436283?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338365712&toolid=20006&customid=EB151264548&
Post by: Bryanj on September 12, 2023, 08:59:19 AM
Ken, in no way was it meant that way, its not condescending as most builders on here have not had the experience of using micrometers and verniers are just not accurate enough.
It is my opinion that standard micrometers are not accurate enough to measure the very small differences in pin tolerance the Honda use.
I know originally they used air gauges that are accurate to the 4th decimal place in metric and i dont think there is a hand tool made that can be that good.
I can remember being taught in a big machine shop and every student got a different size when measuring the same practice piece, and all were different from the quoted size.
I am not as accurate as i used to be and on the last 400 was only certain that all the pins were the same size.
This was not meant to offend in any way and i would more have expected Graham to be upset at being call an old fart, but i did include me in that.
There are some excellant engineers on here but most seem to be home enthusiasts who i am more than willing to help out using whater expensive kit i have aquired over the past 50 years
Post by: Trigger on September 12, 2023, 09:11:33 AM
It is not worth any member going out and buying the correct measuring equipment for 1 or 2 engines. I have lost count on how many members i have had in my workshop asking, if i could measure up everything so they know it is correct. And some i have found that they had at least one rod that was slightly oval. That would of all ended in tears if they had used it.  ;)
Post by: Bryanj on September 12, 2023, 10:08:40 AM
I agree Graham, by the time you have decent mics from 0 to 100mm(about 4, i dont like multi anvil ones) decent dti, bore gauge, what do you recon £500 retail?
When i used to do a lot of cars, mostly kent and essex fords, you could guarantee an oval rod if it knocked
Post by: Trigger on September 12, 2023, 10:45:26 AM
I have had loads of rods that needed re claiming, which you can not see that they are out with the human eye over the years and quite a few twisted rods even on SOHC's.
As for the price of the correct measuring equipment it can be very expensive and take a lot of experience to use correctly.  ;)
Post by: McCabe-Thiele (Ted) on September 12, 2023, 12:31:21 PM
Not sure what is meant by reclaiming a con rod Graham?
Post by: Trigger on September 12, 2023, 02:25:20 PM
I think the yanks call it resizing but, i have always known it as reclaiming. I use a Sunnen machine  ;)
Post by: Bryanj on September 12, 2023, 03:01:16 PM
Ted, normal a rod goes oval with the dimension across thr bolts staying standard and other way from rod o cap getting a bit bigger so you carefully take a small amount off the pads with bolt holes in then hone the hole circular again
Post by: McCabe-Thiele (Ted) on September 12, 2023, 04:19:15 PM
That sounds an amazing process - presumably you can still fit an off the shelf bearing shell, I guess were talking a really small amount of metal removal.
Post by: Trigger on September 12, 2023, 06:17:29 PM
Yes, back to standard spec. And you have to do all the rods the same to keep the weight right  ;)
Post by: Seabeowner on September 12, 2023, 06:47:20 PM
Plastigage is cheap. But if you measure out of spec with the clearances and if you can't rely on the crank being as new then you have to buy (or borrow) a pair of new shells to do the measuring with.
Post by: DomP on September 16, 2023, 03:48:46 PM
I've spent the morning plastigauging my crank, the results are very consistent. I won't bore you with every journal but they are to my eye identical across the entire crank, an enjoyable process!
Post by: Bryanj on September 16, 2023, 04:54:00 PM
Cant remember spec, is that within?
Post by: DomP on September 16, 2023, 05:04:16 PM
Haynes says 0.02 to 0.048
My readings were when torqued to the lower end of the range
Post by: Bryanj on September 16, 2023, 05:15:49 PM
Clearance is fine then
Post by: DomP on September 16, 2023, 06:06:20 PM
Thats a relief 🤪
Post by: DomP on September 17, 2023, 07:57:37 PM
Im putting together a DS order for gasket set, primary drive rubbers etc, I'm sure I've read any removed circlips must be replaced with new ones, one looks a Honda specific part but are the rest easily and cheaper to source from Ebay etc?
Post by: Oddjob on September 17, 2023, 09:04:36 PM
Not the gearbox ones, use Honda. The rest should be ok.
Post by: DomP on September 17, 2023, 09:31:28 PM
Do you mean I can reuse the ones under the clutch cover Ken?
Post by: Bryanj on September 17, 2023, 10:53:04 PM
Advisable for new on kicstart shaft inside cases
Post by: Oddjob on September 18, 2023, 02:17:12 AM
No, I meant you can buy cheaper alternatives Dom, not reuse old ones. The ones on the gearbox shafts are special so need to be Honda ones, the rest of them should be ok to use copies. I'd certainly use a new one on the clutch basket for instance and on the kickstart shaft if removed. When you go to replace the primary damper rubbers you'll think you need to remove the 3 screws but IIRC it's just the circlip you need to remove to split it in half. Don't remove the screws unless you have to. Far too many fall out again afterwards.
Post by: DomP on September 19, 2023, 03:28:29 PM
Interesting you should say that Ken, I thought they needed removing too (they dont) so set about taking them out with a JIS screwdriver, they were already loose but the staking prevented them from fully undoing by themselves. I'll be making sure they are tight and staked when I put it all together.
The dampers when removed were pretty hard.
Post by: Oddjob on September 19, 2023, 04:39:00 PM
When you fit the new rubbers you may think it's not going to go back together. A little silicon oil on them works wonders.
Post by: DomP on September 19, 2023, 05:03:01 PM
Oh that's good then, there was a very small amount of play in it
Post by: Oddjob on September 19, 2023, 06:37:41 PM
Before or after the new rubbers Dom.
Post by: DomP on September 19, 2023, 09:34:58 PM
With the old rubbers Ken, still waiting on my DS order due to a few backorder but my Cruizinimage pistons are on their way.
Post by: DomP on September 21, 2023, 04:46:30 PM
My plan is to prep the engine ready for paint this weekend except for the barrels as they'll be going off to Bryan for some work.  There's not much paint left on them, just a bit of black remnants from a previously bad paint job so a bit of nitromors and a bit of scotchbriting should sort it.  I was going to use carb cleaner as a final pre paint prep then Simoniz vht aluminium silver paint followed my a 'Millyard bake'
Post by: DomP on September 21, 2023, 07:09:27 PM
I have a question, has anyone on here any experience with straightening bent fins?  I've got a few which are out of sight and minor enough that they can be ignored but two on the cylinder head are top left and obvious.  I've watched a few videos of warming with MAPP gas and carefully tweaking back, do I dare risk it before painting or just accept them as battle scars?
Post by: McCabe-Thiele (Ted) on September 21, 2023, 07:43:23 PM
Think of it as age related patina.👍
Post by: Nurse Julie on September 21, 2023, 07:51:00 PM
If you don't get the heat just right, the alloy easily snaps. Best leave be unless you're doing a concours engine renovation.
Post by: DomP on September 21, 2023, 08:13:02 PM
Ted and Julie, I think you're correct. Let's hope the temptation doesn't get the better of me!
Post by: McCabe-Thiele (Ted) on September 21, 2023, 08:22:12 PM
You will be well disgruntled if one snaps as NJ has warned you.
Post by: K2-K6 on September 21, 2023, 08:22:45 PM
Agree if you're not confident, to leave it, as snapping a bit off will look worse.
If you waht to try something to feel what it moves like, an old / broken clutch lever of similar, clamp end in vice, put ring spanner on it and pull very slightly to tension load it, then heat with torch where you want it to bend, then you'll feel it yeald as the heat reaches critical point to let it move. No real increase in pressure, just as it comes in range you'll feel it start to soften enough so it moves easily.
Some use soap on surface to see it going brown as it approaches the right heat level too.
Post by: McCabe-Thiele (Ted) on September 21, 2023, 08:56:20 PM
Using soap as a temperature indicator that takes me back to the 1960s.👍👍👍
Post by: DomP on September 22, 2023, 07:54:26 PM
Well Cruizinimage have delivered, quite literally!  Ordered my pistons Sunday night, on my doorstep this afternoon.  I won't even get them to Bryan that quick!
Post by: Nurse Julie on September 22, 2023, 08:06:11 PM
We have always found their delivery service excellent. On one occasion, I ordered a few piston / ring kits on the Tuesday lunchtime and they arrived Friday morning.
Post by: DomP on September 23, 2023, 07:58:16 PM
It is impressive Julie! I'm going to be needing some oil pump o rings when you're back.
Post by: Nurse Julie on September 23, 2023, 08:03:44 PM
OK Dom. Send me a PM as a reminder and I'll get back to you when I'm back home, (and everyone else that's sent me PM's whilst I'm on my holibobs). Many thanks
Post by: DomP on September 23, 2023, 08:08:16 PM
Today was project crankcases, I've had a few evenings to begin prep work on them so this morning was a cycle in the dishwasher then a dry out followed my a rub down with a scotchbrite.  Because of the lovely weather I was able to get them out in the sun, I made a cardboard box spray booth and hit them with multiple coats of Simoniz aluminium VHT paint that I'd been warming in a jug of hot water, masking up probably took as long as the prep. The finish is pretty good considering the weathered surface on my cases, I think they've been sand blasted due to the bare finish they came to me in and wonder if that might explain the top end wear?
Tomorrow is bake day so I'll fire up the gas bbq, is 2hrs enough at 200 degrees?
Post by: DomP on September 23, 2023, 09:04:18 PM
Should I be replacing cylinder studs if they have a bit of rust and pitting on the shank?  I will get a pic up tomorrow.
Post by: McCabe-Thiele (Ted) on September 23, 2023, 09:20:06 PM
I suspect cylinder studs might be a nightmare to remove without breaking!
Post by: DomP on September 23, 2023, 10:03:09 PM
My suspicions too Ted, mapp gas might help along with soaking in plus gas but maybe they might not need replacing if not too bad because the torque they are set to is actually quite low isn't it
Post by: McCabe-Thiele (Ted) on September 23, 2023, 10:54:00 PM
Yes it is low compared to cars with steel heads!
3 out of my 8 exhaust studs snapped despite heat and a decent stood removal tool.
Post by: Bryanj on September 23, 2023, 10:58:32 PM
Leave them alone they can be a real pig even with heat
Post by: DomP on September 23, 2023, 11:40:07 PM
I'll leave well alone then Bryan, the pitting is what concerned me.  I can just oil the updater a rub down its only a couple of the front studs.
Post by: DomP on September 24, 2023, 11:08:49 AM
I've had a minor setback,  I fired up the bbq having had my cases warming overnight at around 20°C, set them in it at the lowest setting and have been gradually increasing it but I've got small bubbles forming. I did heat the cases through before paint but I'm guessing I still have gassing off?  Is the only option to strip and start again?
Post by: Nurse Julie on September 24, 2023, 11:50:40 AM
Yes, you will need to strip what you've applied and clean cases thoroughly. It's usually oil impregnated in the alloy that causes the blistering.
Post by: DomP on September 24, 2023, 12:10:33 PM
I knew the answer really, my engine was bare alloy when I got it so there could be loads of oil etc absorbed into it.  I degreased, dishwashered it and scrubbed it with thinners so I'm not sure what more I could have done, I'm thinking it's remaining moisture rather than oil so I'll try baking the top half more slowly to see if a gentler temperature gradient helps.  I've got nothing to lose in trying and only time and a can of spray paint if it fails!
Post by: McCabe-Thiele (Ted) on September 24, 2023, 12:25:24 PM
I'm concerned by the mention of a dishwasher what detergent did you use as a normal dishwashing tablet attacks aluminium?
IIRC the paint needs 24 hours of air drying in the summer before heat treatment.
Post by: DomP on September 24, 2023, 12:56:40 PM
Everything I read says dishwasher tablets are fine, I hope they are !  There was no signs of any attack on the bare surfaces.  I've had them drying in an heated room close to an oil radiator for 24 hrs so should be well cured, interestingly the top half has been in the oven now for an hour and is up to 180 with no signs of bubbling so I think it may be the temps rose a bit quickly or i wasnt as thorough on my bottom half?
Oh and didt use salt as we'd run out anyway.
Post by: McCabe-Thiele (Ted) on September 24, 2023, 03:28:02 PM
I put an aluminium frying pan once in our dishwasher - it turned almost black in one full wash cycle, it ended up in the bin.👎👎👎
Post by: Nurse Julie on September 24, 2023, 03:34:32 PM
Most dishwasher tabs are caustic based, and as Ted says, it makes alloy go black.
Post by: DomP on September 24, 2023, 04:37:08 PM
Well I think I must have dodged a bullet there as it looks no different to when it went in, just cleaner.  What does everyone use in theory dishwashers when doing this then, nothing I've read has suggested anything different.
Post by: McCabe-Thiele (Ted) on September 24, 2023, 07:59:31 PM
I heard of a dirty wiring harness going in a dishwasher with a dishwasher tablet.
Post by: DomP on September 24, 2023, 10:34:31 PM
I think I've read that on xs650.org,  I'm really hoping I've done no lasting damage now, there's certainly no visible damage.  I defiant recommend a gas bbq to bake though, it's no where near controllable enough and mine smoked leaving marks on the new finish with the lower half.  Top half came out of the oven having been raised to 200°c for 2hrs looking perfect, no sign of any micro bubbles, my parrot loved it because it meant he got to spend the day in the living room away from any dodgy fumes.  That paint stinks when baked!
Post by: DomP on September 25, 2023, 08:09:48 AM
Nearly done with painting the crankcase etc, the minor disaster with the bubbling lower case seems to be resolved.  One thing I've been meaning to mention is the camchain wear on the sides of the case, I've not seem this mention as a place for wear before, is this normal?
Post by: Bryanj on September 25, 2023, 08:52:12 AM
Not common, bring the tensioner complete with you when you come up and i will check it out for you
Post by: DomP on September 25, 2023, 09:26:59 AM
It explains the silvery non magnetic sump residue
Post by: DomP on September 27, 2023, 09:39:32 PM
I have a few questions regarding o rings that may not be in, or may need upgrading from the Vesrah full gasket set, namely the oil jet o rings that I've read may need to be thicker than those supplied and will I get the small o ring for the camchain guide mounting bolt?  I know I'll need new pucks (pontefract cakes) and oil pump orings from Julie.
Post by: Oddjob on September 27, 2023, 10:09:14 PM
The tensioner ring is 5.8 x 1.9mm Dom. Should be in the kit. Measure how thick the head gasket is first.
I can supply rings for the oil pump if you need them.
Will look for that lock washer etc tomorrow
Post by: DomP on October 03, 2023, 09:35:05 PM
I've ordered new bearings for the selector drum and primary shaft, two are easily removed but one on the primary shaft is really on there.  I think I've read Ken saying it can be rested in a loose vice and the shaft carefully tapped through, have I understood this correctly?
Post by: Oddjob on October 03, 2023, 09:53:26 PM
Spot on, just open the vice wide enough for the shaft to move and tap the end.
Post by: DomP on October 03, 2023, 10:36:30 PM
Thanks Ken, I was just surprised it was such a tight press fit compared to the other end
Post by: DomP on October 04, 2023, 04:21:21 PM
How much force is needed to get the bearing off? I've smacked the hell out of it, any more and I risk damage to the shaft end.  The bearing hasn't budged but is now probably not in great condition
Post by: Oddjob on October 04, 2023, 04:31:07 PM
All mine just fell off Dom. Try some heat and see if that helps. I have a few of the shafts if you bugger it up.
Post by: DomP on October 04, 2023, 05:37:06 PM
I'll get my mapp gas on it Ken
Post by: DomP on October 04, 2023, 06:00:22 PM
Bingo! Got it hot and off it popped with a big whack Ken, I tapped the new one home using a 21mm deep socket and then the last bit with an old 6205 bearing as a spacer to get the extra depth needed that the deep socket didn't have.  I think that makes sense but essentially a success.
Post by: DomP on October 22, 2023, 08:10:48 AM
Yesterday I travelled to Bryan to pick up my .5mm rebored barrels, I assembled the bottom end when I got back using what I thought was the thinnest layer of Hondabond, maybe it was due to my garage being pretty cold but it was near impossible to brush on.  I ended up dabbing it on with my finger to get a thin covering.  When I torqued all bolts down I got a small amount of sealant squeeze out which is now concerning me, in my haste, ok it was excitement, I missed to hondabond the two crank end seals.  Do I need to split it an do it all again?
Post by: Bryanj on October 22, 2023, 08:48:26 AM
Nope, it should be ok as long as case uo to edge of seal was done, seals are slightly oversize so should clamp ok.
As to sealant squeezing out a small amount is ok
Post by: DomP on October 22, 2023, 09:18:14 AM
It really was a tiny amount Bryan, I went to bed lastnight thinking I'd be having to split them again today.  I got the piston rings all fitted and all together on the conrods, really glad to see no play in the gudgeon pin on no4 cylinder like with the old piston and pin.
Post by: McCabe-Thiele (Ted) on October 22, 2023, 01:31:33 PM
I also  tried & failed to apply Hondabond with a brush even in the warm it was just too thick. In the end I wore a pair of disposable gloves, I would squeeze some Hondabond on the back of my left hand.
I then used my right forefinger to transfer small amounts of Hondabond onto the inverted upper crancase - this seemed to give me the thinest layer of sealant. Bearing in mind my three Groundhog days (http://www.sohc.co.uk/index.php/topic,23291.225.html) I became very well practiced in the art of thin film technolgy.
I can't claim this method of application was my idea NJ gave me the tip, probably from years of applying ointment during her years of Nursing.  ;D ;D ;D
Post by: Oddjob on October 22, 2023, 02:54:41 PM
I've always used the fingertip dab method, seemed logical to me at the time in order to get a thin film.
Post by: DomP on October 25, 2023, 07:43:05 PM
This weekends slow progress, I got down into the pub by my brother in law so that halted things.
Post by: McCabe-Thiele (Ted) on October 25, 2023, 09:06:00 PM
I would pop some grease on those stud threads Dom.
Post by: DomP on October 25, 2023, 09:35:08 PM
Bryan suggested I didn't put anything on the threads as it mucks with torque settings.  Might have a bit of a hold up with my barrels now though.
Post by: McCabe-Thiele (Ted) on October 25, 2023, 10:34:09 PM
Oil or WD 40 then as they look so dry - I would be worrying about any more rust forming.
Post by: DomP on October 25, 2023, 11:41:37 PM
I think they appear dryer/rustier than they are in the photos but I'll wipe them down with WD40 for you Ted😉  I was thinking of putting some rust treatment on the shafts of the exposed studs to protect them once fitted.
Hopefully get this thing started before Christmas!
Post by: Laverdaroo on October 26, 2023, 01:11:51 AM
Looking good Don, that’s great progress and the cases look fab
Post by: Oddjob on October 26, 2023, 04:10:16 AM
Bryan is right about grease potentially mucking with torque settings. However, having threads like those with nothing done to them can also cause problems. The threads can getting damaged when the head and barrels are removed just by the rust/debris/crap that’s around the threads when you go to remove them. I always run a good die down the threads to make sure any rolled over threads are cleaned up, I’d also give them a thin smear of molybdenum grease before fitting the barrels, just to protect them from rust over the years they’ll be exposed. I also used to grease my threads and use a slightly lower torque setting to compensate for the grease. Around 2-3lbs lower. Around 14ftlbs iirc. Modern Hondas started to spec pressures with the threads oiled. TBH I think a lot of them got oil on the threads and especially the nuts back in the day, common practice was to throw all nuts/bolts in a tub as you dismantled the engine, we knew where they came from, we didn’t need to have them in separate boxes for example, lots of other stuff also got thrown in the same tubs, stuff dripping with oil, so the head nuts would be soaked in the oil coming off those parts. Didn’t seem to cause any problems back then tbh.
Post by: DomP on October 26, 2023, 08:00:52 AM
I have no intention of putting it all together without cleaning those threads up so don't worry about that, when doing work on my cars I've always used copperslip and reduced the torque 5-10%.  My thoughts were in alloy I'd rather not risk slippery threads and lower torque on gaskets
Post by: DomP on October 27, 2023, 12:52:17 PM
Ted, you'll be pleased to hear I spent a wile on my studs and threads lastnight.  Got them nice and clean then a wipe over with some oil until I can get it all back together again.  The threads were quite dirty but perfectly formed, no damage evident.
Post by: Laverdaroo on October 27, 2023, 01:25:25 PM
Skills
A satisfying job whe you’re on with it
Post by: DomP on November 07, 2023, 06:01:59 PM
Has anyone painted over powdercoat?  My frame has a few scratches and chips that I really can't be bothered going to the trouble of stripping it for, I tried touching them in with Rustoleum combicolour as it's what I painted my XS650 with but it's very obvious that it's a different black and sheen level.  I tried rubbing it back with some 0000 wire wool to matt it but it hasn't worked.
I'm now thinking of keying the entire frame and painting over the powdercoat with combicolour.
Post by: Johnny4428 on November 07, 2023, 08:43:59 PM
Guess it would be like painting plastic maybe. The first time my 750 frame was powder coated it got a mark on the rear frame from taking it out of the oven. I5 was only about the size of a finger nail but unfortunately on a visible part of the frame. I suggested touching up with paint but the powder coated said no and acid dipped and stripped and coated it all over again.
Post by: McCabe-Thiele (Ted) on November 07, 2023, 09:24:07 PM
I believe Hammerite Smooth will pretty much stick to anything so if out of view shading might not matter
Post by: DomP on November 07, 2023, 10:03:17 PM
I think I'll get it out in natural daylight to make a decision, if it stops raining!
Post by: Bryanj on November 07, 2023, 10:11:15 PM
It used to, but like a lot of the good stuff its been altered and aint so good anymore
Post by: DomP on November 07, 2023, 10:40:02 PM
Combicolour is really good Bryan, flats out even when brushed on which is one of its claims, even better if you warm it and the workpiece while using it.  It does claim to be ok over powdercoat as its recommended for industrial use on machinery etc.  I'll do a bigger test patch I think then give it the scratch test!
Post by: DomP on November 12, 2023, 10:13:44 AM
Yesterday I bit the bullet and lopped off the rear seat bracket to weld in my upswept hoop, I've not done much welding but nothing watching a few YouTube videos couldn't sort.  I've noticed another peculiarity with my right foot peg, it's an F so has the fold up peg but when down the rubber sits sloping forward rather than being horizontal like the left side, could it be a peg from another model?  It looks identical to the parts fiche on CMSNL.
A bit of a side note but I've noticed my frame and engine numbers match, I thought this rarely happened and given the mix up of parts on my bike I'd assumed the engine may not be original.
Post by: McCabe-Thiele (Ted) on November 12, 2023, 12:35:59 PM
I believe it might just be common wear on the footpegs - my 500 ones are the same
Post by: DomP on November 12, 2023, 02:09:23 PM
Ah you're thinking I mean not horizontal sticking out from the bike but I mean as in rotated about their axis.  It is l located on the frame tab correctly.
Post by: mickwinf on November 12, 2023, 03:56:02 PM
They can get bent if dropped at some point, also designed to rest against the kick-start.
Post by: Oddjob on November 12, 2023, 04:08:32 PM
Remove the footrest rubber Dom and check to see what shape the bar is, the 500 and the 550 used different shape rods, IIRC, the 500 used square type and the 550 flat type. As the 550 uses footrest rubbers that are held by bolts going through the rubber and threaded into the bar and the 500 doesn't have that, if you swap the bars over and drill holes for the bolts unless you get them right they don't line up and the rubber sits at an angle.
Post by: DomP on November 12, 2023, 04:10:56 PM
I think you're misunderstanding me, it's not bent it's rotated to the wrong angle which isn't possible from a drop.
Post by: DomP on November 12, 2023, 04:12:05 PM
This sounds far more likely to me Ken, I'll go take a look and a few photos
Post by: DomP on November 13, 2023, 06:09:53 PM
Here's some pics-
Post by: Oddjob on November 14, 2023, 03:57:11 AM
Something not right there Dom. The rear brake pedal is miles too high for starters. The dot on the pedal and the dot on the rear brake actuator arm are supposed to align.
Post by: DomP on November 14, 2023, 04:14:52 PM
Thats because I've got the rear end in bits
Post by: Oddjob on November 14, 2023, 04:48:19 PM
Try turning the peg down on the bolt
Post by: DomP on November 14, 2023, 05:41:04 PM
In this photo you can see that it's located in the notch on the frame so won't rotate any further, the other way would be the wrong direction so i can only assume it must be the wrong peg for this bike
Post by: Bryanj on November 14, 2023, 05:58:11 PM
I am probably wrong but i seem to remember the tand on the footrest bar locating againg the frame peg that sticks out
Post by: Oddjob on November 14, 2023, 06:18:34 PM
Yeah, forgotten about that TBH Dom.
Footrest looks correct TBH. Special one fitted to the 550F due to the kickstart needing to fold right out to miss the standard 4 into 1 exhaust. It might be possible to fit the 500 footrest onto the lower bolt if you're not using the standard exhaust.
Post by: DomP on November 14, 2023, 06:50:05 PM
Yeah that's correct Bryan
Post by: andy120t on November 14, 2023, 07:14:11 PM
I'm pretty sure I have the same on a 550f frame. Funny flip-up peg to avoid kickstart exhausts etc. with the peg in a different location to the K models.  I assumed the foot rest was angled forward to give a sportier lean forwards towards flat bars on the F model.
Post by: Oddjob on November 14, 2023, 07:35:19 PM
I'd try a 500 footrest if it bothers you Dom. Locate it on the lower bolt, although that may mean buying the double ended bolt with it being longer. The left hand footrest is essentially the 500 so it would match better as well. You need to drill the bar to take the bolts holding the hero plate on but that's it I reckon.
Post by: DomP on November 14, 2023, 08:00:18 PM
I thought this too until I noticed the left side
Post by: Oddjob on November 14, 2023, 10:38:04 PM
I wonder if anyone with a 550F and a 500 could try and see if the 500 footrest would fit so long as you're using an aftermarket exhaust?
Post by: DomP on November 22, 2023, 09:12:38 PM
Not much progress lately, a bit more plating of bolts and brackets but other than that I need to paint the frame ready to get the engine back in and put together the top end.  I think for now I'm going to skip getting the camshaft reprofiled, I can always revisit that next winter.
Post by: DomP on December 03, 2023, 08:53:14 AM
Yesterday morning I managed to drift the swing arm bushes out, the tube that runs through them had well and truly seized onto them so lots of blow torching sorted that.  What I have noticed now is that my swing arm sounds like like a child's rattle, lots of loose rust inside, how can I get it out?  It sounds solid enough when tapped so I don't think there is any terminal rot, I might drill a small hole and inject some Bilt Hamber S50
Post by: Oddjob on December 03, 2023, 09:29:03 AM
Look at the back of the arm, on the inside edge near where the cain adjusters are welded on there is a small vent hole drilled into the arm. Clean the hole as it normally gets partially blocked with rust flakes. A small straw or something similar inserted in hole and jiggled whilst shaking the arm will allow the rust to drop out
Post by: DomP on December 03, 2023, 09:49:30 AM
I thought there should be a venting hole, must have been powdercoated over, I'll have a look.
Post by: DomP on December 03, 2023, 12:20:09 PM
None on mine Ken, doesn't look like they've been painted over at there's no evidence.  The most rattly but is the pressed bracing plate that has no vent hole either so I will just drill my own and flush it out
Post by: DomP on December 03, 2023, 02:51:29 PM
All cb550 swingarms on Ebay are missing drainage/vent holes, would it be sensible to drill a 3-4mm hole so I can flush the crap out and put cavity wax in?
Post by: Oddjob on December 03, 2023, 03:48:53 PM
The CB500 swinging arm certainly has them and it's essentially the same arm.
Post by: DomP on December 03, 2023, 04:47:04 PM
Shall I just pop a couple of holes on each side, wouldn't at the lowest point on the underside be the best place to allow condensation to drain out?
Post by: Oddjob on December 03, 2023, 05:13:05 PM
I'll take a pic of the 500 arm, it may be that the hole is there but so blocked and painted over that you can't see it.
Post by: Oddjob on December 03, 2023, 05:14:27 PM
https://www.ebay.co.uk/itm/314995246801?hash=item49572e06d1:g:zqgAAOSwQbNlZh7B&amdata=enc%3AAQAIAAAAwF%2FweM8O98kTru5%2B7Nwb27qwvYviYl8ad9Dns%2BNX51SArPK5SE7uqP3hqHbnaoTDgXe7XzDOEkBq2mfrUK0oVubNz6HFMD7B%2Fl%2Feqj46nppPTpMOA4W%2B4sL1%2Btku9%2FVgjxJYIAVBiB2L3j81ompIjRQij2P4wzIa84aVY6KlWlmrzwkPzGPoTIrRuvJI%2BTiroeQo%2BLd9uXh2a601T%2FsllI%2FtbpRzugJYVswV2zEDXmBOzmFIdYkd50dvescZrKT35w%3D%3D%7Ctkp%3ABk9SR8a83IqGYw
7th pic, you can see the hole.
Post by: DomP on December 03, 2023, 05:58:20 PM
I'll go out and wire brush it to see if it's there,  why would they put it there and not at the lowest point to allow draining?  Water will pool in the bottoms on those
Post by: Laverda Dave on December 04, 2023, 09:16:36 AM
I'll go other and wire brush it to see if it's there,  why would they put it there and not at the lowest point to allow draining?  Water will pool in the bottoms on those
It could be because if they put the hole in the bottom it could potentially allow water to find it's way in especially when you consider this is directly behind the rear wheel and subjected to the spray thrown off the rear tyre.
Post by: Oddjob on December 04, 2023, 11:22:13 AM
I'd do the hole where Honda put it on the 500 Dom, I'm using the same hole to fill both sides with Waxoyl after it's been powder coated, then allowing it to drain out afterwards just leaving the layer of wax behind. Do that every few years and it should outlast me
Post by: taysidedragon on December 04, 2023, 11:46:31 AM
Any holes in frames or swingarms are often there to allow the escape of hot gasses during welding. It reduces distortion  I believe.
Post by: Laverda Dave on December 04, 2023, 09:33:43 PM
Rickman put holes in their frames for the same reason Garath. It was also to allow the nickel solution to drain during the plating process otherwise the frame would rot from the inside out.
Post by: Oddjob on December 04, 2023, 11:18:22 PM
The problem though is that the swinging arm, because Honda didn't use seam welding but spot welding which allows moisture to form inside the tubes, this then rusts the tubes from the inside out, hence why you can hear rust flakes tinkling around inside, the holes allow you to get rid of those and also to put something down the tubes to stop any future rot.
Post by: Laverda Dave on December 05, 2023, 09:20:34 AM
Did Honda put holes in all their frames Ken because I haven't seen any on the 400 frame or was it just the 500/550’s?
Post by: Oddjob on December 05, 2023, 02:40:46 PM
I seem to recall there is a hole in the frame on the 500 but at this moment I can't remember where. TBH though, the welded parts, because they aren't seam welds, I'd say the frame doesn't really need them. The swinging arm always had them though but the amount that get those holes blocked by rust flakes etc is high. This topic is odd because not that long ago I did the shaking thing on one of my swinging arms, heard that rattling sound and decided I would stop that, took me about 40 mins to get it all out via the drill hole, the more you shake the arm the smaller the flakes get and they'll drop through the hole after a while.
I bought a basting syringe for meat, that has a small hollow metal needle, I'll fill the syringe with Zinc182 paint, fill the swinging arm till it's full, then allow it to drain through the holes, after that I'll fill with Waxoyl and allow that to drain. That should stop any future rust from developing. For me it's about ensuring the frame etc last as long as possible, I may do the same with the frame tubes if I an find a suitable entry point.
Post by: DomP on December 05, 2023, 05:46:41 PM
I definitely have rust flakes in the swingarm bracing
Post by: DomP on December 09, 2023, 05:56:29 PM
What's the difference in these part numbers? Same screws but one lot are quite a bit more expensive
Post by: Oddjob on December 09, 2023, 07:07:30 PM
B is chromed.
G is black
Also an A which is BZP.
There is one with no letter, probably plain steel
Post by: DomP on December 09, 2023, 11:44:15 PM
Oh thanks Ken!
Post by: DomP on December 16, 2023, 11:11:02 AM
I've had some progress having got the lower half of the engine back in the frame, I've started refitting bits like the starter motor but have a question, how do I hold the crank still while I torque up the rotor bolt?
Post by: DomP on December 16, 2023, 11:18:47 AM
I just stuck a strong screwdriver shaft through the rotor to hold it
I have another question though, which of the two casing bolts by the alternator does the cable retaining clip go on?
Post by: DomP on December 17, 2023, 05:30:25 PM
I cobbled up a bearing/bush press from a length of 10mm threaded bar, heavy washers and large inverted sockets to press against the bushes themselves.  Even after leaving the bushes for three days in the freezer and warming up the swing arm and Liberal amounts of grease they required a hell of a lot of force to get them fully seated, to the point I stripped one length of 10mm bar.   Still they are in now so that's another job ticked off.
I noticed I'm missing the dust cap the sits under the rear brake arm, how important is this part?  Might be one for Ken or Bryan's endless supply of spares😉
Post by: Bryanj on December 17, 2023, 05:58:24 PM
Early ones didnt have them so cant be that important, i think yours should have an arrow on it that when it lines up with arrow on brake plate means the shoes are worn out
Post by: DomP on December 17, 2023, 06:49:42 PM
Yeah that's what CMS parts fiche suggest, to be fair Bryan I'm not going to ride it in crap weather so dust and during washing is the only concern.  I reckon I could find something if only a thin washer to cover the exposed felt pad.
Post by: DomP on December 28, 2023, 05:48:53 PM
Im revisiting my carb restoration now i have a zinc nickel plating kit, am I correct that this pin needs drilling out to enable the carb linkage rod to be removed and what can I use to re-pin afterwards?
Post by: Sesman on December 28, 2023, 09:24:33 PM
Photo required for confirmation, but probably yes. No, you can’t reuse the pin!!!
Post by: DomP on December 28, 2023, 10:25:23 PM
Yeah, I said what can I use to re-pin.  Here's the photo I meant to upload.
Post by: Oddjob on December 28, 2023, 10:30:37 PM
Use a dog point screw from Ebay, get them in brass if possible. Fit them into an electric drill, point end outward, spin and use a file to grind the end down until it fits inside the slot in the bar. 4 or 5mm is best.
I'll have some of those bars in stainless in a few weeks Dom. They tend to rust a lot.
Post by: DomP on December 29, 2023, 09:38:16 AM
Mines a bit flakey to be honest Ken, how much are the rods as I'm trying to stop thie budget running away😄
Post by: McCabe-Thiele (Ted) on December 29, 2023, 11:18:43 AM
Had the SS version been available when I assembled my carbs I would have fitted one. I sourced a much better one than my original from a member here.
If the corrosion is just on the sections between the fittings a good clean up & a some silver paint is pretty good - it's hardly vissible when the petrol tank is fitted.
My carbs had been restored by Gerben & when they drilled out the pin they broke part of that bearing - hence why my bracket had to be replaced - if you decide to drill out the pin be very careful as there is a risk of the bush in the bracket splitting in two. The bush looks like some sort of bronze colour.
Post by: DomP on December 29, 2023, 04:25:49 PM
Thanks Ted, I'm not sure what is meant by the bronze bush, is there any photos on you're build thread?
Post by: McCabe-Thiele (Ted) on December 29, 2023, 04:48:21 PM
The bracket that the throttle rod runs through has bushes inside the alloy bracket at each end - the bushes are not available seperately. When you drill out the pin on the right side of the bracket there is a risk that the drill will go into the bush & it could split.
Updated Found a photo.
.(https://live.staticflickr.com/65535/53429259704_aa6e3db78a_o.jpg) (https://flic.kr/p/2ppmVsQ)throttle bracket bush 1 (https://flic.kr/p/2ppmVsQ) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
.(https://live.staticflickr.com/65535/53429094293_a10e5da9bb_o.jpg) (https://flic.kr/p/2ppm5hV)broken bush (https://flic.kr/p/2ppm5hV) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: K2-K6 on December 29, 2023, 05:16:30 PM
If you are going to remove a rusty one to replace it, then worthwhile using emery cloth (the real stuff) on the open rusty bits to allow passing through the bushes with reduced chance of damage.
Post by: Oddjob on December 29, 2023, 05:31:08 PM
TBH Ted I think it was either Gerben that buggered up that bush or someone before him broke it and he didn't see it until he had them. I think whoever did it didn't drill all of it out, then they started to hit the rod sideways not knowing that a bit was left in, that shattered the bush.
The new Stainless Steel rods are £50 each Dom including P&P. That's not exactly cheap but you can't buy a new rod and getting an old one hard chromed costs around £65-85, I had a couple done earlier this year, the first time I had one done they charged around £25-30, then the power crisis hit and the cost went through the roof. I have some of those dog point screws as well, if you buy one I'll throw in one for you.
ATM, I only have one rod that Max made as the test one, I intend to order 3-4 more in a few weeks. However if you want this one I can let you have it so you can get on with the carbs.
Post by: McCabe-Thiele (Ted) on December 29, 2023, 05:55:11 PM
Good point made K2-K6, I had cleaned off the visible rust on my old shaft with a small brass rotary brush in my drill before I drilled out the pin.  The bracket was inside a large shallow plastic tub that I use for dismantling things like carbs or gearboxes - aside from some waste from drilling out the pin there was no other debris so I am certain it was already broken.
Post by: Laverda Dave on December 29, 2023, 06:33:39 PM
I took my 400/4 spindle to Philpotts with my fork stanctions and asked how much to hard chrome it........£130😲, I didn't bother!
I've bought a S/S one from Max. He's going to be making them for the 400/4 in the near future.
Post by: Sesman on December 29, 2023, 07:23:47 PM
Oops, sorry Dom. must get some new specs. Plus one on what Ken has advised…eg dog point screw.
Post by: Oddjob on December 29, 2023, 07:37:56 PM
That's odd, was this after I'd asked him to make them Dave as he asked for an old spindle to copy and AFAIK he's only made the one, which I have. Unless of course he made one especially for you.
Post by: DomP on December 29, 2023, 08:51:24 PM
Thanks everyone for your replies, so once carefully drilled out the pin and the deburred shaft is slid out, drill out and tap to 4 or 5mm leaving the bushes in place?
Post by: Oddjob on December 29, 2023, 08:56:56 PM
Yeah 4 or 5mm. Not sure which I've got but suspect it's 5mm, I'll have a look.
Post by: McCabe-Thiele (Ted) on December 29, 2023, 08:59:48 PM
Unless you are replacing the shaft I see little point in removing it unless you need to replate the quadrant.
Title: Re: Doms CB550F1 project
Post by: Oddjob on December 29, 2023, 09:10:14 PM
Oh I dunno Ted, some grease on those bushes can't hurt, plus it lets you really inspect some of the parts. I've seen lifter arms cracking where the pin goes through for example, yes you could most likely spot that without dismantling but checking the quadrant is also flat and not twisted is another.
I've considered drilling 2 small holes above the bushes so I can occasionally drop a little silicon oil down there, just 2 small plugs needed to seal them.
Plus of course the ability to change or replate the rod.
Post by: DomP on December 29, 2023, 09:12:47 PM
I think for now Ken (and Ted) I'm just going to replate the throttle cable linkages and replace the shaft another time but thanks for the offer.
Post by: Laverdaroo on December 29, 2023, 09:23:11 PM
Dom, did you get anywhere with the  footpeg scenario? I’ve just come back from the states  and having a read. I think I have a spare one if you want to try it. I had the same issues  with mine and had to doctor the ones that stayed on the bike. How’s you get on?
Post by: Johnny4428 on December 29, 2023, 09:25:31 PM
Weh hey back to the land of the living Roo! Or maybe you left that accross the pond? Anyhow welcome back.
Post by: DomP on December 29, 2023, 09:29:27 PM
Hi Roo, how was the trip? No I've not got to the bottom of it yet and moved on to other bits for now but I could try a spare.  Maybe worth me getting some photos of mine off the bike to compare first as I'm sure it's not bent just cast at a different angle.
Post by: Laverdaroo on December 29, 2023, 09:29:36 PM
Cheers Johnny I’ve an air box lid for Dom too so thought I could fire him up a mixed bag of stuff. Makes sense.
Glad to be home……..at least it’s warmer
Post by: Laverdaroo on December 29, 2023, 09:33:04 PM
I thought the same as mine looked twisted too, had a right think on trying to fettle it. I had the compounding issue that at the time, none were available so bought whatever came up,   mine was drooping badly also but managed that fairly easily, the twist was different but let’s have a look at what you’re working with and see if we can fettle it for you. Mine look pretty good now and I’m happy to leave them now but it took a bit of fiddling.
Post by: DomP on January 20, 2024, 05:33:20 PM
I've spent  the last few weeks fiddling around with my wheels trying to decide what to do with the slightly crusty rims, I'm thinking black powdercoat with stainless spokes.  Today I've only just noticed my front rim is a Takasago with really thick 4mm spokes, surely not standard, dos that mean the rim has been reared out to take the hoofing great nipples?
The rear has very tidy plated spokes with yellow phosphor nipples so I might see if I can sell them on to help fund the stainless.
Post by: Bryanj on January 20, 2024, 07:43:30 PM
That make was not fitted by Honda originaly, i think Kawasaki used them but i know Silver sold as a "quality" pattern part, if you are going to powder coat it i have a wheel you can have for a charity donation
Post by: DomP on January 20, 2024, 10:30:25 PM
That's great Bryan, I could collect it when I'm over at some point.  Those spoke surely aren't oe either, now I've noticed them they look horrific.
Post by: Oddjob on January 21, 2024, 12:36:54 AM
I had spokes that big on my K reg 500, had them chromed first though, very sparkly  ;D ;D
Post by: DomP on January 21, 2024, 03:39:22 PM
They just look a bit big when compared to the rears, CWC are going to be making a hole on my pocket I think
Post by: DomP on January 22, 2024, 08:00:10 PM
Central Wheel Components list the cb550 spokes as straight un butted where I believe they should be single butted, sadly that makes them £125 a wheel😟
Post by: Laverdaroo on January 22, 2024, 08:29:32 PM
Eek!
Post by: DomP on January 22, 2024, 09:43:41 PM
Eek!
Their prices have gone up a bit since I did my xs
Post by: Laverdaroo on January 22, 2024, 09:44:34 PM
Last set of rims n spokes I had were over 600 quid and I built them meself
Post by: DomP on January 22, 2024, 11:07:09 PM
It's a rewarding process isn't it!
Post by: DomP on January 23, 2024, 07:51:42 PM
Cart before the horse, less haste more speed, or plain old driving both rear wheel bearings home before putting the spacer in the hub!  😥☹️
*update, managed to drive the sprocket side bearing back out seemingly unharmed!
Post by: McCabe-Thiele (Ted) on January 23, 2024, 09:51:27 PM
Not 100% certain but iirc there are two spacers in the rear hub, the long distance piece with the prongs plus the narrower one that fits into the left bearing. I assume you may have forgotten the smaller one.
Post by: DomP on January 23, 2024, 09:54:27 PM
Oh better than that Ted, I forgot both🤦‍♂️
Post by: Bryanj on January 24, 2024, 09:42:13 AM
You aint the first and wont be the last
Post by: McCabe-Thiele (Ted) on January 24, 2024, 11:54:00 AM
I will make no judgement here as I rode my 400 for a 100 miles before I discovered why it was down on power, popping & banging due to two wrongly connected plug leads.
Post by: DomP on January 27, 2024, 08:52:23 AM
I've now corrected my mistake, I'm thinking I need to replace the refitted bearing though.  When I assemble the hub on the axle (no spokes or rim yet) and rotate it it stops suddenly rather that running freely, I think either a knackered bearing from the pounding to remove it or I've pinched the inner races with the spacers up tight.  Quite a tricky set up this isn't it considering the tolerance in drifting in the bearings, one tap too many and the inner races are under too much tension.
Post by: Bryanj on January 27, 2024, 10:01:06 AM
The inners need to be up tight for the axle to tighten, think about it as you tighten the nut you are forcing everything together, its possible you damaged a race knocking the bearing out tacke the wheel out again stick a finger in the inner race(s) and rotate by hand
Post by: DomP on January 27, 2024, 11:00:32 AM
I think the inner race has been pinched, how the hell do you drive the bearing against the spacers without putting some preloaded on the bearing?
New bearing time...again maybe
*all sorted, I heated up the brake side bearing surround til very hot then knocked back the spacer from the socket side with an 18mm socket just enough to take the pressure of the inner race.  Free spins without notchyness.  Might have got away with that.
Post by: McCabe-Thiele (Ted) on January 27, 2024, 11:58:14 AM
TBH I would have thought it more likely that in drifting out the bearing your drift slipped off the outer race & distorted the metal bearing cage - easily done if the bearing is tight.
The tightening of the lock ring fixes the left side bearing (after you have previously fitted the right side bearing) Once assembled the spacers will give some preload to the inner races - this preload is limited as the right side bearing would be pushed out if it became excessive.
At least the above is how I see it in my head.
PS I am aslo often wrong.
Post by: DomP on January 27, 2024, 01:15:03 PM
Definitely not thankfully Ted, the hub spins silky smooth so the acid test will be once its used in anger.
Post by: DomP on January 28, 2024, 09:46:23 PM
Today's progress
Post by: Bryanj on January 28, 2024, 10:02:44 PM
Are you buiding the wheels yourself Dom, if so i have hints to make it easier
Post by: Johnny4428 on January 28, 2024, 10:03:51 PM
Nice wok on the hubs there Dom!
Post by: DomP on January 28, 2024, 10:17:37 PM
Indeed Bryan, including that front-wheel you've offered me😉  I've built my xs650 wheels before but more than welcome any tips mate
Post by: Bryanj on January 29, 2024, 12:39:49 AM
OK, this is the way i do it.
There are two different ends at the hub end in angle and depth. One is fitted inwards from the outside so you see the head at the hub, the othe is fitted outwards from the inside so you dont see the head, there are 20 of each.
Fit only the ones that go inwards and fit the rim using just these 20, 10 per side.
Get the wheel truded as best you can on just these 20 spokes not forgetting Honda spec is 1/8 for side to side and up and down, no doubt you will get it closer than that BUT dont try and true out the jump where the weld is.
After you have done this it is easy to fit the other spoke from inside to outside and fit then tighten.
Doing this you are only truing on half the spokes which is way easier
Post by: Johnny4428 on January 29, 2024, 11:14:21 AM
Very good advice Bryan, and a very satisfying job to do. Last wheel I did I followed that advice from a previous post and it worked a treat.
Post by: DomP on January 29, 2024, 07:33:20 PM
Thanks Bryan, I think I've read this advice from you before so I'll give it a try this time.  I really enjoyed lacing my XS wheels, I ended up using dynabeads to balance them rather than visible wheel weights.
Post by: DomP on February 02, 2024, 05:13:17 PM
Does this spacer from the sprocket side of the rear axle need replacing?  I wonder if the roughness will eat the new dust seal I've fitted.
Post by: Oddjob on February 02, 2024, 05:17:48 PM
What spacer, no pic?
Post by: McCabe-Thiele (Ted) on February 02, 2024, 06:27:10 PM
If it's the outer spacer you can get them in SS from Max via Ken methinks
Post by: DomP on February 02, 2024, 07:36:03 PM
Oh my classic mistake! Here it is
Post by: McCabe-Thiele (Ted) on February 02, 2024, 07:44:51 PM
I have my old one from my 500 if its the same size .
I'll check it for condition foc postage only if it helps.
Post by: Laverdaroo on February 02, 2024, 07:48:38 PM
I’ve a spare re plated one if not Dom
Post by: McCabe-Thiele (Ted) on February 02, 2024, 08:15:55 PM
Just had a look for it in the garage but part is not where it should be then I remembered why.
My original steel 500 rear spacers I posted out to Max who made exact copies of them - when I fitted the SS copies the rear wheel did not sit centrally.
That is when I found out that my bike had the wrong spacers fitted. Max supplied the correct ones - I binned the old steel ones as I have no idea what they were off.
I do however have the wrong sized ones in SS that are useless, sorry if I have built your hopes up - I should have looked before I posted.
Post by: McCabe-Thiele (Ted) on February 02, 2024, 09:06:09 PM
The SS one I have is 38 mm deep spacer so almost certainly the wrong size.
Post by: Oddjob on February 02, 2024, 10:04:09 PM
That is worryingly worn Dom, like the hub had been media blasted and the seal and spacer left in. You need to replace that. Max has them for sale on Ebay last time I looked https://www.ebay.co.uk/itm/156003857172?hash=item24528df314:g:Dm4AAOSwRrpk6SW8&amdata=enc%3AAQAIAAAAwFenbnOcq2gpA3mu2NrOTve8TZF3EgxbEA2Nuw3BfqG75mq%2FS64omy%2FXjNFgCKk2RVXyt0TxxsrawFG9Mj9edkyHCEgBLbNehVWpVJlSm0y9Fz1KZygQ1A0RkS2h2bKLA4jXLcCjv8eg1Q%2BqbRmWiiaRWjMEerUe5f%2BeiMox8YuLQeY6cI3o4iRleYLZSDVwx2AcG1RkM2t9S2nmI6c5Q%2BKp0wIAzJK4Ldmzt8OReob8gx7B4jbP3nfL9ZN8ncCHsQ%3D%3D%7Ctkp%3ABk9SR8rOxL2tYw
Post by: DomP on February 02, 2024, 10:24:29 PM
It's from my rear wheel which the hub was totally knackered from the sprocket carrier wearing away so has been replaced and rebuilt, this is one of the only remaining pieces.
I think Roos offer or a stainless replacement from Max might be the best option.
Post by: Laverdaroo on February 02, 2024, 10:42:22 PM
Its not stainless Dom, its just one I was practising my plating on, It came out really well but I had some SS ones to fit anyway, like I say, ,more of a practice piece but youre welcome to it once I get home and dig it out. I know where it is,  just hope its the right size for you mate, should be 8)
Post by: Oddjob on February 02, 2024, 11:35:19 PM
Ahh, the sprocket carrier oscillating would certainly cause that type of damage Dom. Explains that.
Post by: DomP on February 03, 2024, 12:25:28 PM
I picked up my rear rim from the powder coaters this morning,  laced it and trued up with minimal adjustments needed to get it within 1-2mm runout.  Pretty pleased with how it's turned out, just need to get the front rim from Bryan collected and drop off for the same treatment.  Oh and new spokes for the front to replace the ugly thick ones currently fitted.
Post by: DomP on February 03, 2024, 12:48:48 PM
Ted, I'm pretty sure 38mm is the correct size for my 550f1 assuming it is the sprocket side
Post by: McCabe-Thiele (Ted) on February 03, 2024, 12:53:29 PM
Yours for postage only if you can use it. I will pop a photo up when I'm back home.
Post by: DomP on February 03, 2024, 01:22:36 PM
Thanks Ted!  I've tried searching the correct spacer sizes for a 550f1 but can't find much so I'm relying on what is fitted being correct, currently it is 38mm long x 34mm tapering up to 38mm x 20mm bore on the sprocket side, 50mm x 35mm x 20mm bore on the brake plate side.
If anyone with an f1 can confirm these I'd be grateful.
Post by: McCabe-Thiele (Ted) on February 03, 2024, 02:00:46 PM
The other measurements look the same as those you have posted for the hole size & thickness, bore 20 & 34-38 o/d diameter for the seal etc.
This spacer pushed my wheel off centre towards the right side so Max supplied me the correct one for my 500 that is about 3 mm shorter.
(https://live.staticflickr.com/65535/53506046481_328790fbe1_o.jpg) (https://flic.kr/p/2pw9tuM)rear spacer (https://flic.kr/p/2pw9tuM) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: DomP on February 03, 2024, 02:31:58 PM
Can I just check but it looks perfect Ted.
Post by: DomP on February 03, 2024, 02:36:12 PM
Actually Ted I'll take it if I may, I'll message you.
Post by: McCabe-Thiele (Ted) on February 03, 2024, 03:32:18 PM
Item spoke for - going to Dom then!
Post by: DomP on February 06, 2024, 06:52:51 PM
I want to replace my rear axle nut with a stainless one, does anyone know where I can get an m18 x 1.5 stainless castle nut?  Middleton only go up to m16 and ebay items all seem to be 1.75mm thread pitch
Post by: McCabe-Thiele (Ted) on February 06, 2024, 08:03:03 PM
I suspect you need the right high tensile grade of SS.
Post by: DomP on February 06, 2024, 10:32:16 PM
Yes I'd not considered that Ted, I kind of assumed they'd be suitable
Post by: DomP on February 11, 2024, 08:16:50 PM
I picked up my rebored barrels from Bryan on Friday and dropped them off for a skim at a small engineering place in Hereford on my way home, with any luck I'll have the enginecall back together in a few weeks.  In the meantime I need to rebuild the front wheel once the rim has been powder coated, I'm thinking of economising with DS spokes rather than stainless, how resilient to rusting are they?
Post by: Bryanj on February 11, 2024, 11:36:12 PM
About the same as original
Post by: DomP on February 12, 2024, 08:15:03 AM
My back wheel spokes were near to immaculate but may have been replaced at some point where as fronts are pretty corroded.  Cws are good and I've used them in the past but they're now £130 an end posted
Post by: Johnny4428 on February 12, 2024, 11:26:56 AM
Not that long ago I was groaning at them being £75! 😡
Post by: DomP on February 12, 2024, 12:16:07 PM
It's hard to justify £130 to the 'bank manager'
Post by: Johnny4428 on February 12, 2024, 12:28:27 PM
An alternative would be plated ones on the front to match the rear? Would they be good enough to replate?
Post by: DomP on February 12, 2024, 12:46:38 PM
The DS ones are BZP aren't they, mine are too far gone and even then the tine involved plating 40 spokes and nipples with my small kit makes the DS ones price attractive
Post by: Johnny4428 on February 12, 2024, 02:40:56 PM
I tend to agree Dom, even with a set in good condition it would be quite a tedious job. Never done a set myself, just bought a replacement stainless sets. Time to talk the “bank manager!” 😂
Post by: DomP on February 14, 2024, 10:52:50 AM
Here's a question for Bryan or anyone else that knows the answer, I picked up a cb550 hub from Bryan last week which is the version without the flats on the speedo side, what is the real difference if any when used on a single disc set up?
Post by: Bryanj on February 14, 2024, 01:53:31 PM
Single disc none at all, you use all the same bits in same places speedo drive is driven by the chrome plate and bolts
Post by: DomP on February 14, 2024, 05:05:53 PM
Cheers Bryan, what was the change for then?
Post by: Bryanj on February 14, 2024, 06:02:16 PM
Probably cheaper to produce, less machinig time
Post by: DomP on February 14, 2024, 06:41:23 PM
OK, final question, what was the purpose of the machined flats that were seemingly not required?
Post by: Bryanj on February 14, 2024, 07:28:08 PM
On the first CB 750 the speedo drive had two turned down flaps that engaged with the slots to turn the drive gearbox and the chrome trim was flat, aparently the speedo needle wandered due to not positive enough drive so honda modified it and i guess just did not get arround to altering the hub drawings till years later
Post by: DomP on February 15, 2024, 09:01:35 PM
Thanks Bryan!
Post by: DomP on March 02, 2024, 03:20:50 PM
Today is fork servicing and polishing day!  I've had them all apart to find the lower tips of the stantions are worn a fair bit, I've never seem the. Like this before, are they toast?
Post by: Laverda Dave on March 02, 2024, 07:29:55 PM
Philpotts could possibly bring them back up to spec with the hard chrome plating. They will probably ask you to send them to enable them to have a closer inspection. Like everything else their prices have risen by a huge amount recently (likely as a result of the chrome plating industry being licensed into oblivion). I paid £280 for my 400/4 set a month ago including the two fork top nuts. £10 return postage is included in that price.
Post by: McCabe-Thiele (Ted) on March 02, 2024, 07:35:28 PM
Is it leaking fork oil or is it a cosmetic issue, if its leaking oil then hard chroming by Philpotts looks like the answer.
If it's purely cosmetic can you  live with it or cover it with fork gaiters as a cheaper alternative.
Post by: DomP on March 02, 2024, 07:38:16 PM
It's only at the bottom of the stanchions so not swept by the seals and totally out of view, I think I need to check them for straightness as that's surely the only way they can wear like that.  No oil leak at all.
Post by: McCabe-Thiele (Ted) on March 02, 2024, 07:43:10 PM
Could it be the forks have in the past been dry of oil or is it a bend in the stanchions that has produced the bottom wear marks?
Post by: DomP on March 02, 2024, 07:53:44 PM
Well actually one side was pretty low on oil and both were very dirty, I don't think they've been serviced for years as its been off the road for a long time
Post by: McCabe-Thiele (Ted) on March 02, 2024, 08:00:06 PM
Not sure if abrasive dirt in the oil might explain the marking - if it's just surface marks might be fixable with slightly heavier fork oil - what do the insides of the fork legs look like - are they similar?
Someone like Bryan or Ken might know the reason for such wear.
Post by: DomP on March 02, 2024, 08:20:55 PM
I think the legs are pretty good, I'll check again in the morning
Post by: DomP on March 03, 2024, 09:45:22 AM
Very little marking inside the lower legs, I struggle to understand how without bushes on the stanchion they don't contact the insides of the legs.  The damping rod has a bush I know but there must be significant flex in the rod
Post by: McCabe-Thiele (Ted) on March 03, 2024, 11:42:32 AM
Might be worth a PM to Ken or Bryan - pretty sure they will know the cause & fix.
Post by: Bryanj on March 03, 2024, 02:20:25 PM
Some wear is frequent, those look fine to use to me
Post by: DomP on March 03, 2024, 04:48:24 PM
That's a relief Bryan, I've reassembled them😀
Post by: DomP on March 05, 2024, 08:12:13 PM
I began assembling the top end tonight, I've staggered the piston ring gaps if this really makes any difference as I've read they are known to naturally rotate in use, laid the gasket on with its orings and oil jets (got them upside down to begin with) then lowered the barrels over and fed #2 and #3 then #1 and #4 piston into their bores.  Leaving the 20mm gap I then inserted the cam chain guide and slackened off the tensioner and fitted it making sure it as in the pocket in the crankcase.
Having had the barrels skimmed I'm hoping the orings in the top of the oil jets will be sufficiently fat enough to prevent leaks.  I've fitted the head gasket and dropped the head on, at this point I'm going to ask if I'm missing anything?  I've got new pucks from Julie to fit s well.
Post by: davidcumbria on March 06, 2024, 07:52:04 AM
With a vesrah gasket I did upsize the o rings so looked a bit tighter than yours, allowing for the squish. Pretty sure I used 2.75 thickness in viton but can’t be sure. I know I didn’t use the vesrah ones. Head was not skimmed. No leaks so far. I thought it’s  It s worth trying a few sizes to see how they look because they  are so inexpensive and having to remove head again is a big expensive job.
 The po had fitted the oil jets upside down on my bike, not realised and actually damaged the seat in the barrels - amazed it wasn’t leaking.
Post by: DomP on March 06, 2024, 08:02:01 AM
Yes I agree David, I might order some today, can you recall the internal diameter of them?  I'm at work so can't measure
Post by: Bryanj on March 06, 2024, 08:07:36 AM
As you have skimmed the block you dont need oversize O rings as the pockets are shallower so the ones you have will squish more.
Too much might close the hole a bit.
Rest of it looking good mate
Post by: DomP on March 06, 2024, 08:18:17 AM
Thanks Bryan, the o rings are pretty much level with the gasket, will it crush that much?
I'll put a picture up with a steel rule so I can demonstrate how shallow the Vesrah o rings are
Post by: DomP on March 06, 2024, 09:20:48 PM
I got home from work a bit early today, nothing to do with having a half built engine honest!  Bryan was correct, the new oil jet o rings were plenty proud of the gasket prior to torquing the head down which I have now done (I went middle of the specified range) following the Honda shop manual, an excellent resource on here thanks to the great forum members.  Should I retorque them tomorrow or will it be fine as is?
Getting the camshaft, sprocket and chain all on was a right b#####d, I knew I'd read Ted suggesting his method so trawled back through his build thread until I found his method.  All I can say is get the chain on the righthand side of the sprocket not the left then it's easy.
Post by: McCabe-Thiele (Ted) on March 06, 2024, 10:12:29 PM
Glad you remembered my struggle with the cam chain - hard to put into words though.
Pleased it helped.👍👍👍
Post by: Bryanj on March 06, 2024, 10:38:01 PM
Honda dont specify retorque but might be an idea to take to the max setting after a 24 hour wait, in workshops we never did as time taken was always against us
Post by: DomP on March 06, 2024, 11:16:12 PM
It really did help Ted, what didn't help was reading Ken mention to check and check again the tensioner is sat in its pocket in the crankcases...I'm panicking now even though I'm sure it was, any way of checking now its all torqued up?
I might do that Bryan but I felt uncomfortable torquing the two m6 flange bolts, makes me cringe doing them up in alloy to specified torque.
Post by: Bryanj on March 06, 2024, 11:30:28 PM
Dont torque the m6 just do them last and to hand tool tight, only torque the main ones
Post by: McCabe-Thiele (Ted) on March 07, 2024, 12:14:32 AM
I know what you mean about the tensioner, just have confidence that everything went into place pretty easily when you lowered the block.
The front part that sits between the chain has side lugs that if it's not in place  would stop the block going flat down if its not in the recess slot iirc.
The rear tensioner blade is easier as it has the adjuster bolt plus the top mount - iirc the top bolt has an  O ring - this is just from my memory. I have the same sort of panic attacks - I ought to take assembly photos so I can check my work but I don't - thats when doubt creeps in.
This was the advice from Bryan & Ken on fitting the tensioner that I followed.http://www.sohc.co.uk/index.php/topic,28541.510.html
Post by: DomP on March 07, 2024, 08:11:14 AM
I just used the very lower end of their torque range on the 6mm flange bolts which I think was about 7 ft lb Bryan.
I agree Ted, but I have to have something to wake me in the middle of the night😀
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:20:05 AM
I have my blaadder for that Dom. ;D ;D ;D
I know what you mean though wrestling with problems & solutions makes for restless sleep until the tricky things are done.
Post by: DomP on March 07, 2024, 11:36:39 AM
Oh I've reached that point as well Ted, I thought I was still young at 44
Post by: McCabe-Thiele (Ted) on March 07, 2024, 12:18:09 PM
BPE is part of being a bloke!
Post by: Seabeowner on March 07, 2024, 07:20:14 PM
I always fit the sump after the block so you can check the tensioner is in the slot by looking up underneath. It can miss and slip behind, done that a few times.
Post by: DomP on March 07, 2024, 07:25:56 PM
I suppose I can whip the sump off and have a look because I've not got oil in it yet.
I've just had to do a helicoil thread repair on one of the valve cover bolts, literally one of the last ones I did up so lots of masking up to prevent any swarf going any where. I used a piece of aquarium airline on my Charles hoover to vac the hole out.
Post by: Seabeowner on March 07, 2024, 09:42:22 PM
When fitting the block you can either leave the tensioner loose and it will waggle around a fair bit or push the blade back by hand against the spring and lock it off with the nut to hold it firmly upright. The loose way gives opportunity for it to miss. The fixed way in theory should be better if all is straight.
Pic of missed pocket:
Post by: DomP on March 07, 2024, 10:03:46 PM
I bolted mine up and tensioner fully held in and locked off so fingers crossed I don't see that in your photo!
Post by: DomP on March 09, 2024, 05:47:25 PM
The worry was killing me to I took the sump off this morning, thank goodness all was as it should be!
Post by: DomP on March 22, 2024, 07:21:05 PM
I don't like to ask this question but when installing the cam chain tensioner is it possible to locate it out of the pocket to the rear of the engine, I've seen plenty that have been mounted in front of the pocket which I know I didn't do from my photos but I'm concerned it may have missed and gone the other side.  Paranoia is setting in!
Post by: Bryanj on March 22, 2024, 08:11:01 PM
No, the crankcase is in the way as i remember
Post by: DomP on March 22, 2024, 11:01:07 PM
That's a relief Bryan, I've got a photo up through the sump which confirms its not missed  then
Post by: DomP on April 02, 2024, 06:11:04 PM
I've not updated this much lately, mostly because I've hit a bit of a slow patch with other things going on and not being quite sure how I'm going to finish bits off.  I've made a fibreglass seat base with cable release and a cowl so I'm getting to the point of thinking about paint colours which brings me to my question, I'm pretty set on a gunmetal or graphite colour but maybe with a bit of a greeny hue or green metallic flake.  I'm struggling to find the colour I have in my head and have trawled Ebay car listings and looked at cars while on holiday hoping to find it, despite anyone have any suggestions or a way of finding the right colour?
Post by: McCabe-Thiele (Ted) on April 02, 2024, 06:28:58 PM
It's an old colour from the late 1960/early 1970'ss - have you looked at Goodwood Green Metalic Starmist iirc its a dark green almost black in poor light from Vauxhall back in the day?
Or something like this?
https://www.ebay.co.uk/itm/112665458713?chn=ps&_ul=GB&_trkparms=ispr%3D1&amdata=enc%3A1sWidqwJeSU24B67B0VzMbQ40&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=112665458713&targetid=1647205088520&device=c&mktype=pla&googleloc=9046416&poi=1006674&campaignid=19926849521&mkgroupid=147378848803&rlsatarget=pla-1647205088520&abcId=9311021&merchantid=115207584&gad_source=1&gclid=Cj0KCQjw2a6wBhCVARIsABPeH1twg4sNgWnItKn5mNc_wXiuivCS6xw6D4qAJfeBYcS9dSrZocQ7_6QaAhiAEALw_wcB
That said some here might remember I was going to paint my 500 frame in Nut Brown so best ignore me.lol
Post by: DomP on April 02, 2024, 07:37:57 PM
Oh yes! The nut brown frame😄  I was hoping to spray the tank etc myself but the best way of deciding on the right colour might be easier if I visit a local bodyshop to look at their colour swatches
Post by: DomP on April 25, 2024, 09:28:18 PM
Updates following Roo's request
Post by: Laverdaroo on April 25, 2024, 10:16:53 PM
Loving that Dom, really getting there now mate, top progress
Post by: Laverda Dave on April 25, 2024, 10:25:31 PM
Looking good Dom. Nice to see something a bit radical 👍
Post by: DomP on April 25, 2024, 11:03:17 PM
Thanks chaps, it's surprising how much I've still got to do though.  I think all cables will need replacing or inventive routing, new multifunction gauge- possibly a Koso, replacement side covers, brake lines and a respray.  Oh and the leather seat project that I've got my mum involved in but sadly she is undergoing constant chemo so not much into the idea anymore.
Things I've learnt, I can't weld but I can melt two pieces of metal together and tidy it up with filler.  Fibreglassing is satisfying if a bit tricky at times.  Paint stripper is very flammable, don't set light to it while holding an item covered in it, you may just flap around like a loony trying to put it out and splash molten stripper on your otherwise immaculate Daytona 675.  This really did happen and I'm only just forgiving myself for it.
Post by: Laverdaroo on April 25, 2024, 11:13:27 PM
That’s crap maye, hope she’s see’s some improvement soon mate.
The job list is endless and there’s always something else to sort! I’ve some spare black coated brake lines lurking in the draw. They’re the ones from the solid section off the calliper to the splitter, not sure of the configuration you’re using but I bought them after getting sums wrong and ended up being a bit short. I had some remade so these are surplus.
I went for the single tachometer, digital speedo combo from Daytona. Looks pretty classic, small and has all you need on yer know…….possibility for you?
I run a digital connector from the OE speedo drive the same route as the cable would go up to the clocks. Fairly inconspicuous……(https://uploads.tapatalk-cdn.com/20240425/957ca24eace175d490e37e2401fadd45.jpg)
Post by: Laverdaroo on April 25, 2024, 11:18:45 PM
(https://uploads.tapatalk-cdn.com/20240425/808505c1bef3c046646c1a7089b03008.jpg)
Crap photo but during jogging mudguards. That’s the electric pick up on the drive there. It had a fettle after this for better clearance but works a treat and keeps a look………kinda
Post by: Laverdaroo on April 25, 2024, 11:19:54 PM
(https://uploads.tapatalk-cdn.com/20240425/600add985d3ba21b4d54c2c29a1f3ab1.jpg)
Betterer look
Post by: DomP on April 25, 2024, 11:31:05 PM
Oh, I misunderstood the speedo cable thing Roo, I assumed it plugged into the end of the standard cable which concerned me as it'll be hugely long by then.  Which cable was this and was it from Digital speedos?
Post by: Laverdaroo on April 25, 2024, 11:42:25 PM
The tacho is from digital speedo’s and I think the cable connector is from Louis Moto,  I got it from there as DS’s didn’t have one in stock. If I get chance tmrw I’ll  dig the paperwork and get the deets for you
Yeah, the cable turns the original rotational, speedo drive into a pulse that the tacho can read. It has to be set up like everything which I haven’t got round to yet but the reviews are really good and it was perfect for what I was doing.
Post by: davidcumbria on April 26, 2024, 06:40:19 AM
Good progress Dom I like the way your design really gives more emphasis to the engine/ exhaust than the stock bike. Shame about the Daytona ( I have a street triple ) but unless you never ride your bikes or do anything in the garage these minor damage issues seem to be an annoying fact of life for most of us.
Post by: DomP on April 26, 2024, 06:51:45 AM
Thanks David, it's been a bit of an evolving project really, it was meant to be a budget build!😄
It would be good if you could find the details Roo, ive just looked on Louis moto and there are a few different cables so I may give them a call to see which I need, they all appear identical.  One other question, have you blanked off the tacho drive on the cam cover?  I was looking at that very gauge too but now I'm thinking of a smaller 64mm koso
Post by: Laverdaroo on April 26, 2024, 11:34:21 AM
Yeah, bunged it up with a rubber grommet, I’ve plenty if you want one
I’ll have a look later on for you, just out wobbling around the mendips today with ‘The Long Haired General’ on the back.
(I’m on my best behaviour)
Post by: DomP on April 26, 2024, 12:06:07 PM
Post by: DomP on April 26, 2024, 01:24:02 PM
Digital Speedos website is a bit crap, there's no phone number but they do have a messaging service. I've gone backwards and forwards trying to get them to answer my question about speedo cables for a cb550 but not getting a direct answer.  I'm not sure how you can operate a business with no phone number.
Post by: McCabe-Thiele (Ted) on April 26, 2024, 03:11:56 PM
I've noticed quite a few Websites where phone numbers, actual postal address are missing as well as a lack of e-mail address.
Some that have them keep them well hidden it seems with lots of navigation needed.
Post by: DomP on April 26, 2024, 05:45:35 PM
It's so frustrating Ted, I've asked yet again today if they can confirm which speedo cable type I need for a cb550, the reply avoided answering the question.  I'm fairly certain I know having taken mine off but confirmation would be great so it's over to Roo to answer it for me.
Post by: SteveD CB500K0 on April 26, 2024, 08:00:24 PM
Companies Act 2006.
If you are a limited company in the UK you must put (at least) your registered address on your website.
Post by: Laverdaroo on April 26, 2024, 08:31:25 PM
Posted today Dom, I’ll have a look for those deets mate, haven’t forgotten…………just side tracked…
Post by: McCabe-Thiele (Ted) on April 26, 2024, 09:33:50 PM
Companies Act 2006.
That address is often one of a row of brass plaques at an office full of letter boxes!
Post by: DomP on April 26, 2024, 10:07:52 PM
Thank Roo mate!
We've got an address in the High Street in my home town of Kington that has hundreds of businesses registered at it.
Post by: Laverdaroo on April 26, 2024, 10:10:22 PM
Sent via wattsapp buddy deets and piccies
Post by: Johnny4428 on April 27, 2024, 06:44:30 AM
Just catching up on this thread and without high jacking it the name Digital Speedos came up. Is anyone else on here been waiting for an order from them for a considerable time? I have been waiting 7 weeks now and they are proving very difficult to contact was beginning to think that I’ve just chucked £200 odd quid away. Then on the 15th April this email came through. And by the way I am still waiting. There was no mention of any delays when I ordered but yet the money came off the account pretty quickly!😡
Post by: McCabe-Thiele (Ted) on April 27, 2024, 09:54:59 AM
That sounds promising a change of ownership might explain the delay.
Post by: Johnny4428 on April 27, 2024, 09:59:46 AM
I was hoping that Ted!
Post by: DomP on April 27, 2024, 03:15:46 PM
That's partly why I've not ordered from them yet, lots of iffy reviews
Post by: Johnny4428 on April 27, 2024, 03:45:09 PM
There’s nothing yet to convince me that I’m going to receive anything Dom!😳
Post by: DomP on April 27, 2024, 05:04:26 PM
Have you been using their online messaging service? I've been getting some joy speaking to a chap called Jamie but as I've said before he doesn't answer some of my questions but avoids them.  I hate that, if I ask 5 questions I want 5 answers not 4!
Post by: Laverdaroo on April 27, 2024, 05:10:07 PM
Are you boys emailing or calling, I’ve never had an issue with them?(https://uploads.tapatalk-cdn.com/20240427/e575a29683bbf469d32d932ae76352bd.jpg)
Post by: DomP on April 27, 2024, 08:41:45 PM
That's the number I've tried Roo, it has never been answered just rings
Post by: Laverdaroo on April 27, 2024, 08:44:18 PM
Mmm, maybe go all ninja and jump on em at 1 minute passed opening time on Monday and try to ambush them that way?       Swines!
Post by: taysidedragon on April 27, 2024, 09:40:13 PM
I've bought stuff from them before and never had a problem. They're usually at the larger bike shows too.
Post by: Johnny4428 on April 27, 2024, 10:59:51 PM
Maybe just bad luck to have ordered from their site in the midst of a take over. I just tried phone number on their website Roo not sure if that’s the same one. I’ll give it a couple of days and try again.
Post by: Laverdaroo on April 28, 2024, 02:00:50 AM
Fingers crossed mate,
Post by: DomP on April 28, 2024, 09:14:41 AM
I think when I order I'll just stick it on a credit card for safety
Post by: DomP on May 17, 2024, 06:12:22 PM
Bleeding brakes!  This is getting annoying now, I've fitted a cbr600 master cylinder to my bike to fit my clip-ons and new braided line direct to the refurbed caliper but do you think I can get any pressure on the lever or movement of the piston in the caliper!
I've bled the mc end and everything I can think of to get fluid to pump through  so I'm at my wits end and asking for help here guys
Post by: Bryanj on May 17, 2024, 08:02:58 PM
Tie the lever to the bars and walk away for 24 hours and/or threaten to throw the f*▪︎kn thing out the window.
Worked for me at Meads
Post by: DomP on May 17, 2024, 08:31:36 PM
Tried that Bryan😪
Post by: DomP on May 17, 2024, 08:47:33 PM
I've got two other lines of investigation,  first is that I've used a banjo bolt on the caliper but I believe it is short enough that it doesn't bottom out on the caliper. Second is that the mc needs new seals but Roo thought it was rebuilt so I'm kinda assuming that much.
Post by: Laverdaroo on May 17, 2024, 09:02:52 PM
I might have stuffed you there Dom, I’ve checked my other ones and I put the kit into the one on the bike that’s on now‍
My heads a shed it appears, I might have a spare kit and off out to the Shed of Dreams in a bit, I’ll have a rummage
My bad!
Post by: DomP on May 17, 2024, 09:08:29 PM
My bad!
It's moving fluid Roo, whether it's under enough pressure though I'm not sure
Post by: DomP on May 19, 2024, 07:25:28 PM
I got there in the end, it took ages to get air out of the new master cylinder which was made harder because my clip ons have a 15° downward angle on them so air was sitting at the top slightly above the mc piston inlet.  Solved it by rolling the bike up the slope of my drive and putting it on the side stand.
Lesson learned!
Post by: Bryanj on May 19, 2024, 09:49:04 PM
Just got to work and was going to suggest standard bars might help
Post by: DomP on May 22, 2024, 01:37:40 PM
I'm trying to fit my new Koso multifunction gauge and daytona speed sensor but have cone across a few queries.  First one, is there a permanent live in the headlight I can tap power from?
The three wires from the speed sensor don't correspond with the three from the gauge, they must be live signal and earth I presume but I've no way of knowing which is which on the koso side so any way of finding out would be great.
Then there is the rpm signal that I'm getting from the coil, the instructions are so confusing I don't understand what I'm meant to be doing here at all.
Post by: DomP on May 22, 2024, 01:39:22 PM
Pics of instructions
Post by: DomP on May 22, 2024, 07:48:05 PM
All sorted thanks to the legend that is Roo.  Well almost, the neutral light comes on then hors out but I'm sure it's an easy fix
Post by: McCabe-Thiele (Ted) on May 22, 2024, 09:54:26 PM
Roo a legend - he will wear that accolade as a hard earned well deserved  badge of honour.👍👍👍
Post by: Laverdaroo on May 23, 2024, 04:33:42 PM
To quote a good friend of mine, you know what’s at the leg end?
Yup, an arse
It’s great what you can gleen from a phone call or two to try a remote diagnosis.
Happy you’ve sorted it Dom
Post by: DomP on May 25, 2024, 08:42:35 AM
I've fitted led indicators to both front and rear of my 550, the two wire rears work perfectly but I'm having a few issues with the fronts, that is they don't work at all.  Now I think this is due to their three wire set up, I should mention at this point that I also have a new Koso gauge so therefore an led dash indicator.  Am I correct in saying I need to fit diodes and reco figure the current 3 wire configuration?
Post by: DomP on May 25, 2024, 10:42:45 AM
Bit of an update, made up a gauge and ignition brackets out of 2mm steel bent in a vice with lots of mapp gas, lots of hacksawing and even more filing.  Really happy with the results!
Post by: DomP on May 25, 2024, 10:45:23 AM
Ignition bracket
Post by: McCabe-Thiele (Ted) on May 25, 2024, 11:30:22 AM
Good bit of Metalwork there Dom - always a nice feeling to make something yourself.
Post by: DomP on May 25, 2024, 12:57:05 PM
Thanks Ted!  Do you know if I'm barking up the right tree with my led's as I think you've done similar?  Currently the fronts won't light up at all.
Post by: McCabe-Thiele (Ted) on May 25, 2024, 02:35:26 PM
With some LED's they need connecting with the right polarity - hope I'm not insulting your intelligence.
Some LED's are not Polarity sensitive but probably  most are.
I tested mine with a slave battery - some come with good instructions.
Post by: taysidedragon on May 25, 2024, 02:44:57 PM
Nice work on the instrument bracket. It looks very professional.  👍
Are the 3 wire front indicators made so that they can be used as daytime running lights (as in USA)?
If so you can leave the running light wire disconnected, not used. The other 2 wires would be power from flasher relay and earth. Just need to identify which is which.
LED indicators either use a resistor in each indicator wire with the original flasher relay or use an LED electronic flasher relay which doesn't need resistors.
Post by: DomP on May 26, 2024, 07:55:34 AM
The new indicators are two wire, I've tried them in just about every combination but can't get them to work on th front, the rears are fine however.  I've fitted a new relay to run leds as well
Post by: McCabe-Thiele (Ted) on May 26, 2024, 08:39:30 AM
Have you tried switching the front bulbs with the rear?
Tested the front bulb holders using a test lamp?
Post by: DomP on May 26, 2024, 09:05:28 AM
I think I'll try this today Ted, I'll plug in an original lamp first.  They were working before so with checking again before I go any further
Post by: DomP on May 26, 2024, 10:20:07 AM
Retracing my steps paid off, when I've fitted new headlight brackets they mount onto plastic bushes so I had a break in the earth.  Moving the ground wires to some spare plugs fixed it!
Post by: McCabe-Thiele (Ted) on May 26, 2024, 11:18:42 AM
Result. 👍👍👍
Post by: Johnny4428 on May 26, 2024, 01:30:43 PM
Great Dom there on the bracketery! Nice to chase the Gremlins too.
Post by: Laverdaroo on May 26, 2024, 01:52:10 PM
Well done Dom, nice to hear some progress.
Good to fettle unexpected problems, it’s why we do it. If you ever do another just think of the confidence and knowledge you’ve accrued
Very satisfying, well done mate
Post by: DomP on May 26, 2024, 09:11:06 PM
It's coming along nicely Roo, I'm looking forward to getting it painted but I think I'll get it on the road to get some miles on it first.  Definitely got an oil leak from the new oil pump o rings so whether I've pinched it when assembling I'm not sure.
Post by: Bryanj on May 26, 2024, 11:20:04 PM
Which O ring? Cover or pump to crankcase?
Post by: DomP on May 27, 2024, 06:18:50 AM
Pump to crankcase it appears Bryan
*thinking about it now I wonder if its the oil pressure switch, as its fresh oil its so clean its hard to trace but I may just remove it and put a couple of turns of ptfe around it carefully
Post by: DomP on June 02, 2024, 05:34:48 PM
Sorted the leak out!
Before I tentatively try a road test should I try and fine tune my carbs or just take it down the road running rich as it appears to be?  I've got a Morgan Carbtune but I'm conscious of running it for too long statically when it's on new pistons and a rebore.
Post by: Laverdaroo on June 02, 2024, 05:41:02 PM
Get it out on the road mate, you’ll know what needs sussing when you ride it or at least a starting point. Don’t run it on the bench it’s too hot and it’ll just knacker yer liners, get her out on the road and give it varied conditions. That’s the better way although takes longer than you want. I’ve not run mine for ages waiting on other bits for that reason. Seats ordered and away, just waiting on my paint slot and she’s done.
I’m dying to tune her up but the risk is too great after going to all this work to bugger it up just when you’re within inches of her being done, done.
Post by: Laverdaroo on June 02, 2024, 05:44:51 PM
Post by: McCabe-Thiele (Ted) on June 02, 2024, 06:01:40 PM
I'm with Roo here, run it get the pistons  to settle in a bit, it's amazing what some warming and cooling down of an engine can change.
If your dynamic timing is set a few miles will help you balance the carbs with more certainty as and when.
Post by: DomP on June 02, 2024, 06:40:52 PM
I think I'm just worried it's going to leave me stranded down the bottom of a hill, I can only go downwards from my place
Post by: Laverdaroo on June 02, 2024, 08:01:20 PM
It’s like that at my house Dom, best foot forward and all that.
Can of brake fluid in your pocket to encourage it to fire if it bogs is a handy thing to have if stuck. If only to limp home if it gets moody and gives up. It’ll be carbs so you might as well gob full to get it running if yer stuck. Just don’t give it heaps
Post by: DomP on June 02, 2024, 10:11:08 PM
I was quite tempted this afternoon but didn't get a chance between people visiting, how many miles should I do to being with and up to what rpm?  I still can't get a rev reading so I'll be guessing that bit.
Post by: Bryanj on June 03, 2024, 12:16:22 AM
If the engine is built to mr Hondas specs it onlyneeds bedding in not running in. More imortant to not run with revs to low (lugging) than letting it rev high
Post by: DomP on June 03, 2024, 08:30:20 AM
Thanks Bryan, I'll ride it like a semi loony then, to be honest brakes will be the limiting factor as they're not that great.
Post by: Laverdaroo on June 03, 2024, 10:12:19 AM
Don’t forget,
Wheelie’s passed the ‘all girl school’ bus stop are compulsory
Post by: DomP on June 03, 2024, 10:58:25 AM
Don’t forget,
That's more likely than a stoppie!🤣
Post by: Laverdaroo on June 03, 2024, 11:14:11 AM
Don’t forget,
Post by: DomP on June 03, 2024, 06:50:28 PM
Did a sneaky first ride (proper countryside so no main roads)
Some things no note and the reasons I ended it pretty quickly, I've got a hanging idle which revs up between gears, sometimes to high to be comfortable with.  Its definitely running rich which may be part of it?
Secondly when I got back and switched the key off it did a kind of intake of breath and popped a muted backfire, again this concerned me a bit so I'll wait some responses before I go out again.
Lastly, no speedo registering on my koso with daytona analogue to digital speed sensor as well as the well documented lack of rev counter
Post by: Tony.B on June 04, 2024, 12:30:26 PM
Are you 100% sure carbs are balanced exactly? I remember back in my 400/4 days, that was always the giveaway that carbs needed balancing.
Post by: DomP on June 04, 2024, 01:03:58 PM
They're bench sync'd but not balanced as such, because it's a rebuilt engine I don't want to have it sat idling for long
Post by: McCabe-Thiele (Ted) on June 04, 2024, 01:25:06 PM
We have an old floor standing fan that I use when tinkering to give an air flow over the front of the bike.
It used to be whiteish - with the ravages of time  its now beige/yellow.
I've brought it down from my garage loft ready for setting the dynamic timing and the carb sych.
Post by: DomP on June 04, 2024, 03:37:33 PM
I have had this thought Ted, just I don't want the pistons and rings to suffer before they are bedded in
Post by: Laverdaroo on June 04, 2024, 07:28:40 PM
Im with Ted on that, get some fans on it but keep yoiur time idling to a minimum to reduce the risk of glazing. I dont have fans so going to be carrying my guages with me on the test rides. Roadside fiddling always been a part of my motorcycling career but  that might be due to the amount of old and shagged out Ducati's I've had. ;D
Post by: DomP on June 07, 2024, 07:51:14 PM
The main problem I've caused myself is that I can't set the revs due to having no working rev counter.  I just can't get it to idle nice and even, when I blip the throttle the revs won't fall meaning I end up hitting the kill switch, it is pretty even across all four cylinders on my Morgan carb tuner though so that's a positive.
One other thing to note, sometimes when I turn the ignition on I get a pop/air type sound from around the battery or airbox.
Post by: davidcumbria on June 08, 2024, 08:36:10 AM
I found the pilot airscrews have a much bigger effect than you’d think so try experimenting with them 1/2 turn further in or out and see what changes. Are all the cylinders running at similar temperatures - an infra red temp gun is cheap and useful.
Post by: McCabe-Thiele (Ted) on June 08, 2024, 10:53:29 AM
What sort of gap did you have when you bench synchronised the carbs?
I went for zero on the 500 so even on 3 and a bit cylinders no issues with setting the idle.
On my 400 I used an odd sized drill shaft it was something like 3/32.
Reads as very difficult with no working rev counter.
Post by: DomP on June 09, 2024, 03:13:09 PM
I missed these replies sorry folks.
An infrared temperature gun is something I keep meaning to get so I think I'll order one now David.  I've set my pilots to the standard 1 1/2 turns out but have not tried at 1 3/4.  As for gap Ted, I set it very much at the smaller end but forget what it was now, the rev counter issue is really not getting closer to solved, I need to email Koso to try and get to the bottom of it I think, I've made a rod for my own back by not using the same brand gauge as the speed sensor too.
Post by: McCabe-Thiele (Ted) on June 09, 2024, 03:37:55 PM
Those tables show a wide range of 1-2 turns for the 550F,F1 & F2 069A type carbs Dom, are you definitely air leak free in all three areas between carbs and cylinder head?
I use a bit of alloy pipe as a listening tube to check for air leaks - it amplifies any sounds of air being sucked in - plastic pipe works but not as much amplification.
Post by: Laverdaroo on June 09, 2024, 03:39:00 PM
1 1/34 is base setting Dom, +/-  1/2 turn but it’ll be more I should think. Set em all at standard then work from there mate.
Post by: DomP on June 09, 2024, 05:06:48 PM
At 2 turns out it seems ro run and idle better, it'll still start with no choke though from cold so must still be quite rich, until I can get to the bottom of why I have no speedo and rpm readings I can't really take it out nor play with carb fine tuning
Post by: DomP on June 18, 2024, 06:19:48 PM
Bit of a snorkel question, apart from the obvious job it serves to keep out water is there any tuning or performance reason to have a snorkel fitted to the top of my filter lid or could I just mount some mesh over the lid opening?
Post by: Bryanj on June 18, 2024, 08:56:47 PM
Originaly for noise supression in certain european countries (Germany) came with smaller jets as airflow restricted so if you use open lid would suspect you would need the 500 jets
Post by: DomP on June 18, 2024, 09:09:28 PM
I've got the lid Bryan so if I fitted the lid to narrow the opening and mesh it to prevent leaves etc would I be OK to run the standard 550f jets do you think?
Post by: Bryanj on June 19, 2024, 08:07:10 AM
Dont know Dom, all you can do is try it and see
Post by: McCabe-Thiele (Ted) on June 19, 2024, 10:18:56 AM
Someone told me the main reason for your different jetting was more to do with it being a 4 into1 rather  than just the air box.
Post by: DomP on June 19, 2024, 11:41:20 AM
Will give it a go Bry.  Yeah I read that somewhere Ted
Post by: McCabe-Thiele (Ted) on June 19, 2024, 11:57:03 AM
The top tool tray is not a close fit to the airbox anyway,  It's probably just designed to keep water from the seat out of the air intake.
Post by: Bryanj on June 19, 2024, 01:39:15 PM
Thats the 500 Ted the 550 snorkle is held down to the filter box with long wing nuts
Post by: McCabe-Thiele (Ted) on June 19, 2024, 03:20:50 PM
My bad I was thinking it was a 500, presumably the 550 might have some sort of vent circulation from the cam case cover as well for reduced emissions?
Post by: Bryanj on June 19, 2024, 05:04:09 PM
It does Ted
Post by: DomP on June 30, 2024, 02:18:34 PM
I really haven't much to update on my project lately, I've been held up laying a brick plinth for my workshop build.  I've tried to set up the magnetic speedo sensor supplied by Koso but can't get a reading yet. The speedo converter I got from Digital Speedos was definitely incompatible, attempts to contact them by phone and email have all been ignored so be careful using this company.
Hopefully I will have finished my brickwork by the end of next week so should be able to turn my attention back to the 550!
Post by: DomP on July 04, 2024, 09:56:14 PM
I did something!  My airbox had no lid or brackets to hold a lid on, thankfully Nige on here helped me out with a 550f lid so other than stripping and repainting it all I needed to do was make some brackets and weld some m5  threaded bar to them to locate through the lid holes.  It's worked out really well so all I need to do is make a new seal and mesh the opening,  the snorkel won't fit below mu home made seat base but I'm not sure it affects the running but is there more to prevent rain ingress...I could be wrong.
Top tip - remember to take the chuck key out of your pillar drill BEFORE turning it on!   Chuck key still yet to be found.
Post by: Johnny4428 on July 05, 2024, 08:12:51 AM
[/quote]
Thankfully it wasn’t imbedded in the soft tissue somewhere!😳
Post by: taysidedragon on July 05, 2024, 12:08:54 PM
[/quote]
I hope that it didn't hit any bike parts on it's solo flight!
Post by: Laverda Dave on July 05, 2024, 12:13:51 PM
I remember during a metalwork class at school one of the kids was using auto feed on the lathe when he decided to go walkies. The resulting bang and carnage was a sight to see. The teacher went nuts and hit him over the head with a tool post!
Post by: Bryanj on July 05, 2024, 01:41:29 PM
At college we had a large cardboard chuck key that the last person to leave one in had to wear until the next person did it!
Post by: DomP on July 05, 2024, 08:03:30 PM
I'll cut one out and where it tomorrow Bryan!
I'm not sure what the airbox lid brackets should look like exactly but here are my efforts complete with front and rear stamps because they ended up slightly different.
Post by: DomP on July 05, 2024, 08:56:50 PM
On the subject of filter lids, looking at photos I think the mesh aperture is around 2mm, can anyone confirm for me as it will surely make a fair difference in air flow restriction.
Post by: DomP on July 11, 2024, 06:56:44 PM
Is this distance correct, I've read there should be a measurement of 56mm between cable nipple and cable anchor point but the diagrams are near impossible to interpret.  What is the actual effect in real terms if the cables are not inder tension at idle?
The upper throttle stop screw into near to making contact with the bell crank
Post by: DomP on July 12, 2024, 04:44:40 PM
I took my first real ride out lastnight just to see if any of the running issues might sort themselves out.  It seems to accelerate fairly well after bogging down a bit, the idle is the main problem though, it raises between gear changes and when coming to a standstill at junctions to the point I had to flick the kill switch on and off to settle it.  Other than that the front brakes are a bit woeful and I have a bobbly front end, could be a lack of wheel balancing or the oil weight maybe?
*oh and I hit 143mph, think I need to calibrate my speedo🤣
Post by: Laverdaroo on July 12, 2024, 06:17:15 PM
Nah, 143mph sounds about right Dom. I take it you didn’t get it in ‘top’ then?
Post by: DomP on July 12, 2024, 06:34:02 PM
No not this time Roo, this was just through town on the back wheel.
I'm considering taking the carbs off do double check the float heights, jets are all clear and that I've set the bench sync to bottom out with the idle screw out, somethings not right to be running rich 2 1/4 turns out and have a idle that keeps rising with the throttle shut.
What do you think regarding the throttle linkage Roo?
Post by: McCabe-Thiele (Ted) on July 12, 2024, 08:03:45 PM
On the 550 with the solid brass screw I thought the settings are 1/4 turn out as a base point. If you are over two turns out my understanding is that you have let so much air in it will be running  far too lean pulling fuel from the main jet when it can. Opening the screw slows down the amount of fuel from the idler jet so it's trying to  draw fuel from the main jet instead. Look at that video I posted about hanging throttles.
The 500 has a different design of air screw so needs more turns to achieve the same effect.
Post by: DomP on July 12, 2024, 08:37:25 PM
I believe on mine which are 069a's (550F1) the base setting is 1 3/4 turns out, if I richer it it stinks of fuel and soots up the plugs.  I'm happy to be wrong if it solves the hanging idle however 😄
Where the video Ted, worth a watch I think
Post by: McCabe-Thiele (Ted) on July 12, 2024, 10:19:37 PM
It's under Misc/open on here Dom although the video shows  single cylinder bike his explanation seems logical - up to now no one has commented on the post.
Post by: DomP on July 12, 2024, 10:48:25 PM
Oh I've watched that before, maybe I'm barking up the wrong tree then but the rich smell of fuel led me to think it needed leaning out not richening.  I'd say I have a climbing idle not a hanging idle though so I'll check for an air leak tomorrow
Post by: McCabe-Thiele (Ted) on July 12, 2024, 11:05:09 PM
When altering the mixture on SU carbs on cars my late father told me the best guide to lean or rich was the exhaust temperature a rich mixture gives a cold exhaust out of the pipe , a lean mixture gaves a hot exhaust  - he never mentioned petrol smell.
Post by: Laverdaroo on July 12, 2024, 11:21:31 PM
Just got home tonight axon, I’ll have a look tommoz, found a bottle of Landlord in the fridge and well that was that!
Post by: McCabe-Thiele (Ted) on July 12, 2024, 11:38:05 PM
It might be I'm confused about the screw turns - it might be 1/4 turn for a 500 fitted with the 550 carbs.
I guess it's this table that you are refering to.
Post by: DomP on July 13, 2024, 07:58:12 AM
Cheers Roo although is was meaning the 56mm distance thing but yes I'm still looking for the connecting plate
Post by: McCabe-Thiele (Ted) on July 13, 2024, 08:43:38 AM
The 550 manual on here shows air screw as 1 turn out plus or minus 1/8th turn - if I understand you correctly it runs far too rich when you try that. Do you have the solid brass air screws with the flat end? Are you on 40 pilot jet?
Post by: DomP on July 13, 2024, 09:45:45 AM
Yes solid Ted and all jetting is standard keihin jets for an f1 but they are 1 1/2 +/- 1/2 turn
Post by: McCabe-Thiele (Ted) on July 13, 2024, 01:27:01 PM
Came across this post of a similar issue.
http://www.sohc.co.uk/index.php/topic,28462.0.html
Post by: DomP on July 13, 2024, 02:15:27 PM
Read that too Ted🤣 I seem to have opposing problems, of a hanging idle yet rich running
Post by: McCabe-Thiele (Ted) on July 13, 2024, 02:19:20 PM
Trying to think outside the box - could it be timing related - mechanical advance not falling back as it should?
Post by: DomP on July 13, 2024, 04:00:52 PM
Now you say that, I remember chatting to Ken about my trimmed advance springs.  I'd rather have standard untrimmed ones but someone in the past has cut and bent the end coil
Title: Re: Doms CB550F1 project
Post by: K2-K6 on July 13, 2024, 04:45:24 PM
That shouldn't, in and of itself, cause problem with tickover. It would make the "closed" position more assured to enhance stability at idle by not fluctuating at those low rpm.
Worthwhile double checking your static timing point against the F mark tough, as anything in advance (firing too early) would go to making it more difficult in settling back to consistent idle rpm.
I dont agree with shortened springs though, certainly without then getting quantification of how the advance curve plays out. Arriving too late will at the needed advance specification will reduce low rpm torque output. You'd need to accurately measure at what point in rpm range it reaches full status.
But, as noted though, that's an issue as you're asking for power and not lowest rpm stability.
Post by: DomP on July 13, 2024, 05:14:24 PM
Are correct springs still available?  I'm not sure I understand everything you've said there K2-K6
Post by: Bryanj on July 13, 2024, 06:54:14 PM
Springs were never available as a seperate part you have to buy the complete unit, pattern ones are now available BUT a member on the US site found the 750 one had the F and T marks incorrectly positioned, you need a 500 part anyway.
I think DS lists them and 4 into 1 in US but watch out for duties.
One bit i dont have lots of, could possibly lend you one for testing purposes
Post by: DomP on July 13, 2024, 08:13:25 PM
Thanks Bryan, I'll let you know if it comes to it.  Oh its a 550 though not a 500 not that that may make no difference
Post by: Bryanj on July 13, 2024, 09:09:31 PM
Same part as far as i know, lots of 500 parts fit and are even same part number!
Post by: K2-K6 on July 14, 2024, 08:48:44 AM
Supply, as Bryan notes, can't see any springs available.
Apologies for confusion.
To clarify;- the molded springs currently fitted should have nil effect on the idle issue you are chasing. They effectively (by tightening) make the retarded position more positive which would only enhance stability and repeatability at the tickover rpm. I'd dismiss them from suspect for this cause.
Two things to check though. Is the A/R mechanical not impeded by friction itself, all appears to rotate freely if you exhamine it ? And, have you checked that the static timing is definitely at the F mark accurately to make sure its getting that aspect right ?
Post by: DomP on July 14, 2024, 07:52:55 PM
Cheers Nigel(?)  I've decided to check it over from scratch but also to pull the carbs and bench sync them again.  Having watched Motormac on YouTube I'm going to follow his method and set the 56mm distance on the bell crank, I've fiddled with them so much I can't now be sure where they're at.  A bit more time spent now might save me further headaches.
Post by: K2-K6 on July 15, 2024, 11:35:10 AM
Yes, Nigel is correct.
Probably worthwhile looking through them again. Youjust gain more experience in doing this, a very pedantic/ critical eye in evaluation of them will often turn up something that may be causing an issue.
They are just plain fiddly to get right if there's any impairment etc, that's carburettor in general, even for experienced practitioners of the art. Can go round and round until finally sorting them. A friend runs a garden machinery business and hates the run around that inevitably comes with sorting out simple problems.
The bench sync is absolutely fine to run the engine without problem from tbat aspect. It has the major advantage of knowing they are mechanically in synchronization and helps in diagnosis of other faults if you don't try and sync them after installation.
The carb rack should allow for adjustment of the major rpm stop screw to fully lower the slides after setting them (if you use the drill method on here) which ensures that the slides have the capability of full restriction once set to parity.
You can then connect them to cables, without installing on engine, to ensure the cables definitely don't conflict with that function.  Emphattge slides should sit at rest on that master tickover screw stop, and nothing else should impede that operation.
Adjustment of the airscrew idle function when running is then where the attention should be. The suggested opening point 1 1/2etc should be seen as competent start point, from which you need to test what exactly is needed.  That method is in the Honda manual officially to instruct you.
Effectively, it gets you to adjust leaner until that cylinder falters, this  is the air fuel mixture just going past its technical ideal of 14.7 to one ratio. Thats pertinent to the hardware in place AND the fuel in use at the elevation you are working.
Then it requires you to make it richer by adjustment to bring a 100 rpm drop (multimeter with frequency will register this if you've got one) to bring that carburettor and cylinder to ideal operating point.
Later Honda manual detail recording that absolute setting in service notes as baseline for the operation. It can be different for each of the for cylinders. If you don't get something competently in range at that point, this suggests something else maybe wrong, or some impairment is still there withing that idle circuit.
Post by: K2-K6 on July 15, 2024, 01:32:30 PM
The absolute airscrew setting has always been part of adjustment scheme in reality, rather than solid set and forget.
With variation likely on component now in comparison to production line original, then highly likely that set point is going to be different.
Bore of jet, bleed holes, airflow passages, air filter performance, piston ring sealing, fuel burn characteristic, ethanol inclusion (contains oxygen over and above no e types) will all contribute to a setting that may be different to "book" value originally given.
The cleaning  of the jets and air passages are also a scource of variance too.
Establishment of a set for what you've now got in place should effectively accommodate these.
Fuel injection system do exactly this now, with more or less the same methodology as Honda originally published in their manuals, just automatic in itself via ecu programming, built in sensors etc.
Like these carbs though, if the sensible adjustment fails to yeald a competent combustion before reaching the end of logical steps available, then it'll usually throw emissions/check engine code and warning to request further work in establishing what is the real cause of going out of range.
Post by: DomP on July 15, 2024, 07:44:55 PM
Thanks Nigel, that's one hell of a reply.  Carbs are coming off this week if I get a chance so that I can eliminate my bench sync from the equation
Post by: DomP on August 04, 2024, 08:13:28 AM
Is there a way of testing if my standard Keihin pilots (38) are within spec and not worn or over cleaned to a point they are now significantly larger?
Post by: McCabe-Thiele (Ted) on August 04, 2024, 10:43:09 AM
I believe the concensus is that the screw adjustment range will compensate for normal wear.
That said I know one member used one 38 and four 40 jets to avoid a rich running cylinder. The air screws for the 500 are a very different design  to the 550. My 500 was fitted with the 550 brass solid flat ended screw. Courtesy of Ken I have fitted the correct ones that are hollow with side holes.
Post by: DomP on August 04, 2024, 03:42:51 PM
That confirms my thoughts Ted, I suppose it would run richer as the pilots wear meaning screws out further to compensate.
Post by: DomP on September 29, 2024, 10:32:59 PM
Having sorted the rpm on my Koso gauge I set about trying to rectify the hanging idle I've been experiencing. As much as it pains me I removed the carbs (again!) and checked/adjusted the float height being even more anal than the last time, no2 carb had a float with a chunk missing out if it so I replaced it with a used original.  Having refitted the carbs and opened the fuel tap I still have a hanging idle,  it's absolutely fine on start-up but any blip of the throttle won't return to idle, nothing mechanically is sticking and a spray of carb cleaner around the carb boots doesn't change the idle. I'm beginning to lose patience with it.
Post by: Johnny4428 on September 30, 2024, 11:40:52 AM
Are carbs balanced too Dom?
Post by: McCabe-Thiele (Ted) on September 30, 2024, 02:05:18 PM
I have little experience with no formal qualifications on bikes, with that disclaimer  heres what what I think.
I'm often wrong with a relatively short experience on only two Hondas in the last four years.
I am in my seventh decade of experience on a variety of cars and at the limit of my memory from bikes during the 1960s & 1970s. I do eventually admit when I am wrong.
My perception now seen through the prism of old age & the many posts on this subject is roughly as follows.
These bikes are fitted with four carburetors that at a basic level have two fuel supplies to the engine.
1) The first is what I think of as the idle jet circuit - this supplies fuel not just at idle but at significant amounts as you increase the engine revs with a sort of reducing influence  as the main jets take over.
2) The second fuel supply is the main needle & jets that operate by the sliders.
Assumptions - there are no air leaks on the induction side with standard air cleaners, original jets & needles in good condition. When hot the open & closing throttle cable are working & not binding. The ignition advance/retard is working as it should & timing is spot on at idle & full advance settings.
A hanging throttle is confusing as if the sliders fully  close when you shut off the throttle the engine rpm should fall relatively quickly back to a normal idle as no fuel is being provided by the main jets as the needle is effectively shutting off the fuel supply.
Contrary to logic I believe a hanging throttle is caused by a lack of fuel or conversely too much air supply - a weak mixture at that point as the revs should fall instead  they take a while to drop from say 2,200 rpm to 1200 rpm.
So how does the engine manage to maintain this hanging throttle?
I think it is as a result of a tad too much air passing through the intake under the sliders when the throttle fully closed, this draws fuel via the idler jet circuit as well as an unknown amount from the main jet in some situations.
This might be as a result of 1.2.3 or all 4 sliders being too wide open in the throttle closed position.
It's possible to think you have the air screw spot on when you do the bench sync by reducing the fuel flow by opening the air screw you can get an a false idle. When the engine is up to full running temperature this in my view points to the slider gaps being just that bit too wide. So it's all good when warm but after a fair run the idle gets too fast.
If when the main throttle stop screw is completely undone the sliders are fully closed then as no petrol can get through it will of course not even idle but stop.
I think the trick is getting the least amount of slider gap yet maintaining a tickover contolled by the air screw adjustment only - on a engine that is up to temperature.
I'm waiting for incoming - my shields are up !
Just edited some poor spelling & sentence structure for clarity
Post by: DomP on September 30, 2024, 08:53:42 PM
I've bench sync'd the carb Johnny, I think there is some good information in Ted's comprehensive write up, I need some good weather to get it upto temperature really.  Not sure when that might be but hopefully this week.  Thanks again Ted!
Post by: Bryanj on September 30, 2024, 08:57:03 PM
I have had it where the carbs have been bench synced with the slides a tad too high, make sure all the slides can bottom out with the big tickover screw unadjusted
Post by: DomP on October 01, 2024, 10:58:50 PM
Yes I can kill it if I wind the idle screw out, pretty damn sure I've got no vacuum leaks too as I've gone around it with carb cleaner and not noticed any change to revs.  I need to get a good free day to fully dedicate to going over it with a fine tooth comb.
Post by: McCabe-Thiele (Ted) on October 02, 2024, 03:38:45 AM
I've added an additional assumption to my analysis that I omitted -  you need to have the original mechanical advance & retard this needs to be in good working order or an electronic equivalent that works.
Post by: DomP on October 02, 2024, 05:41:39 PM
One other thing of note is that it is far too easy to start, no choke needed, whether that points to the shield being a little too open or if its just that it's running too rich?
Post by: K2-K6 on October 02, 2024, 06:12:01 PM
If you start it from cold, run it 30 sec, switch off and then check the header pipes for temperature (basic spit on your thumb and touch will do) what have you got ?
Any cold ones  ?
Post by: McCabe-Thiele (Ted) on October 02, 2024, 06:35:15 PM
I am not saying this as a thing but both my bikes need full choke to start up from cold as a first start of the day. As soon as the engine is running I reduce the choke as necessary. If I switch off after half a minute or so no choke needed to fire her up again if it's within a few minutes. might need some slight choke to ride off
Post by: DomP on October 02, 2024, 06:47:06 PM
Any cold ones  ?
Only time I'm getting no firing on a cylinder is because the plugs soot up
Post by: K2-K6 on October 02, 2024, 07:10:51 PM
A good synopsis Ted. I think some parts need further discussion to clearly establish exact relationship and effects.
Probably another thread would be a good idea, else it gets buried in more general information like this.
Post by: davidcumbria on October 03, 2024, 08:15:22 AM
I have come to the view that with the twists and turns it may be nigh on impossible to clear a partially blocked air screw circuit so it doesn’t work as intended. Playing tunes with smaller pilot jets in affected carbs might be the solution as it was for my sooty number 1 cylinder. This could play into the hanging idle scenario.
Post by: K2-K6 on October 03, 2024, 09:12:49 AM
This is ultimately the cause as I understand it. Thats dependent on how "hanging" idle description is observed and applied though. IF there's another cause possible, ignition advance, plugs, mechanical impairment of cables etc, that has to be eliminated before this status can be emphatically linked to fuelling.
With the idle circuit being the only fuel supply and metering route at closed carburettor slide position, then it must have a reciprocal relationship with the air going under the slide. Failure of that relationship in a stable accumulation of fuel as the slide moves up will give the variance we see in mixture, leading to below or above target air fuel ratio given.
Post by: McCabe-Thiele (Ted) on October 03, 2024, 09:43:07 AM
That's an interesting observation David that makes complete sense, a practical solution. After I had cleaned my carbs in the hot ultrasound bath I casually squirted some releasing fluid through the idle jet followed by some canned compressed air a mate gave me. I can see a situation where a part of the passage might be reduced in size by corrosion that will not budge by normal cleaning.
Post by: K2-K6 on October 03, 2024, 01:01:09 PM
Any cold ones  ?
Are you absolutely certain, by doing this test it will at least show a confirmation.
The effect, if one cylinder is not running reliablly when throttle is closed, is that the main rpm adjustment is made to effectively accommodate only three cylinder pulling the crank around, making it too high IF four are running when you drop the twistgrip, to later go to three and have corresponding drop in rpm .... can be determined as a hanging idle.
The reason I check for this is that many which I look at have this fault with the owner unaware that it existed.  Then you're back to cleaning idle circuit passages etc  :)
Post by: DomP on October 03, 2024, 06:25:01 PM
Ah I see what you're saying, I'll give it a go this weekend, I do sometimes get a bit of a pop that sounds like a small backfire which this could explain.  I have fully striped and cleaned the carbs with the original keihin jets for a 550f which Ken helped me out with when one was a bit crushed, every jet was clear and carb cleaner is spraying through the passages.  I didn't however use an ultrasonic cleaner
Post by: Sesman on October 03, 2024, 06:41:48 PM
Appreciate the “hanging idle” discussion, but does this explain sooty plugs? I thought the idle jets played an insignificant role above 1500 rpm or so.I appreciate there is an element of transition phase.
Post by: K2-K6 on October 03, 2024, 08:09:51 PM
I'll try to pick the right wording to describe what their influence is.
Its situational rather than hard rev band or throttle position.  This because the engine is responding to volume of ai, while the carburettor responding primarily to vacuum (the drop below atmosphere via venturi design) therefore it'll flow differently for different situations.
Example is if you rev the engine then drop the throttle instantly/fully, the air volume stops but the vacuum now climbs as the rpm decays according to flywheel energy. That provides a spike in fuel with the slide closed, making it temporarily rich which helps to quench combustion, finally to recover as these two influences equal out. All in a very short space of time. Failure to do that by having  restriction in delivery jet, then it'll go lean, relatively, and promote "hanging" rpm.
Anther example .... if you're approaching a long sweeping bend and go down a couple of gears, throttle off to near closed, then say it's running 5000 rpm that'll be pulling tgrough the idle jets as vacuum is high, this facilitates it going immediately you then open the throttle, if it didn't do that you'd get a flat spot up there that's really annoying as initially it would be lean. So a much higher influence than most would suspect.
It's also why you get popping on overrun if there's an exhaust header leaking air into system. The fuel that's in excess from moving towards rich with throttle closed passes into the exhaust unburnt in some quantity, availability of leaked air then brings that back to combustible in the hot exhaust pipe, and so you get popping from air leak but supplied by excess fuel from idle jets working correctly.
I do think it needs more dedicated thread that can be referenced rather than difficult to search within another topic.
Post by: McCabe-Thiele (Ted) on October 03, 2024, 08:14:53 PM
Why don't you start a new post yourself under tricks & tips or do you want me to do an opener?
Post by: K2-K6 on October 03, 2024, 09:12:38 PM
I don't mind Ted, conscious of not wanting to muck up Dom's project thread,  but obviously it'll be useful to have discussion containing this topic.
I'll start one in the anorak section and see how we get on.
Post by: DomP on October 03, 2024, 09:49:10 PM
Im now beginning to realise how much I don't know or understand about carburetors,  thanks again chaps, I need to read that all over again slowly to try and get my grey matter around it all.  Much more going on than I thought.
Post by: Laverdaroo on October 03, 2024, 09:51:50 PM
Phones always on Dom if you need confusing or just need a rant or even just to offer a theory mate
I know how frustrating it can be buddy
Post by: Sesman on October 03, 2024, 10:22:18 PM
Err….sooty plugs?
Post by: DomP on October 04, 2024, 10:12:02 PM
Thanks Roo, you're a gluten for punishment mate😂
Post by: Laverdaroo on October 05, 2024, 12:26:38 PM
That I am but at least I'm not Lactose intolerant as well. ;) ;D
Post by: DomP on October 05, 2024, 01:10:32 PM
🤣🤣 I'm not sure I can blame auto correct for that one!
Post by: DomP on October 12, 2024, 05:46:04 PM
Im putting carb issues to one side for now while the weather is crap to get my grotty tank prepped ready for my attempt at a DIY respray.  This is where I'm going to ask you wise folk for your opinion on tank liners, my rather battle scarred tank has what appears to be a light brown liner which currently looks to be OK but as I'm doing a respray should I consider removing it?
I'm doing a full bare metal strip which has uncovered quite a bit of filler, I knew I would having run a magnet over it, the tank badge clips have been filled in so I think I might have to do the same for two reasons.  Firstly my badges were glued on with the pins cut off, secondly I the denting is mostly around the badge area so I think getting the clips to accept the badge pins will be nigh on impossible.  Any thoughts or opinions appreciated.
Post by: DomP on October 13, 2024, 07:53:17 AM
I think it's been used for target practice!
Post by: Laverdaroo on October 13, 2024, 10:02:37 AM
After having a liner fail for the first time in 10 + years, all I can advise is steer clear of the bloody things. Up until this point I was quite a fan but I wouldn’t go near it at all if I were you. Trying to get rid of ‘said’ failed liner took me over a month to be sure it was all out. The cleaning stuff is over a tenner a litre and I used nearly 10 litres and even then it’s not that great at shifting it. Steer clear Dom it’s a cock up in tin waiting to happen.
Post by: DomP on October 13, 2024, 10:49:09 AM
I've read acetone will remove them, might ginmve it a try before I start painting this thing, it seems pretty solid though so hopefully I'm not poking the bear as it were.
Post by: AshimotoK0 on October 13, 2024, 11:11:52 AM
When I go to Newark Autojumble next week I am going to get a 5l tin of unbranded methylene chloride type paint stripper and chuck that in a tank I have with a liner in it. If that doesn't strip it I will give up !
Post by: Laverdaroo on October 13, 2024, 10:42:44 PM
I couldn't tell you what's in it Ash as there were no details at all on the lable and no data sheet. It worked but only after having it in the tank and turning it every day, for a month, during week four the liner only just started to soften. It doesn't dissove it, it just dislodges it from the tank so you end up with big chunks that come off but wont snap to be furkled out of the filler hole. Its a miserable job.It's obvious that frost buy it in bulk and decant it into gallon tins and do a cheap paper wrap lable............posted to you sir for about £60!
I used two tins in the end as its such vile stuff that |I found that there was a huge evaperation issue if the taknkwas left open and the filler not blocked up. It resembles walpaper paste like Nitromors used to be but with a different smell, not citrus based thats for sure.
So yes it did work, yes it was hugely expensive, no, nothing else |I tried came close and yes a horrible job deadling with proper nasty stuff in bottles that makes your eyes hurt even with glasses on ;  ;Dthat takes forever.
Post by: DomP on November 03, 2024, 07:36:54 PM
The respray has stalled a bit, after stripping the old paint I've been filling the many dents and trying to get the profiles correct but it's not am easy job to get it to feel flawless.  Anyway my workshop build has taken my attention for the last few weeks, the roof should be on come next weekend so I'll be able to relax and get back to project 550!
Post by: DomP on February 02, 2025, 07:51:38 PM
Still not much progress on this lately although I did pick up a spare tank complete with cap and fuel flap from Bridgend today, I got for a steal...I think!
I feel in itch to get into it again though with the sunshine we've had today.
Post by: DomP on May 12, 2025, 07:58:36 PM
I've done a thing!
Post by: DomP on May 12, 2025, 07:59:14 PM
My home made cowl
Post by: DomP on May 12, 2025, 08:00:56 PM
Turns out with lots of prep and a polythene booth, spraying is easy.  This is candy midnight forest with 2k clear coat
Post by: Johnny4428 on May 12, 2025, 10:37:01 PM
That’s a lovely colour Dom, I envisaged something like that for my 550 but didn’t quite work out. Going for Candy jade green now which was the original colour. Great to see yours when it is finished.
Post by: Laverda Dave on May 12, 2025, 10:51:47 PM
Great colour. In the words of the departed hot rod builder Boyd Codington 'It's Bitchin'  8)
Post by: DomP on May 12, 2025, 10:56:54 PM
Thanks chaps, it's was from CCR paints, quite a lot of prep work but for rattle cans I'm very very happy with the result I got.  I just need to decide if I apply the standard 550f decals or leave it as is as its a bit of a custom build, what do you all think?
Post by: Laverda Dave on May 13, 2025, 08:38:09 AM
I think I'd be tempted to add some custom decals but in the Honda style font or slightly different.
You could try Diego (Piki) on here or a company called Classic Transfers (they are on the web).
When I rebuilt my Triton I called Classic Transfers and spoke with Ashley who designed the decal as I wanted it. I wanted the name 'Dresda' included within the 'Triton' script. Ashley designed a decal within hours and emailed over the design which was perfect.
I'm sure Diego could probably do the same if you sent him an idea of what you want and he's one of our site sponsors and is super helpful 👍
Post by: Laverdaroo on May 13, 2025, 10:25:43 AM
Lovely colour Dom and a great look especially from rattle cans. A place called IMAGE WORKS have done some stuff for me in the past with great results, have a look on the interweave and they should be easy to find.
A pals bike that was a right mix of bits got finished and they did me some wicked transfers and stickers of the word ‘ Frankenhonda’ but in the Brough Superior font, looked ace.
Great work buddy, keep it going mate
Post by: DomP on May 14, 2025, 08:08:33 PM
It looks good but the lacquer is still soft😭  in followed the process by the letter so not sure why, for now I'm super heating my workshop to try and bake it.  Any ideas greatly appreciated
Post by: Laverdaroo on May 14, 2025, 08:54:36 PM
Sometime’s baking it will soften in depending on the rattle flavour/producer, sunshine has always done it for me but my painting has been a struggle over the years so gave up and farmed it out. I love doing it all except the paint.
Can you leave it in an ambient temp instead and leave for few days, surprisingly when it has gone well for me is when left to cure for a few days up to a week left in the spare room etc.
I’ve always found the clear stage the hardest bit
Post by: K2-K6 on May 14, 2025, 09:31:59 PM
There's difference in IR level from ambient to sunlight, as Roo suggested, it may benefit from sunshine to help "catalyze" the mix.
Post by: DomP on May 14, 2025, 09:34:04 PM
I've turned the heat down a bit, the 2k clear was ProXL Roo.  I'm just hoping all my prep work and making a booth wasn't in vain
Post by: DomP on May 14, 2025, 09:37:07 PM
Well as the sun is looking good for the next week I can get it out on some benches during the day, see if it helps.  It takes me back to having to get my xs650 redone when the guys first attempt failed to harden after 3 weeks.
Post by: Laverdaroo on May 15, 2025, 12:04:55 PM
Just keep yer eye on it Dom, if you think it’s getting hot, move it or have it in a draft at the same time, you don’t want to cook it, just set it if you know what I mean.
Post by: DomP on May 15, 2025, 05:09:16 PM
Got it in the sun now Roo, it seems harder today after a few days at 20 or so degrees.  I wonder how long it will take?
Post by: Laverdaroo on May 15, 2025, 05:46:37 PM
Pass
Post by: Laverdaroo on May 15, 2025, 05:49:39 PM
I saw mine yesterday properly for the first time in three months under a duvet in the container. The ally has bloomed in places and it’s pretty dusty, had a harumph and walked out. Can’t deal with that at the moment!🫤
As soon as I get somewhere I can spread out a bit I’ll get going again but enthusiasm levels are low at the minute while I TRY to find somewhere to live and a job to go with it.
At least I can peruse over yours so hurry up
Post by: DomP on May 15, 2025, 09:14:33 PM
Chin up Roo!  Must be a good time of year to be looking for a job surely?  If you were nearer you could put a tent up in my garden, I'd offer you a room but we seem to have attracted our two eldest kids back home😃
Post by: K2-K6 on May 15, 2025, 09:20:56 PM
Hope you get sorted Roo.
Post by: Laverdaroo on May 15, 2025, 11:16:13 PM
Trying me best as yer do, thankfully it’s been warm and dry and that helps a great deal but I’ve been concentrating on working on my fishery trying to getbb by the access sorted so I can drag some machinery in when situations change. I’ll find something, so far only promises and I can’t function on those. Got a week oop norf to do a pond job for a friend but there’s not much in it, more a change of scenery and I said I’d help him so off up there after next week.
Bit quiet and rather solitary but chipper none the less. Just by the fire with some crap radio 4 extra comedy on, had the blues hour on planet rock, it’s Beyond Our Ken next, that’s always good for a chuckle.
(https://uploads.tapatalk-cdn.com/20250515/f1c5b77db3cebe25c4f87fe32366909e.jpg)
Post by: Laverdaroo on May 15, 2025, 11:18:22 PM
(https://uploads.tapatalk-cdn.com/20250515/f10d8681e5d106efe0b05ca50267867f.jpg)
Enough for a tractor and trailer
Right, high jack over
How’s the paint Dom?……
Post by: DomP on May 16, 2025, 07:24:24 PM
Hmm...the paint is still not hard Roo, out in the sun right now as am I with a beer
*I think its getting harder though so fingers crossed, if it fails I'm not doing it again myself that's for sure
Post by: Oddjob on May 16, 2025, 10:20:11 PM
Not sure where this is going, Roo spotting his todger for the first time in years and then Dom claiming it’s getting hard.
Ohh Matron
Post by: DomP on May 17, 2025, 08:03:26 AM
 🤣 I did think that as I wrote it Ken
Post by: Laverda Dave on May 17, 2025, 10:31:40 AM
Good to see Vic & Bob are back sparring 😂😂.
Really hope you get sorted soon Roo 👍
Post by: Laverdaroo on May 17, 2025, 10:49:28 AM
Not quite sparring yet Dave, I haven’t sunk down as far down to his simple level of intellect yet, just getting ready
Post by: DomP on May 17, 2025, 01:02:08 PM
Refurbed my badges, I've gone for very simple black rubbed through to the base metal silver then a few coats of lacquer.   2K seems to be hardening daily🤞
Post by: K2-K6 on May 17, 2025, 01:45:34 PM
Hopefully all your hard work in painting is not in vain, if it fully reaches it's expected status slowly then that bodes well for longer term permanent condition.
Looks good though  :)
Post by: DomP on May 17, 2025, 03:39:17 PM
I suppose if its not hard in a couple of weeks its not likely to ever be is it?
Post by: Laverdaroo on May 18, 2025, 11:16:37 AM
It will Dom, fret not. Looks good though, that’s a smashing colour!
Post by: Laverdaroo on May 18, 2025, 11:17:38 AM
I’m with you on that Nige,
Post by: DomP on May 18, 2025, 12:54:46 PM
Baking in the sun
Post by: Laverdaroo on May 18, 2025, 12:55:17 PM
Baking in the sun
Good man
Post by: Laverdaroo on May 18, 2025, 12:58:22 PM
You painted the fuel flap the same colour Don, nice one
Never understood why they got painted a different colour, looked terrible! Good skills Dom
Post by: DomP on May 18, 2025, 01:39:56 PM
I did Roo, its not quite as dark as the tank though but not too bad for a first attempt
Post by: DomP on May 21, 2025, 03:27:12 PM
Baking it with an electric heater seems to have done the trick, I'm really paranoid about flatting it all back though😳  CCR recommend 1500,2000,2500,3000 then a polish, any paint guys care to weigh in on this?
Post by: Laverdaroo on May 21, 2025, 04:39:46 PM
I’d go straight to the higher numbered w&d Dom for fear of shredding it. Plenty of water with a squirt of fairy liquid in it and it should rub up well if you’re happy on the set of the paint!
I thought the UV would have done it but chuffed you’re getting there buddy.
Post by: DomP on May 21, 2025, 04:50:10 PM
Yeah its definitely getting there, just splashing the cash on heating the workshop up🤣
Do these carb adjusters look at bit far out?  Most photos I see they only show a few threads.  I think I'm going to get them off and revisit the whole carb thing while the tanks hardening up.
Post by: Laverdaroo on May 21, 2025, 04:52:36 PM
Yeah, a bit I think by happy to be corrected, it’s not a huge job to sort though bud, better to be safe than sorry. I’ve both the 400 and the 550 to do once they see the light of day again. Booo! think yerself lucky
Post by: DomP on May 21, 2025, 04:58:02 PM
I need to just knuckle down and get it on the road
Post by: Laverda Dave on May 21, 2025, 10:18:20 PM
I had a similar issue with the 400/4 carbs Dom. I couldn't understand why so took the carbs off to check. Turned out I had the choke fast idle screw set out too far (the screw that is part of a hex head adjuster and is offset to the hex so as you turn the screw to adjust it it moves concentrically against the carb fast idle lever which is a ramp basically and it in turn raises the carb slides to increase the revs). This only operates when you have the choke on BUT if it is set incorrectly with no clearance when the choke is off the slides will not close properly and you end up winding out those carb adjusting screws as per your photo in an attempt to drop the revs but you won't succeed because the cold start lever has no clearance!
That's how it works on the 400/4 Carbs anyway, it may be completely different on the 550!
Post by: Laverdaroo on May 21, 2025, 10:28:17 PM
I’d forgotten about that Dave, that’s what the issue was when I originally started the 400, completely forgotten about doing exactly the same thing. It suddenly clicked and I did as you just described. I wonder how many people have had just that issue.
It’s 18 months or so since the 550 was started due to fear of glazing the bores and worked on the mudguards, tank etc. I couldn’t run it as I didn’t have a seat anyway until early this year so until I could, starting wasn’t a priority.
Again, can’t remember what I did to get it running nicely, too much crap has occurred since then and my ‘head’s a shed) at the min. The dusty filing cabinet of a memory can’t dig that one out at the min..
Post by: DomP on May 21, 2025, 10:40:32 PM
I think I follow that Dave.  To be honest, getting that part where the throttle comes to a stop on the off set hex you are referring to has been  a bit troublesome.  There are some measurements in the Honda manual that are so sketchy I still can't work out where they are measuring from.
Post by: DomP on May 22, 2025, 08:18:45 PM
Definitely 2nd from top not bottom for 069a carbs? Cb550f
Post by: Oddjob on May 22, 2025, 09:13:42 PM
Yep, 2nd down, on needles marked 273004.
Post by: DomP on May 22, 2025, 10:39:55 PM
Thanks Ken, can you link me to or remind me of the most reliable bench sync that will leave me with the correct amount of travel on the bell crank and idle screw?
Post by: Oddjob on May 23, 2025, 01:16:04 AM
There are a few different ways and I’m not saying one is better than the other but I’ve always used this way myself and it seems to work for me.
Wind the main idle screw fully out so there is no chance of it touching. Now, look down the throat of the carb from the engine side. Adjust the vac screw so that the slide is fully bottomed out, flick the butterfly a few times so the slides lift and settle, just to make sure nothing is sticking. Now adjust the screw until the slide just starts to lift, use a torch on the air box side if it helps, do the same for each carb. Now wind in the main idle screw until it starts to lift the slides ever so slightly. Compare the gap, does it look the same? If so that’s close enough. I always vac gauge mine after anyway just to get that fine tuning. Never had a hanging throttle done this way.
Post by: DomP on May 23, 2025, 09:08:41 PM
Thanks Ken that's essentially how I did it previously but I've found it ends up with a lot of adjuster threads showing and the throttle stop cam cabpnt be adjusted to touch.  I'll have another look at it tomorrow and see where I'm going wrong.
Post by: Oddjob on May 23, 2025, 09:33:31 PM
I thought it was meant to have a gap Dom
Post by: DomP on May 23, 2025, 11:00:31 PM
Maybe I'm talking about the wrong part, the off set bar with a hex section on the throttle bell crank.  I'll do a bench sync and take some photos tomorrow
Post by: DomP on May 24, 2025, 11:26:03 AM
This morning if made a few discoveries, I had set my float heights to 21mm not the 22mm that they should be.  At least one carb had a twisted float, pushing one side up before the other by around 1.5-2mm.  That must mean I'm getting too much fuel through which may be part of my rich running may be?
I then set the bench sync as suggested by Ken, a really simple and effective method I found. I've posted a few photos to confirm its all good to proceed to refitting.  Mr Honda was having a laugh when he agreed on the carb set up on these, I need a first aid kit just to get them out!
Post by: DomP on May 24, 2025, 11:28:44 AM
Carb gaps all look OK?
Post by: DomP on May 24, 2025, 11:31:10 AM
This is the position of my idle screw when just making contact with the adjuster, is this about right?
The cammed stop I'm pointing to with a screwdriver,  is that to set max throttle travel or minimum?
Post by: Oddjob on May 24, 2025, 01:04:37 PM
The screwdriver pointed one is called the Overtravel Stopper and it should have a gap between it and the butterfly of between 8-12 thou or 2-3mm.
There is another screw (with spring) on the back of the same bracket, this is to prevent the slides locking in place if the throttle is opened too wide, you should adjust this so that when the slide is fully up and the edge has just gone above the carb body you use that screw to set the travel to that amount. It is possible to jam the slides right at the top of the carb and this would mean WOT with no way of stopping the engine except the kill switch.
The idle screw should be making contact, it's what sets the idle speed, if it doesn't make contact and the engine idles it means the throttle slides are set too high.
Post by: DomP on May 24, 2025, 01:11:11 PM
Yeah that's just how I've left the idle control until I install the carbs, they are right down as far as they will go with just a glimmer of light entering through them.
Thanks for your help Ken, fingers crossed it will run better once I get them back on.
Post by: DomP on May 24, 2025, 01:47:30 PM
While the carbs were off ive investigated the carb manifold o rings as it has been suggested to me they can be under sized.  Using a piece of clear 4mm acrylic it is clear that they barely contact the acrylic when pressed against it so I have replaced what were new items with some Vesrah spares I had from the engine rebuild oring kit, far better contact!
Post by: Oddjob on May 24, 2025, 08:08:03 PM
Where did you get them?
Post by: DomP on May 25, 2025, 10:28:22 AM
Well I'm absolutely chuffed!  Either the intake orings were seeping in air or my float heights were causing the issue but it now starts and runs pretty perfectly, no hanging idle no stuttering.  Well happy
Post by: Laverdaroo on May 25, 2025, 10:42:21 AM
Get in, nice one Dom!
A successful fiddle and top skills, well done mate
Post by: McCabe-Thiele (Ted) on May 25, 2025, 11:07:39 AM
A great feeling when you fix these issues.👍👍👍
Post by: DomP on May 25, 2025, 12:20:59 PM
It is indeed, a lot of credit goes to members on here, much of what I have achieved has only been appying their knowledge.
Post by: Oddjob on May 25, 2025, 12:24:52 PM
What tickover speed did you get with the throttle slides set to that position Dom, did you need to up it with the idle screw?
Post by: DomP on May 25, 2025, 12:47:05 PM
Only a small amount to get a smooth idle, I'm running a Koso gauge so need to adjust the rpm setting on it by connecting up the original gauges.  There's not a significant amount of miles on the rebuilt and rebored engine so until I can actually get it out on the road again I'm not going to run it for fear of glazing the bores, I welcome any advice on running it in safely.
Post by: Oddjob on May 25, 2025, 04:08:32 PM
We used to say to new owners, 5k revs for the first 500 miles, then first service and after that add another 1000rpm on for every additional 100 miles. Fully run it at 1000 miles or so. Most important of all though was vary the revs, don't let the engine labour, change down on hills even if that means more revs than you should be doing.
Post by: DomP on May 25, 2025, 07:50:38 PM
Thanks Ken that's exactly what Bryan told me, don't labour it nor baby it.
Post by: DomP on May 26, 2025, 08:40:05 AM
Now I've solved the hanging idle problem I can move on to some of the minor niggles I have.  Here is one that's baffled me, the right side cover doesn't fit nor does the resprayed replacement which is odd because the frame doesn't appear cut about, any thoughts folks?
Post by: Sesman on May 26, 2025, 11:18:44 AM
Hi, Dom.
It may be the photo perspective, but something appears odd about that bracket position and associated welding. I’ve attached a few photos of my F2, which may be helpful…or not!
Post by: McCabe-Thiele (Ted) on May 26, 2025, 12:33:40 PM
It does not help that the lower photo showing the swing arm is upside down - unless that's me.
With three location brackets for the fitting holes can you not measure the distance between the two upper holes on the frame, then compare that measurement against the side cover locating pegs. This first measurement should help you point where the problem lies.
How doesn the diagonal measurement differ between the upper left hole and the botton locating one, how does this differ from the right side similar measurement.
Worst case scenario is there might be enough metal to file a locating hole in the right place.
Sorry if I'm stating the obvious.
Post by: Oddjob on May 26, 2025, 12:43:24 PM
How about a pic showing the placement of all 3 holes?
The problem may be one of the others causing the front upper not to fit anymore.
Post by: DomP on May 26, 2025, 01:48:45 PM
Thanks chaps, I'd not considered it being one of the other two brackets so ill get a photo of all three.  That photo is the correct way up Ted
Post by: DomP on May 26, 2025, 02:03:13 PM
Here you go, there has been a tab removed by the top right bracket, I think it was a helmet hook?
Post by: McCabe-Thiele (Ted) on May 26, 2025, 03:33:02 PM
Assuming the 500 & 550 frame are the same the orientation of your top right bracket is different to mine.
If you zoom in on the top right bracket you will see what I mean, the oval slot is the opposite way round.
#(https://live.staticflickr.com/65535/54546826618_93f44207ec_b.jpg) (https://flic.kr/p/2r77KaU).trashed-1717841760-PXL_20240509_094552105 (https://flic.kr/p/2r77KaU) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: DomP on May 26, 2025, 04:01:00 PM
Hi Ted, the orientation is correct on mine for a 550, just not quite in the right place I think
Post by: Oddjob on May 26, 2025, 06:50:05 PM
If you remove the rubbers does it fit then. They look a little thick to me.
Post by: DomP on May 26, 2025, 07:03:38 PM
Nope, this is with no grommets, looks like the top right is at a slightly odd angle to me.  If its been moved I can't imagine why, nothing else has been lopped off that I can see
Post by: Oddjob on May 26, 2025, 09:53:19 PM
Looks ok to me Dom, the welding looks the same as the other bike pictured.
Looking again it does look a little pushed in, top right that is. Try knocking it out a little and see if it helps.
Post by: DomP on May 26, 2025, 10:04:15 PM
Its really weird, is there any chance this frame isn't a 550f frame, except it has everything else F related like the right foot peg and rear brake lever.  I have two sets of F side covers both with the same fitting issue.  It does look a little pushed in Ken but to fit it needs lowering around 5-8mm I think.  Baffled.
Post by: McCabe-Thiele (Ted) on May 26, 2025, 10:37:44 PM
Just trying to think outside the box here, so sorry if I'm being daft.
Obviously the 550 has a slightly different frame to my 500 as the top right mounting bracket has the oval part turned through 45 Deg.
Are the 550 side panels different as well?
Post by: Oddjob on May 26, 2025, 11:05:03 PM
Try fitting the panel one lug at a time, eg top left, does top right still fit?
Then try top right, does the lower still fit?
Try and isolate which bracket seems to be distorted.
Post by: Sesman on May 27, 2025, 11:04:00 AM
Dom, the top right hand lug is the culprit. The top of the lug bracket should run parallel with the top of the frame, thus giving you the 15-20mm of misalignment you are experiencing. I appreciate that no two welds are the same, but yours has been re-welded imho. If other members could provide a photo of their their bracket positions this will become immediately obvious. That’s a bugger🤨
Post by: 3scs on May 27, 2025, 11:29:44 AM
Yours looks the same as my k3 Dom
Post by: Oddjob on May 27, 2025, 11:53:46 AM
After seeing 3scs pics I tend to agree. Look at the angle of the hole between the 2 pics, 3scs has a slot sloping inwards, yours slopes outward.
Dom, where is your earth cable going from the battery? it's supposed to run downwards from the terminal and bolt to the upper engine hanger bolt, yours seems to be going towards the electrical panel under the left hand side panel. The positive cable doesn't look right either. I know you're running a MotoGadget wiring harness but that looks a little iffy to me.
Post by: Sesman on May 27, 2025, 12:00:10 PM
Like dis…
Post by: DomP on May 27, 2025, 02:55:12 PM
Do you think its in a k3 frame, come to think of it the riveted frame number looks like its been cut off and refitted.
Earthing Ken, it seems to have more than is necessary to me, no two ways about it, its been bu@@ered about with before I did my thing to it😅
Just as well I didn't get tge frame powdercoated and did a diy job on it with a brush I suppose, get the dremel out and lop it off is the only solution.  Get to try out my lack of welding skills again
Post by: Oddjob on May 27, 2025, 05:47:43 PM
There are some differences between the F and K3 frames. The biggest difference is the swinging arm but it may not have that on anymore. Post a pic of the swinging arm and let's see if it's an F or a K3 one.
Did the frame come with a small plastic box near the coils, for all the switchgear wiring to go into?
Post by: DomP on May 27, 2025, 07:03:05 PM
How's that Ken?
Post by: Bryanj on May 27, 2025, 07:56:20 PM
That top rear mout looks wrong to me, sure it should be orizontal
Post by: DomP on May 27, 2025, 08:09:40 PM
That's just a perished old grommet that was fitted when I first got it, I'm now certain its the top right having been removed and welded back on in the wrong place, I'm not sure why it would have been though.
Post by: Oddjob on May 27, 2025, 09:35:17 PM
The swinging arm is 550F, the frame plate says it’s a 550F. Does the frame number correspond?
Post by: DomP on May 27, 2025, 10:46:00 PM
I thought it was an F swingarm due to the closed ends, the frame number on the headstock is so painted over its illegible, I'll rub it back this week with my dremel
Post by: DomP on May 29, 2025, 07:49:13 PM
Yesterday I flatted back the 2K lacquer and polished with my DA polisher, real quick way to get a mirror like shine and take a nick out of your freshly painted side cover when using one handed😤  luckily only small so I think I should be able to touch it in.
Post by: Oddjob on May 29, 2025, 11:08:36 PM
Without a front mudguard brace you will find the forks flex more. Maybe consider a fork brace that clamps around tge top of the sliders, that should suit the look.
Post by: Laverdaroo on May 30, 2025, 03:51:51 PM
Might have one Dom but no mudguard.
That looks ace Dom
Post by: DomP on May 30, 2025, 06:15:33 PM
I might chop up my front mudguard and use it Ken, I'm not sure what i think of the mudguardless look quite but a trimmed down one will look good I think.
Thanks Roo, I might take you up on the offer, still got those yss shocks?
I meant to say, I cleaned up the headstock and it matches the frame number on the plate so definitely an F frame and correct, only solution is to cut the tab off and weld it back correctly, not looking forward to that!
Post by: Laverdaroo on May 30, 2025, 08:38:39 PM
Still got em Dom
Post by: McCabe-Thiele (Ted) on May 31, 2025, 09:25:51 AM
In the absence of welding is there any way you could alter the existing slot so that the panel tag will fit ?
e.g. Open the slot or file it so you could attach a sort of extra cover plate with a small bolt or pop rivet to hold it in place?
Might be too much of a bodge, are there alternative ways of holding the covers in place with a stud latch on the frame?
Post by: DomP on May 31, 2025, 09:31:28 AM
I am thinking this Ted, not sure what the plan is yet. I've got a cheap mig welder but it's splattery and inaccurate (my excuse anyway) my brother has a stick welder which he says is more accurate, might try that on some scrap first.
Post by: K2-K6 on May 31, 2025, 10:55:24 AM
Definitely worthwhile to practice on something first.
Hot tip ..... keep any welding rods (anything "fluxed" really) in an airing cupboard. The flux is hygroscopic and so absorbs moisture, spatters like buggery when used.
Be generous with thickness of new tab as the weld will be more even between thick frame wall tube and bracket from them being more equal. Welding very thin plate to thick will just make it harder as it melts the thin first.
Try and drag the stick tip to get arc rather than stab it, it'll usually spark up easier without getting stuck. Always gets stuck = raise amps. Always blowing away material = drop amps.
The "stick" on non mig should be definitley a little less diameter than thickest material as general guide.
Post by: DomP on May 31, 2025, 09:10:17 PM
Thanks for the welding tips K2, might come to that but I can just about force the side cover on if a distort it so I may just do as Ted said and file the tab hole out by 4-5mm rather than set my bike on fire.
I took it out for a little test ride this afternoon, not perfect yet, it's bogging down/hesitating at lower revs.  That was at 1½ turns out on all carbs so I returned home and tried at 1¾ turns out, may have been some improvement but I had to call it quits for the day when a neighbour calld around.  It crossed my mind to check the timing while running with a strobe, it was slightly retarded so i adjusted to the F mark, its advancing as it should when revved, its only running on a bench sync so I'll get my Morgantune on it tomorrow.  Keep the revs below 5k for the first 1k miles?
Post by: Oddjob on June 01, 2025, 12:56:09 PM
500 miles is ok Dom, then start to increase every 100 miles. So 6K at 600 etc.
Try and use the choke when it starts to bog down, if it gets better it's too weak, if worse it's too rich. Just a small amount, not full choke. I suspect the mixture.
Post by: DomP on June 01, 2025, 01:13:01 PM
Thanks Ken, its definitely getting there, I've just rechecked the
 camchain out of paranoia and redone the Dyna S timing statically with a test light I threw together, it was a bit out so that may be a big part of it.  I'll do a test with a strobe next
Post by: DomP on June 17, 2025, 09:37:39 PM
Finally got my seat done, I tried to do it with my mum who was excellent with any type of sewing, she really struggled with getting her head around it due to the chemotherapy she was having at the time so I left it on the to do pile.  Sadly she passed away in March so it has taken me until now to have the enthusiasm to sort it out, I found a local upholsterer who has done an excellent job in her memory I think.
Post by: Bryanj on June 18, 2025, 01:23:08 AM
Well done Dom, its not easy to do things like that.
Post by: Sesman on June 18, 2025, 08:03:05 AM
Nicely done Dom. The whole package is looking really nice and neat. Just one question: should the exhaust bracket be on the inside of the foot rest hanger? I’ve been puzzling over this on mine.
Post by: DomP on June 18, 2025, 04:57:35 PM
I did wonder this but as the hanger is threaded this was the neatest way to bolt it on utilising the thread.  No matter how I tried ive ended up with no.2 exhaust manifold very close to the oil filter housing..like very close.
Post by: DomP on June 18, 2025, 04:58:51 PM
Thanks Bryan!
Post by: Laverda Dave on June 18, 2025, 10:59:20 PM
Lovely job Dom. I know how difficult is can be to make a one-off seat as I was a coach trimmer back in the day and regularly trimmed motorcycle seats in my lunch break for people at Acton Train Works (I did a few customized Hillman Avengers and Hunters as well. Back then people wanted their seats and door cards trimmed in 'draylon' and deep buttoned!).
Post by: DomP on June 18, 2025, 11:01:58 PM
I'm really happy with how it's all turned out except the paint job i did, the 2k lacquer is still not fully hard after all these weeks
Post by: DomP on June 21, 2025, 03:23:23 PM
Ive just taken it out for another run after playing with the static timing again, its still running really rich at 2 turns out i think.  Symptoms are spluttery pulling off and hesitance, not wanting to go much past 4k and sounding lumpy
Post by: Bryanj on June 21, 2025, 03:49:28 PM
What sort of air cleaner cover do you have and what size jets?
Post by: DomP on June 21, 2025, 04:36:25 PM
All standard Keihin jetting for 069a carbs Bryan, the air filtervis a standard F type but missing the rubber snorkel so I covered the hole in mesh but quite coarse.  I'll post a photo
Post by: DomP on June 21, 2025, 04:38:34 PM
Could this be too free flowing?
Post by: Bryanj on June 21, 2025, 05:55:05 PM
Doubt it, from what you describe its too rich.
That would give similar airfow to 500 which does have larger jets than 550
Post by: DomP on June 21, 2025, 06:09:47 PM
Its better at 2⅛ to 2¼ turns out so do I just keep going until I get a good amount of rideability?  Its better but still has a significant flat spot at low revs then fly.
Post by: Bryanj on June 21, 2025, 06:59:48 PM
Cant answer that one sorry
Post by: Oddjob on June 25, 2025, 03:55:20 PM
Dom do all the jets bear the Keihin K logo?
I’m thinking someone has used a carb kit on your carbs in the past and the problem is the float needle valves and seat. A lot out there wouldn’t stop petrol flowing past if you held them against each other with your fingers. Lot of reports of the tip of the float needle being made off centre so fuel just leaks past, which would make the engine run rich as hell.
The only way to test is to remove a float bowl, turn on the petrol and use a float height setting tool set to 22mm and use that to lift the float, if the fuel stops when it reaches 22mm then it’s ok, if not then you have a problem. Container under the carb of course. I seem to recall genuine Honda float needles has rubber tips whereas copies just had steel tips. If it doesn’t stop at 22mm see if it stops at a higher setting, if it doesn’t stop at all then you need to replace that entire setup.
Post by: DomP on June 25, 2025, 05:19:13 PM
All genuine jets Ken, I've stripped and replaced all orings etc in the carbs.
The float needles are fully metal, ie no viton tips so maybe worth replacing them, where can I get them as replacements?
Post by: DomP on June 26, 2025, 01:22:40 PM
Nothing i can find suggests they were rubber tipped Ken, everything seems to be metal.
Post by: McCabe-Thiele (Ted) on June 26, 2025, 07:05:49 PM
I'm a tad confused Dom, all this talk about the float valves?
Are the carbs flooding?
If not certainly worth ensuring the levels are correct.
Post by: DomP on June 26, 2025, 08:45:44 PM
No flooding Ted, I think Ken was wondering if they were letting fuel through causing rich running as at 2¼ to 2½ turns think i might be a bit rich on some cylinders. No2 and 3 run quite a bit hotter on the exhaust headers
Post by: McCabe-Thiele (Ted) on June 27, 2025, 09:00:21 AM
Are the carbs synched Dom, if 2 & 3 are a tad on the rich side or could it be float heights?
Do you suffer some hanging throttle issues?
Post by: DomP on June 27, 2025, 05:29:04 PM
Id like to think the float heights are correct now, I spent ages fettling them with vernier calipers, I do need to tweak the carb balance a bit so that might settle the 2/3 issue.  Hanging idle seems to be a thing of the past thankfully.
Post by: DomP on July 06, 2025, 02:14:19 PM
I'm struggling to get some decent uninterrupted time on this at the moment, as it's a straightforward job and not time sensitive I thought I'd check my float heights on level ground, number 3 carb seems a little low but all others I believe to be good.  What is the effect of a slightly low float height?
What do you all think?  My carbs have a definite slope down towards the engine on the centre stand is this of significance?
Post by: DomP on July 06, 2025, 04:32:45 PM
I've been out on a 15 mile run having balanced the carbs with a Carbtune about as close as I could get them.  Things I've noticed are the following-
Just a recap on the set up, 550f with genuine keihin jets and carbs set to factory.
•Still bogging down below 3k to the point I have to drop a get away
• top end seems to hit a bit of a wall at 5.5-6k but I am being careful due to the rebuild .
•the front suspension bounces like tigger at about 30-40 mph, I wonder olive ive used too light an oil so may replace with something a bit thicker.
Other than that at cruising speeds on main roads its very smooth
Post by: Bryanj on July 06, 2025, 05:29:14 PM
There is no power below 3,000 would be my comment, top end could be timing
Post by: DomP on July 06, 2025, 06:52:45 PM
To the point it wont pull away Bryan?  Ignition is a Dyna S which ive set up statically with a test light following several YouTube videos, I'm sure its right having watched several different videos but happy to be wrong.
Post by: Bryanj on July 06, 2025, 07:33:11 PM
Personally would try it with original points, are you using the Honda coils or Dyna?
Post by: DomP on July 06, 2025, 09:37:26 PM
I'm using Honda original coils that I've done Ash's fix on with new leads, it came with the Dyna so I don't have the original points.
Post by: Bryanj on July 07, 2025, 06:51:52 AM
I read recenrly somewhere the Dyna now say only use their coils, but then on us site also read of a lot of dyna failures
Post by: DomP on July 07, 2025, 08:10:03 AM
I have read of a few failing, not sure which way to go now im beginning to loose patience a bit.  Time for a holiday i think!
Post by: Johnny4428 on July 08, 2025, 08:39:29 PM
My 750 has Dyna s and Original coils runs great!
Post by: DomP on July 08, 2025, 09:11:53 PM
I have to admit I'm reluctant to remove it.  I need to read a comprehensive guide to carb tuning, I don't know whether in coming or going, rich or lean!  On one hand everything points to rich with sooty plugs and stinking of fuel then I lean it out to 2 ¼ turns out and I've got kangarooing at lower revs and bogging down but suddenly racing away once I hit 3k.  I'm not giving it fistfuls but feeding in the throttle.  I feel I'm close at times but my lack of carb knowledge leaves me confused.
Post by: Laverda Dave on July 09, 2025, 01:14:49 PM
Hmmm, recent Dyna failures. Dyna were a highly regarded name for ignition systems and coils. I wonder if this is maybe linked to manufacturing changes. Are Dyna still manufacturing in the USA or have they gone like all the rest and moved manufacturing to China?
Post by: Rozabikes Tim on July 09, 2025, 01:50:42 PM
The "orange one" will some tariffs on them if so!!
Post by: DomP on July 13, 2025, 09:14:11 AM
Could any of my rich running be related to me running a modified air box? Be ause mine had most of the recirculating parts missing I've plugged the airbox hoses and am running a 550k or maybe a 500 air filter without the hole in the bottom for the air breather.  The lid is from an F model as it should be but is missing the snorkel so I've just glued a stainless mesh over it.   I'd have thought this would all be less restrictive so if anything would tend towards lean?
Post by: Skoti on July 13, 2025, 11:58:48 AM
Mines was bogging down and hesitating at lower revs, tried all the usual stuff such as air filter, pilot jets and mains.
Bloke at the moto piston rally in Spain with a high mileage F1 told me the needles and needle jets would need changing, he was correct it ran beautifully after that.
Title: Re: Doms CB550F1 project
Post by: DomP on July 13, 2025, 04:41:18 PM
Getting new genuine needles and emulsion tubes, I'm not sure that's likely in the UK.
Post by: Skoti on July 13, 2025, 05:24:46 PM
I got a genuine set sent from Australia, then later a spare set from a Honda dealer in Sweden.
(But since then the've become available in the UK again)
I just looked up the part number on CMSNL and then google searched worldwide.
But of course 550F1 stuff maybe much more scarce.
Anyhow good luck.
Post by: DomP on July 13, 2025, 06:27:46 PM
Anyhow good luck.
Im not sure Skoti but I will certainly look into it, in the meantime I do wonder if this it too free flowing
Post by: Bryanj on July 13, 2025, 06:58:18 PM
More air should make it weak not rich
Post by: DomP on July 19, 2025, 07:09:16 PM
What is an acceptable max temperature for the engine block? My manifolds are a little varying in temp using a temperature gun, 1, 2 and 4 seem to be low 70s where as no 3 runs a good 10°C hotter with the block measuring high 90s bar cylinder 3 again which i just got 120°C with my gun.  Seems a bit improbable to have such a gradient so close together.
Incidentally, doing a plug chop only no3 was close to the pale brown colour on the white insulator section.
*following this i decided to double check my dynamic timing which is looking spot but there is a but, and I think it may be interesting.  On 1 and 4 I cant get the timing light to flash consistently, thus has got me questioning the 1-4 coil or its leads.  Another observation is that when raising the revs from idle it gets to 2000/2200 they fly past 3k to 4 with literally no control, I cant hold 3k for love nor money.  Is this the switch from pilot to main jet causing problems?
Post by: DomP on August 25, 2025, 04:18:46 PM
Still d**king around with my carbs!  Can anyone help with this little conundrum, at idle I get a different reading across the four than at 3k for example, where one carb is lagging behind at idle, it is then ahead at say 3k?  See pics
Post by: McCabe-Thiele (Ted) on August 25, 2025, 05:37:18 PM
I'm no expert my thoughts are, at idle you are running on different fuel metering jets than when you are running at 3k with no real world load on the engine.
Post by: DomP on August 25, 2025, 05:41:28 PM
That was my thinking Ted, if I then I each air screw individually that carb struggles so suggests the passages are clear or working, just that some carbs react more to throttle making syncing impossible
Post by: Seabeowner on August 25, 2025, 07:00:28 PM
The manual only specifies measurement at low revs. Think it's a big ask to get it over a wide rev range.
Post by: DomP on August 25, 2025, 07:48:59 PM
Its actually not as bad is I'd thought,  just not as close at 3k as at 1000-1200, still the revs are hard to raise slowly with the throttle without it leaping from 2500 up past 3500-4000.  I presume thats as the advance kicks in, the springs have been trimmed by a PO
