Author Topic: OUT AND ABOUT 2025  (Read 245885 times)
Offline Moorey
Re: OUT AND ABOUT 2025
« Reply #150 on: May 14, 2025, 07:15:50 PM »
Not sure how adding dyed water to the petrol in the Breeze Blocked laboratory is a reliable scientific basis to judge Shell E5 Ethanol content or how cleanly it burns.
The prices quoted for Shell SUL seem off the scale, in Derby it's 164.9, BP SUL  is 150.7 locally, the price difference between E10 & E5 is 29p.
It's a very simple test and quite accurate that anyone can do and the prices reflect when the vid was made.
« Reply #151 on: May 14, 2025, 07:33:38 PM »
Out at Biker night
H j Pugh, Ledbury
Massive bike auction this weekend
Lots of Hondas
« Reply #152 on: May 16, 2025, 01:24:54 PM »
Out at the local VMCC chapter!!
Couple of interesting bikes
« Reply #153 on: May 16, 2025, 01:48:35 PM »
Different, GT 750 clocks on the RE5 and disc braked, unit engined Triton
« Reply #154 on: May 16, 2025, 06:47:05 PM »
Triton looks all wrong...I wonder if it's just the angle of the piccies? Start point is the tyres are odd...too small or too low profile?
Then the rest just looks like all the right bits, but they don't seem to meld together very well - I'm sure if the wheels/tyres were right it would look ok. ( Disclaimer...I'm not knocking someone else's  build as I know it's all personal and always takes a lot of work!).
« Reply #155 on: May 16, 2025, 07:33:12 PM »
It's always difficult to build a Triton with a unit engine. There's a lot of 'open space' to deal with around it hence why the purists go for a pre unit motor, a bit more spaced out.
Dave Degans got the right combination with the unit motor in the Dresda. The front engine plates pushed the motor back a little to fill the gaps. The shape of the oil tank is also critical, again to fill the gaps. Same with the fuel tank, I deliberately used a short circuit tank on mine that sits on top of the frame rails with little overhang at the sides. Fitting a big Manx style tank accentuates the unit engine making it look a bit lost in a wideline frame.
But....as Andy rightfully states, it's how the builder wanted to build it and building a good looking and functional Triton isn't easy so hats off to anyone who attempts to build one👍
« Last Edit: May 16, 2025, 07:39:35 PM by Laverda Dave »
« Reply #156 on: May 16, 2025, 07:38:00 PM »
I don't particularly like the disc brake though on it, just doesn't suit it although I can understand why it is fitted, he wants to stop!
I've seen a couple of Tritons that have used the Honda CBX550 inboard disc brakes fitted to spiked rims and suitably machined, they both looked fantastic, like a drum but actually stops.
I looked into doing the same but anyone with a CBX550 front brake knows exactly what they are worth and used for these days.
« Reply #157 on: May 16, 2025, 08:43:44 PM »
And whats more a rear pia to work on!
« Reply #158 on: May 16, 2025, 09:03:06 PM »
There's other concept too https://www.quattroworld.com/audi-news/audis-world-ufo-brakes-worked-also-kinda-didnt/ shows an interesting design.
It wouldn't be that difficult to get something like a drum looking hub with spoke facility to house one of these, then a Buell internal type caliper arrangement  modded to use.
Offline Rozabikes Tim
« Reply #159 on: May 16, 2025, 09:04:58 PM »
Come on Dave show us yours!!
« Reply #160 on: May 17, 2025, 10:22:16 AM »
Here you go Tim. I fitted what is called 'swan neck' clip-ons, I'm too old and inflexible now to ride with my chin on the tank 🙄. I'm still to run it in!
« Reply #161 on: May 17, 2025, 10:45:31 AM »
Thats a lovely looking Triton Dave, back in the 1960's there was always the odd Triton in the bike sheds at Derby Technical College, none looked half as nice as yours.
« Reply #162 on: May 17, 2025, 10:53:13 AM »
Thank you Ted.
I've changed the front and rear mudguards since those photos were taken because I didn't like the gap between the rear guard and wheel. I fitted Dunstal pattern guards that fit a lot closer and follow the line of the wheel. That's the trouble with building a special, it's never finished!
« Reply #163 on: May 17, 2025, 11:16:00 AM »
Very nice Triton
Well done
Online Skoti
« Reply #164 on: May 17, 2025, 11:45:31 AM »
That's a real beauty, a proper bike.
Skoti
1976 Honda CB750F1
