Author Topic: Importing a bike and NOVA  (Read 22580 times)
Re: Importing a bike and NOVA
« Reply #30 on: September 23, 2026, 06:59:27 PM »
Yes you can reuse a solid copper gasket, heat to cherry red and quench in water
Offline Big Dave
« Reply #31 on: September 24, 2026, 03:09:46 PM »
Springy thing is a Lucas flasher relay . Spring supposedly isolates it from vibration . Ha ha ha !
Offline Skoti
« Reply #32 on: September 24, 2026, 04:09:21 PM »
two wire, think this is it. I would have liked a replacement zener diode they look good under the headlamp, but the combined reg/rectifiers are reasonably priced, think it’s a straight forward upgrade.
You may find that a modern combined reg/rectifier has to be neg earth.
Al Osborn the electrical guru over on the NOC site sells stuff and offers advice on Brit Bike electrics.
He also does regulators for neg or positive earth systems.
http://www.aoservices.co.uk/products.html
Skoti
1976 Honda CB750F1
Offline Alimacdee2
« Reply #33 on: September 25, 2026, 09:56:07 AM »
thanks good site, wish I’d seen that earlier http://www.aoservices.co.uk/products.html,
already have one of those cheap Single Phase Rectifier-Regulator +- units off eBay just to get things started, nearly ready to start wiring in the loom, I’ll upgrade as I go along coils.
And I thought the spring thingy improved output!
« Last Edit: September 25, 2026, 10:11:01 AM by Alimacdee2 »
1970 HONDA CB750
2002 Ducati Monster 750ie
1971 Triumph Trophy T100C
Offline flatfour
« Reply #34 on: October 05, 2026, 04:46:13 PM »
From experience when replacing the pushrod tube seals on the Trident that I own, it is important to ensure that the correct pushrod operates the intended valve, as it is really easy to let them cross over when refitting the rocker boxes. Might be the same on the twins?
There is a method that worked for me that worked, which was to mark a section of the pushrod and its associated valve with a permanent marker pen, so that you are able to confirm matters when lowering the rocker box into place.
« Reply #35 on: October 05, 2026, 05:02:04 PM »
Scrupulously clean and no goo to seal the pushrod tubes, plus the correct O rings/seals which changed several times
Offline Alimacdee2
« Reply #36 on: October 09, 2026, 12:18:27 PM »
thanks I'll definetly be careful with that, did label them L/R F/R with masking tape when I removed them, looked okay to me in my limited knowledge of pushrods, the cam followers same. realising the importance right tools for these as advised, finding some nasty butcherd Nuts not nice viewing, need to buy a clutch hub center puller next 1" x 20TPI among others. My diy electroplating is going well though but sad I'm using up my Trustan rust converter on the rear light holder.
« Last Edit: October 09, 2026, 01:01:08 PM by Alimacdee2 »
1970 HONDA CB750
« Reply #37 on: October 09, 2026, 06:16:01 PM »
Trustan - I've not seen that product in 20 years or more
Darn good stuff.
« Last Edit: October 09, 2026, 07:35:20 PM by McCabe-Thiele (Ted) »
« Reply #38 on: October 09, 2026, 06:54:59 PM »
Its been a long time but my memory says the pushrods fit anywhere anyway, cam followers rarely wear just watch which followers fit which cam, the famous E3134 cam needs followers marked with an R which denotes a different radius, cardboard jammed between the follor rods to fit barrels
Offline Alimacdee2
« Reply #39 on: October 11, 2026, 05:22:46 PM »
Just scored a toolbox full off imperial spanners for a fiver this morning! some whitworth havent looked to closely yet they need a good clean first, bit of a mess but thought I had to grab them, was going to give them a scrub maybe paraffin, or does vinegar actually work?
« Last Edit: October 11, 2026, 05:29:03 PM by Alimacdee2 »
1970 HONDA CB750
« Reply #40 on: October 11, 2026, 05:32:07 PM »
Rub with a bit of steel wool on the worst bits and then Solvol Autosol on the chrome.
Lazy way is just spray them with AC50 or WD40! 😁
Offline Alimacdee2
« Reply #41 on: October 11, 2026, 06:00:24 PM »
thanks Ill get the steel wool and chrome cleaner out,  the  finish on some really bad will soak worst ones in vinegar,
Well pleased ringers are mostly Whitworth have polished up good,
just to update, vinegar 24hrs has worked well then a degreaser and chrome cleaner with steel wool to stop flash rusting,
« Last Edit: October 12, 2026, 11:12:49 PM by Alimacdee2 »
1970 HONDA CB750
Offline Alimacdee2
« Reply #42 on: Today at 12:11:48 AM »
Hi all,
Could these marks be buffed out I wonder?  small ends are in good condition, ding at small end god knows how it got there,  new rods for these are a bit pricey, may have to go new but would prefer to save these. I just wonder if these little triumphs are prone to break rods? plan was a bike for occasional green laning, difficult to resist an occasional blast though, I like speeding on the Honda again! any advice setup to check crank runout?  I have the dial gauge I used to check the Honda crank which was handy using lower crankcase if I remember correctly. Crank bearings in spec could do with a polish I believe,  tarnished on outer bush, still to do sludge trap.
difficulty adding photos at moment
« Last Edit: Today at 12:38:06 AM by Alimacdee2 »
1970 HONDA CB750
« Reply #43 on: Today at 01:16:09 AM »
I have seen broken rods but not common, damage like that is always a worry, are there no used rods about?
Do remove the big plug and the sludge trap in crank they are always bunged up, from memory a web bolt has to come out as well
