Author Topic: CB750K8 Project  (Read 93926 times)
Re: CB750K8 Project
« Reply #105 on: February 14, 2015, 06:10:52 PM »
Nice work
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #106 on: February 15, 2015, 09:51:16 AM »
Decided on colour
Its going to be the red pearl 3 stage finish as used on Clio.
Looking forward to seeing how it turns out and will decide whether to use original style decals.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750K8 Project
« Reply #107 on: February 15, 2015, 10:16:07 AM »
That's a great colour in the flesh Martin. Very vibrant an in-keeping with the 70's flake colour schemes. Nice choice...
Offline martin_uk
Re: CB750K8 Project
« Reply #108 on: February 15, 2015, 10:57:55 AM »
Thanks James, Im  always a bit nervous about choosing non standard colours as its expensive to change!  Will post some pics when I get back.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750K8 Project
« Reply #109 on: February 15, 2015, 11:21:16 AM »
I saw that colour on a Clio abroad greaming in the sunshine and it looked awesome. Thought to myself if I ever do a non-standard colour that would  be the one.
Ash
Offline UK Pete
Re: CB750K8 Project
« Reply #110 on: February 15, 2015, 12:18:20 PM »
Agreed with others , a stunning colour
pete
Re: CB750K8 Project
« Reply #111 on: February 15, 2015, 06:30:31 PM »
Yeah horny ;)
Bitsa
Offline hairygit
Re: CB750K8 Project
« Reply #112 on: February 15, 2015, 07:25:08 PM »
Yeah horny ;)
Bitsa
Getting worried about you Bitsa, you're describing the colour of a FRENCH car as horny? You'll be leaving your wife for some frog tart next!:o
Offline martin_uk
Re: CB750K8 Project
« Reply #113 on: February 15, 2015, 08:23:03 PM »
Thought I had better make a start on the oily bits.
Parts of engine are pretty grungy with caked on dirt.
2015_0215engine0023 by nitram2010, on Flickr
Looks like someone tried to spray part of front section
2015_0215engine0021 by nitram2010, on Flickr
Position of alternator lead clamp
2015_0215engine0034 by nitram2010, on Flickr
Oil filter housing looks quite clean
2015_0215engine0025 by nitram2010, on Flickr
No nasties in filter
2015_0215engine0027 by nitram2010, on Flickr
Even the filter washer is present
2015_0215engine0026 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #114 on: February 15, 2015, 08:30:26 PM »
Looks OK in sump
2015_0215engine0030 by nitram2010, on Flickr
Pick up gauze clear
2015_0215engine0031 by nitram2010, on Flickr
Brown dust gets everywhere
2015_0215engine0006 by nitram2010, on Flickr
2015_0215engine0002 by nitram2010, on Flickr
Points plate
2015_0215engine0003 by nitram2010, on Flickr
Position of overflow pipe guide
2015_0215engine0008 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #115 on: February 15, 2015, 08:43:04 PM »
Looks to be pretty standard and not been split before
Points harness route
2015_0215engine0010 by nitram2010, on Flickr
Bolts will need attention
2015_0215engine0012 by nitram2010, on Flickr
Clutch looks reasonable
2015_0215engine0013 by nitram2010, on Flickr
2015_0215engine0014 by nitram2010, on Flickr
You can see they were originally assemble up side down
2015_0215engine0016 by nitram2010, on Flickr
Inside casing look good
2015_0215engine0019 by nitram2010, on Flickr
Some of cover screws tight, but impact driver removed OK
2015_0215engine0037 by nitram2010, on Flickr
Starter reduction gear, spindle  and washer
2015_0215engine0044 by nitram2010, on Flickr
2015_0215engine0046 by nitram2010, on Flickr
Lifted out starter motor using one of the long M6 bolts
2015_0215engine0049 by nitram2010, on Flickr
Front sprocket pretty worn
2015_0215engine0058 by nitram2010, on Flickr
Lots more gunge
2015_0215engine0053 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #116 on: February 15, 2015, 08:58:32 PM »
Last CB750 I did selector mechanism had been partially dismantled and took a while to work out where all the bits go.
Cable tied in order to save time on reassembly
2015_0215engine0061 by nitram2010, on Flickr
Put a nut on bolt to hold in correct position
2015_0215engine0064 by nitram2010, on Flickr
2015_0215engine0067 by nitram2010, on Flickr
Bearing end cover screws were very tight but came out with impact driver
2015_0215engine0072 by nitram2010, on Flickr
Alternator rotor bolt was very tight, had to turn air pressure right up using impact wrench to remove.
Bolt to pull rotor off
2015_0215engine0074 by nitram2010, on Flickr
Cable tied starter drive gear to rotor as one way clutch plungers and springs have a tendency to pop out
2015_0215engine0076 by nitram2010, on Flickr
Very strange, as I removed this bolt there was a hissing, I guess thge corrosion process had created pressure.
2015_0215engine0078 by nitram2010, on Flickr
Casing looks quite clean and bearings good
2015_0215engine0079 by nitram2010, on Flickr
2015_0215engine0081 by nitram2010, on Flickr
Main bearing journals look good
2015_0215engine0082 by nitram2010, on Flickr
Overall quite pleased so far as no nasty surprises :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #117 on: February 19, 2015, 05:41:00 PM »
Got to grips with the switches.
Left hand was sun bleached and dip switch would not move.
004 by nitram2010, on Flickr
2015_0210frame0017 by nitram2010, on Flickr
Had to take horn switch apart to clean contact to get a good resistance reading.
Cleaned the dip switch contacts in situ to avoid problems reassembling
The insides of switches are full of brown dust like the rest of bike.
2015_0210frame0040 by nitram2010, on Flickr
I took apart the indicator switch and cleaned contacts with wet and dry, contact cleaner and ACF50
2015_0210frame0015 by nitram2010, on Flickr
2015_0210frame0021 by nitram2010, on Flickr
2015_0210frame0022 by nitram2010, on Flickr
US bikes have extra wiring for marker lights in indicators
Mechanism is fairly simple as U shaped contacts just slide left or right to join together various wires.
2015_0210frame0025 by nitram2010, on Flickr
Vaseline is great for holding contacts, balls and springs in place when reassembling.
Found an old switch with good condition kill switch to replace original
2015_0210frame0001 by nitram2010, on Flickr
2015_0210frame0006 by nitram2010, on Flickr
2015_0210frame0007 by nitram2010, on Flickr
Thought about converting from US spec with lights on all the time to UK spec, but decided to leave original.
Start switch was fiddly as it cuts power to lights on start and switch came apart without me seeing exactly how it went together.
2015_0210frame0037 by nitram2010, on Flickr
2015_0210frame0038 by nitram2010, on Flickr
Cleaned up cases and painted with Simoniz tough black satin.
2015_0219switch0015 by nitram2010, on Flickr
Touched in writing in Humbrol red model paint, fine brush, leave a few minutes then dab off excess with folded kitchen towel.
2015_0219switch0017 by nitram2010, on Flickr
2015_0219switch0018 by nitram2010, on Flickr
I will clean off smudges when dry
2015_0219switch0014 by nitram2010, on Flickr
And finally new PVC harness covers.
Checked all resistances and seems good, next job is to fit to bike :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline UK Pete
Re: CB750K8 Project
« Reply #118 on: February 19, 2015, 07:38:53 PM »
Great work on the switch martin, good observation on the fact they sealed the cases upside down as well
pete
Offline martin_uk
Re: CB750K8 Project
« Reply #119 on: February 19, 2015, 10:36:02 PM »
Ordered up a made to measure stainless  braided black covered front brake hose £20.
On the K8 there is no splitter/brake switch union and switch is fitted to master cylinder.
Old one measured at 800mm with 30 degree bent on banjo end.
2015_0219switch0001 by nitram2010, on Flickr
Supplier (furoreproducts.co.uk) advises female bulkhead fitting suitable for concave and convex flare.
2015_0219switch0003 by nitram2010, on Flickr
I am not fully convinced, but worst case will make up new metal pipe with convex flare.
DSS pattern pipe
2015_0219switch0007 by nitram2010, on Flickr
2015_0219switch0005 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
