Author Topic: Honda CB400NA Superdream - new money puddle.  (Read 196576 times)
Re: Honda CB400NA Superdream - new money puddle.
« Reply #240 on: March 26, 2025, 10:04:01 PM »
Today I manged to undo all 8 of the screws that hold the two carbs together, a couple were quite stubborn but came out eventually.Its a sort of upper and lower bracket arragement rather than a normal manifold. The two brackets have quite bad surface corrosion, they are a yellowish colour originally I think. Is this some sort of Zinc plated finish?
Is there an inexpensive way to improve the appearance, Gold coloured metallic paint perhaps if it can take the heat?
« Reply #241 on: March 26, 2025, 11:33:41 PM »
Ted, Without seeing it, hard to be sure. Probably zinc plated, yellow passivated.
« Reply #242 on: March 27, 2025, 08:39:56 AM »
Thanks, I couldn't remember the yellow passivated expression, I'll see if my local platers offer an affordable service.
« Last Edit: March 27, 2025, 08:43:40 AM by McCabe-Thiele (Ted) »
« Reply #243 on: March 27, 2025, 10:10:06 AM »
I collected these items for the TL125 yesterday Ted. £40 in total although I did clean them all up, de-burred and wire brushed everything before I took them in.
« Reply #244 on: March 27, 2025, 12:47:52 PM »
I think they left the yellow parts in the passivate a bit too long Dave, that's damn near gold, it's supposed to be a light yellow.
« Reply #245 on: March 27, 2025, 01:03:14 PM »
I think it's the flash on the camera Ken, its much darker than that in real life. The coil holder is a difficult part to plate apparently because its laminated the passivate drips out from between the laminations as its drying causing streaking (although Gary the plater has been in the ttrade for so long he doesn't get that problem).
« Reply #246 on: April 11, 2025, 01:29:48 PM »
My M3 X5 x 0.5 mm brass washers arrived a couple of days ago, they are a perfect fit on my mixture screw fitting.
« Reply #247 on: April 27, 2025, 03:58:53 PM »
My brother came over to help me fit the rear drive hub circlip yesterday, I could not press the chain ring down and fit the big circlip on my own. What a difference an extra pair of hands made. He actually come over to help me move some wooden shelving out of the rear bedroom ready for the new boiler installation next month.
Today I thought I could just fit the new genuine Honda Dust seal on the rear hub on my own. I've almost had it fitted twice for it to let go again.
Is there a trick to this or is it a case of needing another pair of hands holding one side in place whilst the assistant pushes the other half of the inner lip over the oversize washer ?
I started with a dry dust seal, then using Red Rubber grease, I've been closest to success with the use of grease.
« Reply #248 on: April 27, 2025, 08:06:55 PM »
You need an army of trained spiders with mechanical aptitued Ted or just determination and luck
« Reply #249 on: April 28, 2025, 11:30:23 AM »
As I have fitted new drive cushions I suspect I will need an extra pair of hands to press down on the sprocket, this gives a slightly wider gap for the lip to fit over the washer. It will have to wait for my brother to help me.
« Reply #250 on: May 04, 2025, 04:21:16 PM »
Finally fitted the drive hub dust seal, two pairs of hands made the difference - thanks brother Paul. ( He isn't a Monk)
Both carbs now cleaned, assembled then attached to the pair of mounting brackets.
Next task will be fitting the rear wheel into the frame to check if the 500T swing arm is fully suitable. There will be an unknown drop in rear ride height
« Last Edit: May 04, 2025, 04:58:49 PM by McCabe-Thiele (Ted) »
« Reply #251 on: April 11, 2026, 11:41:42 AM »
Just a bit of an update since my heath issues have improved and Wendy's Stroke last April.
I'm planning to start work on the SD in the next few weeks, it will only be a few hours a week, I see it as a sort of home  respite from my new role as a Carer.
The 500T swing arm did not work out, yes it fitted but rear wheel was way off center using the original spacers. The longer arm length was also problematic impacting on chain length & ride height.
I had the original swing arm repaired by a member on the SD website, it fitted a treat with the rear wheel central to the rear fender, frame and wheels now fitted to frame.
PXL_20250524_190205750 by Macabe Thiele, on Flickr
Offline Skoti
« Reply #252 on: April 11, 2026, 12:27:06 PM »
Good progress, it's looking nice.
I always enjoyed riding the 400's so much nicer than the tiresome 250 version.
Hope it all comes together well for you.
I see you have the proper Jap Vessel screw drivers, always a pleasure to use quality tools.
Skoti
1976 Honda CB750F1
« Reply #253 on: April 11, 2026, 12:34:15 PM »
Well spotted on the tool front Skoti, I have a set of three.
Offline hondarc166
« Reply #254 on: April 11, 2026, 05:39:54 PM »
looking good ted do a bit at a time glad you are feeling better
